Tacoma 3rd Gen Rear Axle Assembly Swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arthurtaco, Nov 4, 2020.
  1. Nov 4, 2020 at 9:52 AM
    arthurtaco
    arthurtaco [OP] Member
    2016 Tacoma Sport 4WD
    3” front lift, 2” rear. 285/70/17 Ko2 Tires, C4 Lo-Pro Bumper, Smittybilt 9000 lb Winch
    6A786480-103D-45FC-94F8-BC4CC479ECD6.jpg Hi guys!
    I’m pretty new to Tacoma World so not sure if this has already been answered.
    I recently broke my left rear axle and will need to replace the whole assembly. My setup is a crew cab, (4Dr) 6 Cylinder and needs AT (3.91) ratio. It’s a sport model so originally it’s w/o electronic locking differential.
    I was thinking might as well buy an assembly with an electronic locking differential. How would the controls need to be set up in the interior? Is it simple or pretty complex?
    Any insight would be very grateful.
    tonered and fuzzydoodle like this.
  2. Nov 4, 2020 at 10:12 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
  3. Nov 4, 2020 at 10:59 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I thought @BigWhiteTRD just helped someone do exactly this. There was a thread yesterday or the day before.
  4. Nov 4, 2020 at 12:04 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Sometimes timing is just sublime...
    (and of course @fuzzydoodle is the one who came up with the concept, put his money on the line, made it happen, and documented it... so kudos to him)
  5. Nov 4, 2020 at 12:28 PM
    fuzzydoodle
    fuzzydoodle Well-Known Member
    Jordon
    Arlington WA
    2016 Inferno Double Cab TRD Sport
    Super easy dude, I'm (obviously), all for it, but just your axle shaft broke and you can't replace it? Its fairly easy...
    As for the swap, super easy if your planning on buying a while assembly, and as time goes on, I'm sure more wrecked ones (like I bought) are becoming available. The wiring is a easy as where you want the switch.
  6. Nov 4, 2020 at 5:31 PM
    arthurtaco
  7. Nov 4, 2020 at 5:44 PM
    arthurtaco
    @fuzzydoodle I wish it was just the shaft, that's +/- $300 vs $1800 for the assembly. I can double check with the mechanic I'm working with, but sounds like it's the whole thing.
  8. Nov 4, 2020 at 7:15 PM
    Nw_nomad
    Nw_nomad Well-Known Member
    2019 Tacoma Trd offroad 6MT
    How?
  9. Nov 4, 2020 at 7:26 PM
    fuzzydoodle
    Jordon
    Arlington WA
    Ahh, so the axle housing itself? Cracked? Hit a boulder?? I'm with the above, how?
    I'm not sure if that harness would even work for you, you may have to do the leg work on it. The sport does not have the same vehicle harness, body control module, or I believe even ECU to even process the rear locker even being a thing (unless I dont interpret that harness correctly).
    All and all it probably cost me 50-60 bucks in parts, including the color matched locker switch, two resistors, diodes, a harness w/relay, and a little wire.
    Also as an afterthought, if you do purchase the axle assembly, I would just confirm they're sending the axle harness as well (the pigtail with the sensor/locker plugs), I dont see why they wouldn't, but, I've found myself burned to many times leaving things to chance and assumption.
    BigWhiteTRD likes this.
  10. Nov 5, 2020 at 3:35 AM
    BigWhiteTRD
    Ted
    I dont think Lapoltba 's 2wheel low harness would do much (anything) for you.
  11. Nov 5, 2020 at 3:38 PM
    arthurtaco
    The short story is a car jumped out in front of me out of a driveway, we collided..I went up a hill, at around 40mph, was airborne and landed on a parked car. Was a pretty bad wreck, but thank God everyone came out alive. Also good thing engine is for the most part intact.
    @Nw_nomad
    @fuzzydoodle
    Nw_nomad and fuzzydoodle like this.
  12. Nov 5, 2020 at 7:28 PM
    fuzzydoodle
    Jordon
    Arlington WA
    Damn, ON a parked car??? Did someone get it on video!?
    You know, you can let up, you don't have to hammer down to prove a point. Lol
    Glad you're, everyone really, is ok, I'll be waiting for the video link.
    arthurtaco[OP] and whatstcp like this.
  13. Nov 6, 2020 at 12:52 AM
    juicedstang999
    juicedstang999 Well-Known Member
    rich
    99 TRD SR5 AUTO XTRA CAB
    6" RC Lift 33's 200k+ club
    Sounds like an episode of wildest police chases!
  14. Nov 6, 2020 at 5:20 PM
    Nw_nomad
    Damn that's wild.
  15. Nov 6, 2020 at 10:18 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    That was the time to have a dash cam if there ever was one.
  16. Nov 9, 2020 at 2:30 PM
    arthurtaco
    Sorry boys, no video available. Had a GoPro at one point but not at that time. :facepalm:
