Tacoma Cat delete pipe "testpipe" Walk around rev
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phearson, Jan 3, 2013.
  1. Jan 3, 2013 at 2:19 PM
    Phearson
    Phearson [OP] Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
  2. Jan 3, 2013 at 2:53 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I'm sure you're going to get some haters giving their opinion. Once my cat goes bye bye I may gut it and used an O2 sim.
  3. Jan 4, 2013 at 6:52 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    So i'm assuming the CEL stays on all the time on your truck now?
  4. Jan 4, 2013 at 9:25 AM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Not bad
  5. Jan 4, 2013 at 9:31 AM
    Boosted TRD
    Boosted TRD your what hurts!?!?!?
    Zeb
    So Cal
    00 TRD SR5 4x4 5-spd supercharged, Cantilever L/T.
    TRD Supercharger, URD 7th injector, 2.2" S/C pulley, light weight crank pulley, CAI, CB exhaust, Camburg Mid-Travel front, LSK Cantilever L/T rear
    Doesn't sound as raspy as I thought it would...Hows it perform on the a$$ dyno?
  6. Jan 4, 2013 at 9:38 AM
    Phearson
    Brad
    Gresham OR
    My o2 sensor are already bad and no the cel light isnt on. The tone is pretty deep just the video dosnt pick it up. Its a little raspy now that the packing has burnt out. But past 3k when the cams open it scremes
  7. Jan 4, 2013 at 7:19 PM
    Bubbaknowz
    Bubbaknowz Well-Known Member
    Travis
    Everglades city Florida
    01 tacoma TRD 3.4 5spd
    Grill Guard
    I have been wanting to do this since we did it on my dads chevy but how do you do it i was told on TW it would put your motor in safe mode?
  8. Jan 5, 2013 at 8:11 AM
    AggiePilot12
    AggiePilot12 Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    I deleted my cat as well. (went bad, easier to replace pipe than to order/install new cats). Used the URD o2 sim to make the CEL go away (worked right away, 2min install).
    But to answer your question: No, the engine doesn't go into safe mode. Nor does it affect the "back pressure" issue everyone seems to think, if anything the truck is less restrictive during acceleration. Phearson, do you agree?
    Also, what kind of glasspack is that? I have the exact same setup just with the stock muffler. Looking for something with decent rumble under acceleration load, but no hwy drone and curious if a muffler or glasspack is the way to go.
  9. Jan 5, 2013 at 10:47 AM
    Phearson
    Brad
    Gresham OR
    yeah. Back pressure isn't a problem. Test pipes are common on lots of cars. And I think its a magnaflow glass. Not sure though. Just picked it up one day
  10. Jan 5, 2013 at 12:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have to point out one thing before everyone thinks this won't throw a code like this guys truck.
    It's a 96 which has a different ecu then 97-04. I am sure that's why no code is being thrown and it's operating a bit different. So for those of you 97-04. Plan on getting the o2 simulator to get rid of the code.
    Also yes back pressure is very important on NA vehicles. I'm willing to be money you have a big loss of low end torque. Yes you did probably gain a bit in the hi rpms(higher then 3k). But we drive trucks..low end power is way more important I would think so not sure this is a great mod for those looking for performance. Unless you are planning on getting a sc..which OP of you are make sure to get a 97ecu to swap in.
    There is my opinion with some facts sprinkled in.
    Cheers
  11. Jan 5, 2013 at 12:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    if any exhaust system has back pressure, it's not running very efficient. Modern exhaust systemsare designed to run with no back pressure, but rather used exhaust scavenging to increase efficiency and performance. modern catalytic converters have a little impact on the way exhaust systems flow.
  12. Jan 5, 2013 at 12:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very true. Not sure that was the case in the mid 90s though..
  13. Jan 5, 2013 at 12:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    soon after auto manufacturers learn how to tune intake systems, they realized the advantages of tuning exhaust systems. this began in the early eighties
  14. Jan 5, 2013 at 1:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    fair enough.
    Didn't you yourself though do a dyno test where opening the exhaust up on our motors though merited a loss in power? because toyota had already tuned for the best efficiency on our motors?
    Opening exhaust up too much without FAI is a bad thing..the only time its good to have a super open exhaust is if your running a turbo for the quickest spool possible..
  15. Jan 5, 2013 at 1:18 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    :popcorn:
  16. Jan 5, 2013 at 1:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have done a lot of dyno testing with different exhaust configurations.
  17. Jan 5, 2013 at 1:49 PM
    blakes09
    Blake
    Deep South
    4x4
  18. Jan 5, 2013 at 2:44 PM
    Phearson
    Brad
    Gresham OR
    I have friends who think its cool to unbolt and run it right out the cat on there 3rd gen 22res. Ive hit the rev limit in my truck countless times and run mine hard. Mine has 300k miles on her and she still gets up and goes. There Toyotas. Theres hardly and loss in power. Kust keep that rpm range up like there ment to be run ;)
  19. Jan 5, 2013 at 3:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe.
    22R's are a different animal. They are a pretty in efficient engine, so most any exhaust mod can wake them up a little bit. The 22R, 3RZ, and 2RZ bennafit most from a "tri-Y" header, and a 2.25" exhaust. The 3.4's in the first gen Tacomas seem to like a long tube header, and 2.5" piping, while the 4.0 like the "Shorty" headers, and 2.5" pipe. Most any "Flow thru" muffler will yield similar gains, as I have only seen a variance of a couple hp one way or another amongst the brands. Flowmasters, and other small, baffled mufflers give a nice loss of HP/Tq thru the whole rev range.
  20. Jan 5, 2013 at 3:12 PM
    AggiePilot12
    Texas
    Modern day exhausts (specifically cats) are efficient enough to not have that much back pressure.. As already mentioned. Thus, cutting a cat really ISN'T a performance mod. When accelerating however, you are naturally going to have less resistance with no cats. Regardless of low or high rpm's. Not a loss of torque.
    We can be at this all day. It's a Toyota.. Specifically a 3.4L. They're bullet proof. They're going to operate great regardless of the condition. :cool:
