Tacoma for plowing?
Discussion in 'New Members' started by thatgdguy, Jan 26, 2018.
  1. Jan 26, 2018 at 12:08 PM
    thatgdguy
    thatgdguy [OP] New Member
    Greg
    New member from the snow belt of upstate New York. I'm a past Tacoma owner who's thinking of purchasing another one, and doing some occasional snow plowing.... only a couple personal/family driveways, not commercially. Anyone with experience have thoughts on using the Tacoma for this? Thanks in advance!
  2. Jan 26, 2018 at 12:10 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    You would have better luck with an old full size 3/4 ton or full toner with a plow. No substituent for weight, especially weight close to the ground when plowing....
    I wouldn't waste my time fitting out a Tacoma to plow. They are better at other things.
  3. Jan 26, 2018 at 12:32 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  4. Jan 26, 2018 at 12:36 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Welcome & hello
  5. Jan 26, 2018 at 1:12 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome!:wave:Look for other possibilities for the plow.
  6. Jan 26, 2018 at 1:15 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    guy I work with has a plow on a suzuki truck...
  7. Jan 26, 2018 at 1:33 PM
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    I had a minute mount 11 on an 01 reg cab that worked like a champ. Stock height, snow tires,fiberglass cap and about 300lbs of tools in the bed. That was a steel blade, i dont think anyone makes a steel plow to fit a 2nd or 3rd gen, they wont hold up to it.if you buy a poly blade go easy and plow more often, like every 3-4 inches instead of waiting til 6 or8. If you are on tug hill or by buffalo 2 inches an hour happens . It is possible but as said before fullsize is made for that.
  8. Jan 26, 2018 at 1:35 PM
    jon.e.b3030
    john
    And welcome
  9. Jan 26, 2018 at 2:53 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  10. Jan 26, 2018 at 3:59 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    I have approximately zero knowledge on plowing, but welcome to TacomaWorld!
    Benzdriver81 likes this.
  11. Jan 26, 2018 at 4:02 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Snowdogg makes a stainless for our trucks. Saw someone running a boss v-plow on a 2nd gen if you'd believe it. I run a SnoWay 7'6" ploy with hydraulic down pressure. Only do my house and a few other driveways. Snow tires and cap on with about 200# of salt in the bed and I'm all good. Took care of last March's 24" by keeping on it every 4-5" because I had to plow uphill.
    I'm 'upstate' NY as well. Can always talk more if you want.
  12. Jan 26, 2018 at 6:57 PM
    mast75
    mast75 Well-Known Member
    Wilkes Barre,Pa
    2018 WHITE TRD OR DC SB AT
    TRD oil cap,Tacoma bed mat,vent visors,Undercover Tonneau cover,tinted windows,remote start,auto armor,SS toyo exhaust tip,OEM Tacoma tailgate Letters
    Welcome aboard,just use a Atv instead for plowing,my 700 Grizz w/50'' plow is awesome.
  13. Jan 26, 2018 at 11:50 PM
    tn_popo
    tn_popo OINK
    Billy
    East Tennessee
    '18 Tacoma DCSB TRD Sport V6 Inferno
  14. Dec 10, 2021 at 7:06 AM
    Blackbear
    Blackbear Hardtooree Member
    Maine
    2008 Blk SR5 2.7 4X4 5 spd ACab
    (DIY)...Fog lights, alloys, wheelwell liners, tonneau, frame cleanup & rustproofing, floor mats, trailer hitch.
    Older thread I know but for those thinking about plowing their driveways with a Tacoma without stressing their truck (I'm in my second winter with my plow...just stock components on a 2.7L 5 spd. and no issues to date) I'd suggest two keys to keep in mind.
    First, use a LIGHT plow. It will ease overall stress on front end components (tie rods, control arms, ball joints, etc.). I like the SnowSport for it's minimal weight, simplicity and low cost but there are others.
    And second, your not plowing commercially or in a plowing race so go SLOW and EASY...no slamming into snowbanks from 30' out or trying to grind straight through 10"+ of heavy wet snow for long periods. Just take it easy, take reasonable 'bites' depending on snow depth/weight, and push the snow rather than slamming it. 4H in 1st gear, 4L only for straight-line pushing (like if you need more traction...turning messes with the front end in 4L). Weight ratios on Tacomas are about 60/40 front to rear and overall weight is about 4,000-4,500 pounds so putting about 300-500 lbs. of 'ballast' in the rear between the wheel wells can be effective for improving traction (plowing or not) and won't affect steering at higher speeds so it's a good idea for winter weather. If snow conditions get too dicey (too deep or heavy) either use a snowblower or hire the plowing out for that particular storm.
    If you plow with the storm (every 4-8" or so depending on fluffy vs. wet...in any case don't wait for a 15" or 20" storm to finish) you can plow snow without hurting your truck any more than using a truck for 'truck stuff' does. Tacomas aren't road graders or commercial plow trucks but the idea that they won't/can't occasionally plow a residential driveway is nuts. They can and WILL move snow effectively...if the driver is just smart about it.
  15. Dec 10, 2021 at 10:26 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
  16. Feb 13, 2025 at 11:14 AM
    cjbiii
    cjbiii New Member
    Chip
    2023 Tacoma SR-5 Double-Cab
    speakers, vent shades, bug deflector, tonneau cover
    They plow fine. I plowed my hilly .4 mile road for many years with a second gen (4.0L). Use a light plow like a Homesteader and plow in low 4x4 if the snow is heavy. My 3rd gen (3.5L) plows exactly the same.
  17. Feb 21, 2025 at 5:15 PM
    Blackbear
    Maine
  18. Feb 21, 2025 at 5:36 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I’d go full size beater. However I’ve seen wranglers plow so I’m sure a taco is up to the challenge.
  19. Mar 24, 2025 at 6:53 AM
    Blackbear
    Maine
    Re the above video by Yah-M, can't say enough about how well he presented his work...very top-notch (he's got vid skills for sure). Regarding the plowing end, the only thing I'd note is that YM has ALOT of room to put his snow to the sides of his driveway (that's a BIG driveway...more like a road with a field edge). Most people likely don't have anywhere close to that much room push snow. So, you'll need to plan ahead for both how and WHERE you'll put it and remember that some states don't allow pushing into or across a public way (it's illegal and can piss off the neighbors). Just take it easy on the push...slammin' ain't good for your truck no matter what you drive. I'm into my fifth winter using my Snowsport plow on my little 2.7L...no issues yet with truck or plow. Happy plowin' to ya.
