Tacoma frame dimensions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tour991, Jun 10, 2016.
  1. Jun 10, 2016 at 8:39 PM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    So I'm looking for the frame dimensions for a 97 tacoma regular cab. To be more specific I Ned the measurement from the middle cab body mount to the rear body mount. I found the extra cab diagram and the measurement is 62.28 any help would be greatly appreciated
    1997TacomaSR5 and GQ7227 like this.
  2. Jun 11, 2016 at 8:46 PM
    Tour991
    James
    South Reno/Tahoe
    Bump!
  3. Jun 11, 2016 at 9:56 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    I have some chassis manuals at my shop that will have that info but I think I only have '99 and '02 books. I bet they are the same.
  4. Jun 12, 2016 at 7:10 PM
    Tour991
    James
    South Reno/Tahoe
    That would be great if you could send that my way. I'm 99.99999% sure all the cab mounts were the same for all 1st gen years.
    1997TacomaSR5 likes this.
  5. Jun 12, 2016 at 8:38 PM
    xcmtb83
    Iowa
    I think the locations will be the same but the heights can vary. I found that out when I put an '04 frame under my '99 extended cab. I took some pictures of the diagrams today but of course they look like crap and lack detail but they are missing that exact dimension anyway. I own a '96 regular cab 4x4 that I can measure for you. Are you trying to see if you frame is bent or are you fabbing something?
    GQ7227 likes this.
  6. Jun 13, 2016 at 11:31 AM
    Tour991
    James
    South Reno/Tahoe
    That would be cool if you could mesur it. I am putting a 97 2wd reguler cab on a 01 extra cab frame. I need to cut out rufly 18 inches but I want to get it exactly.
  7. Jun 14, 2016 at 3:45 PM
    xcmtb83
    Iowa
    43.75" is what I measured on my regular cab and 62.25" on my extended cab. That is center to center of cab bolts.
  8. Jun 14, 2016 at 7:43 PM
    Tour991
    James
    South Reno/Tahoe
    Thanks for doing that. I got just under 44 on my regular cab frame and it looks like there is a little room for adjustment in the cab.
  9. May 19, 2019 at 9:42 AM
    Tour991
    James
    South Reno/Tahoe
    I may on my laptop. I'll check in a little bit.
  10. May 19, 2019 at 9:43 AM
    xcmtb83
    Iowa
    I am actually going down to my shop here in a little while. I can hook you up.
  11. May 19, 2019 at 11:22 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    glad you are not hurt, jamesboy
  12. May 19, 2019 at 2:08 PM
    xcmtb83
    Iowa
    Here are the '99 measurements for regular cab and extended cab so pay attention to which one is which.
  13. May 20, 2019 at 3:35 PM
    1950desoto
    1950desoto Well-Known Member
    billy
    2017 red tacoma double cab
    I need the same info for 3rd gen double cab short bed truck. Rear end damage!
  14. May 20, 2019 at 3:36 PM
    xcmtb83
    Iowa
    Don't have it.
  15. Jul 1, 2019 at 9:10 PM
    matoose1
    matoose1 New Member
    West Virginia
    2003 White Tacoma Double Cab
    Do you have the 1st Gen Double Cab? I have an '03 and need to figure out how to fix it.
    Thanks!
  16. Aug 9, 2019 at 11:29 AM
    TRDPRO360
    TRDPRO360 Well-Known Member
    Hello, would you happen to have the frame specs for a 2017 Tacoma TRD double cab? Mainly need the right front wheel area. thanks!
    GQ7227 likes this.
  17. Oct 8, 2019 at 5:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is there any info in these diagrams that say how thick the metal is,
    interested in the inside little section that angles from box to the C, is it that same thickness as rest of frame?
    ty.
    Running Board Man likes this.
  18. Oct 25, 2019 at 7:31 PM
    xcmtb83
    Iowa
    Still need this? I have a 2004 book which should be the same.
  19. Oct 25, 2019 at 7:33 PM
    xcmtb83
    Iowa
    All material is ABOUT 3/32".
    GQ7227[QUOTED] likes this.
  20. Dec 16, 2019 at 1:10 PM
    chuckyray
    chuckyray Active Member
    rusty 01 2.4l xtracab
    Do you have diagrams for a 2001 ext cab 2.4l manual trans versus an automatic? I am looking to swap my frame and the only one I have found around me is for an automatic.
    edit: or know where to find this information online?
    GQ7227 likes this.
