Tacoma battery upgrade to Lithium?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dronzoni90, Sep 21, 2021.
  1. Sep 21, 2021 at 1:44 PM
    Dronzoni90
    Dronzoni90 [OP] Member
    Danny
    2018 Tacoma Off Road
    ARE Overlander Shell, TruckVault, FrontRunner roof rack, Darche 270 awning
    Can the alternator of the Tacoma properly charge a LiFePO4 Lithium battery, or do I need to install something like a RedArc charger?
    I recently installed a dashcam and my puny little 24F battery that came with the truck 3 years ago can't run the dashcam in parking mode for very long before the voltage drops too low. I'd like to be able to have a battery that can run the dashcam for at least a few days since I don't drive the Tacoma every day.
    Ideally I'd like to have a dual battery set up with at least a 100Ah lithium battery as the aux/house battery, but I just can't find any setups in the engine bay that would fit a lithium battery of that capacity/size as well as a regular starting/cranking battery. This is leaving me to consider using a lithium battery as my cranking and house battery.
  2. Sep 21, 2021 at 1:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The alternator charging voltage is ECU controlled. It is a pretty easy tuning edit.
  3. Sep 21, 2021 at 1:52 PM
    Clearwater Bill
    Billy
    Largo Florida
  4. Sep 21, 2021 at 1:53 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    From what I've seen of lithium batteries so far, I don't trust them
    Abject4x4 likes this.
  5. Sep 21, 2021 at 1:54 PM
    Dronzoni90
    Danny
    I don't know how I'd change that setting. I know nothing about accessing and/or changing values in the ECU
  6. Sep 21, 2021 at 1:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    Can you be more specfic.
    As in why?
    Curiosity and such
  7. Sep 21, 2021 at 1:55 PM
    Dronzoni90
    Danny
  8. Sep 21, 2021 at 1:56 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is done with the vF Tuner software.
    If you're committing to a $500+ battery, it would be good to get the most out of it. Folks, like me, offer tuning services, or the software can be purchased at vFTuner.com .
    shotgunbilly420 likes this.
  9. Sep 21, 2021 at 1:58 PM
    Dronzoni90
    Danny
    I'll keep that in mind. Thanks!
  10. Sep 21, 2021 at 1:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Skydvrr likes this.
  11. Sep 21, 2021 at 2:08 PM
    Evostaco
    Nebraska
    Well, I've seen them cause no start issues. Non functional accessories. As well as the lack of test equipment if you do suspect it to be bad. Currently it is just a math equation based off of the voltage from what I've been told. In my eyes they are un proven, and manufacturers arnt ready for them compatibility wise
  12. Sep 21, 2021 at 2:54 PM
    adhumston
    adhumston Well-Known Member
    https://www.**************/collecti...harging-technology-for-toyota-trucks-and-suvs (offgrid4x4)
    https://www.renogy.com/12v-100ah-smart-lithium-iron-phosphate-battery/
  13. Sep 21, 2021 at 3:02 PM
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    Considering a vehicle electrical system is filled with noise and what not I think the LiPO batteries should have integrated charge controllers considering they like to boom when they are charged improperly
    MasOlas likes this.
  14. Sep 21, 2021 at 3:02 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    At that price, those should have a BMS to deal with charging voltage.
    not_nick likes this.
  15. Sep 21, 2021 at 3:05 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    the battery runs fine in my truck.
    skyking3 likes this.
  16. Sep 21, 2021 at 3:05 PM
    Dronzoni90
    Danny
    I saw that, but it can only fit a Group 35 battery and I can't find any Lithium batteries with at least 100Ah of capacity. I'm hoping for this much capacity so that I could run electronics including a low voltage bunk warmer (heating blanket) for a few days without needing solar panels (which I intend to get much later). Most Group 35 lithium batteries only have about 50Ah of capacity which is significantly less than I'd like.
    I originally was looking at a Yeti 1500X battery bank that I'd keep in the bed of the truck when camping, which has 140Ah of capacity, but I can't easily hook my dashcam up to that. Because of this, I'm completely re-evaluating my designs into something like a mounted dual battery set up with the house battery having 100+Ah of capacity, or going back to my original design but having a beefed up cranking battery. That is, I'd have a lithium Group 31 battery as the cranking battery, and then have a Yeti 1500X in the bed of the truck
  17. Sep 21, 2021 at 3:07 PM
    Dronzoni90
    Danny
    It does say it has a BMS, so does that mean that I wouldn't have to make adjustments to the ECU for the alternator output? Or would that be a question for the battery manufacturer?
  18. Sep 21, 2021 at 3:08 PM
    Dronzoni90
    Danny
    What battery do you have?
  19. Sep 21, 2021 at 3:09 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    the antigravity lithium one...
  20. Sep 21, 2021 at 3:12 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Those batteries do not like temperatures below 32*F or 0*C.
    Somethings to consider.
    When a Li fails, a self-sustaining fire can erupt. The fire must be extinguished with sand, similar to a Mg fire.
    Air freight requires special handling and containment vessels.
    Power tool companies spend millions $ controlling charge/discharge cycles. (I doubt if your Toyota can control the charge/discharge cycle)
    Good Luck.
    mabepossibly likes this.
