Tacoma 2022 condenser A/C fan
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoarm, May 4, 2023.
  1. May 4, 2023 at 2:03 PM
    tacoarm
    tacoarm [OP] Member
    Armando
    2022 Tacoma TRD 4x4 Sport
    Hi Guys I'm adding a cooling electric fan for the ac condenser and I need your help for the wire connection, what is the best way? any ideas?
    Hoksamoen likes this.
  2. May 4, 2023 at 2:07 PM
    tacoarm
    tacoarm [OP] Member
    Armando
    Anyone knows what this connection is not connected for, will it be for some fan?
  3. May 4, 2023 at 3:17 PM
    caribe makaira
    Caribbean, Puerto Rico
    No, it's a junction block to the CAN-BUS circuit. Leave it alone...
    Otterstuff, HondaGM and Kolter45 like this.
  4. May 4, 2023 at 3:33 PM
    caribe makaira
    HondaGM, OnHartung'sRoad and Kolter45 like this.
  5. May 4, 2023 at 3:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Relay to the battery and a switch in the cab is the easiest way to do it if you are not comfortable with doing more.
    HondaGM likes this.
  6. May 4, 2023 at 3:46 PM
    OnHartung'sRoad
    Are they using that for the AC fan installation TSB? I was also considering using the leads to the compressor clutch to power a fan relay switch.
  7. May 4, 2023 at 3:55 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Random question from someone who doesn't know much about trucks. Why are you doing this? I ask as I've had cooling issues with my truck in the past, and have debated a CSF radiator. This seems cheaper and easier to do.
    HondaGM likes this.
  8. May 4, 2023 at 4:00 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This is only to help out lackluster AC performance while idling / stop and go on a hot day
  9. May 4, 2023 at 5:06 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    HondaGM and Rainoffire like this.
  10. May 5, 2023 at 6:44 AM
    tacoarm
    tacoarm [OP] Member
    Armando
    Thank you.
    HondaGM likes this.
  11. May 5, 2023 at 10:48 AM
    caribe makaira
    OnHartung'sRoad and HondaGM like this.
  12. May 5, 2023 at 10:56 AM
    caribe makaira
    P.S. Knowing Toyota, the wire to connector A35 is most likely there and up to connector IA5 on one side.
    If anyone could confirm this...:tumbleweed:
  13. May 5, 2023 at 11:13 PM
    islandhiker
    Calgary, AB
    Gotcha, thanks for the reply
  14. May 6, 2023 at 11:57 PM
    caribe makaira
    Add missing relay, tap the Battery Charger Relay (pin 2) for IGN, same as OEM if CDS was part of the install.
  15. Apr 5, 2024 at 9:07 AM
    vp12198
    vp12198 Member
    Frank
    Miami
    23 toyota tacoma SR5
    Stock
    88590-35051 Look up this part it should fit perfectly on your taco is made for that plug and play
