Tacoma Dash Accessory Mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaliRaisedLed, Feb 1, 2022.
  1. Feb 1, 2022 at 8:46 AM
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Welcome
    Cali Raised Led
    www.CaliRaisedled.com
    Phone (714)-752-6315 Or (714)604-6426 Email info@caliraisedled.com Instagram
    @cali_raised_led
    Main Threads
    https://www.tacomaworld.com/threads/cali-raised-led-products-pricing.439264/
    https://www.tacomaworld.com/threads...ng-great-affordable-led-bars-and-pods.376180/
    Accessories are necessary but can really be too much to handle when you're needing to focus on the trail ahead. Find yourself fumbling with your phone? Looking for a place to store the walkie-talkie while you lead the way on the trail? Or maybe, you need that go-pro mounted to capture your sweet ride across the countryside.
    Cali Raised LED is proud to release the ALL-NEW extruded Tacoma Dash Accessory Mount - a multi-optioned mount to ensure your gear is close and within reach, but doesn't interfere with your ride.
    CHECK IT OUT: https://caliraisedled.com/products/dash-accessory-mount?_pos=3&_sid=1e5088d8a&_ss=r
    sized_dashmount_0000s_0003_DSC04998.jpg sized_dashmount_0000s_0002_DSC04999.jpg sized_dashmount_0000s_0000_DSC05003 (1).jpg
  2. Feb 1, 2022 at 9:03 AM
    Minsky_Machine
    Minsky_Machine New Member
    J
    2022_LunarRock_OR_DCLB_4x4
    Why is it so short? Is there an option for a longer one? Also is there any adjustability, or are you limited to only those two mount points?
  3. Feb 1, 2022 at 9:23 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    We have a ton of different accessories available for purchase on our website right now! Check it out using the link below!
    https://caliraisedled.com/search?q=Dash&type=product
    na8rboy likes this.
  4. Feb 1, 2022 at 9:48 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    From a design element, it looks to me like they went to some great length to tie it into the centered appearance of the head unit, including sloping the ends to somewhat mimick the edges of the trim bezel on the HU. I would also guess the T rail would give you adjustability of the ball mounts. With the sea of many different track mounts, TPAM's, etc., this has some nice lines to it. If I didn't have an EE TTM already, I'd jump on this because it looks pretty sweet.
    Well done, Cali!
    Ngneer likes this.
  5. Feb 1, 2022 at 11:37 PM
    Minsky_Machine
    J
    LiquidArrogance likes this.
  6. Feb 2, 2022 at 7:17 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    You have the ability to move the two joints or balls across the track. There are options on the website to make an arm longer or shorter based on which accessories you would want. Let us know if you have any other questions
  7. Feb 2, 2022 at 7:32 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    Can you get it with 25mm balls vice 20mm balls?
  8. Feb 2, 2022 at 7:40 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Pretty neat. Always good to have more mounting options available. I would recommend if you don't have one already, an end cap. One with a rubber grommet of sorts for wires to pass through and one without to clean up the ends. Seeing the sides with the slots exposed, in my opinion, looks incomplete.
  9. Feb 3, 2022 at 1:01 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Good idea! We will look into a solution!
    Extrakrispy and GrizzledBastard like this.
  10. May 13, 2022 at 6:42 AM
    Doc62
    Dave
    SE Pennsylvania
  11. May 16, 2022 at 8:37 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Unfortnelatly, Track form does not make a 25"mm ball. Please let us know if you have any other questions.
  12. Jan 8, 2024 at 4:23 PM
    timw1
    timw1 Well-Known Member
    Tim
    Arapahoe
    2023 Tacoma TRD OR DCSB
    CaliRaisedLed[OP] likes this.
  13. Jan 10, 2024 at 9:16 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thank you so much for sharing! Love your set up. :bananadance:
    timw1[QUOTED] likes this.
  14. Feb 9, 2024 at 6:49 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
  15. Dec 11, 2024 at 7:49 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
  16. Dec 31, 2024 at 8:53 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2.
    Not as clean as the TG MM, which is invisible with the balls removed.
    End caps would help.
  17. Feb 25, 2025 at 7:31 AM
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    Are there any plans for a MagSage compatible mount? The magnet holder would be great if it was compatible, but I see reviews it isn't. I also dont want to add a metal plate to the back of my phone (I dont use a phone case).
  18. Feb 25, 2025 at 9:50 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thanks for reaching out. I am unsure as to if there are any plans to add since Tack Form is one of our partner companies. I too use a Magsafe case. I need up using there spring-loaded phone mount on my setup and it is just as easy to use! I would highly recommend considering that as another option.
    Here is the link to check it out and see if it's something that would work for you!
    https://caliraisedled.com/products/phone-cradle-with-3-5-arm
    nucl3ar likes this.
  19. Feb 25, 2025 at 2:35 PM
    timw1
    Tim
    Arapahoe
    Tackform is good stuff!
    Kolache007 likes this.
  20. Feb 26, 2025 at 3:18 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I can’t remember where I bought mine from, but can go look. It’s a MagSafe compatible charging magnet mounted to my dmm, but it would fit on the caliraised mount as well. Ramball compatible. It’s super solid and charges at the same time. I ran the wires in behind the radio and spliced into 12V.
    nucl3ar[QUOTED] likes this.
