TACO TABS - DON'T DO IT!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RUMHAM1, Oct 8, 2021.
  1. Oct 8, 2021 at 11:19 AM
    RUMHAM1
    RUMHAM1 [OP] Well-Known Member
    David
    Denver
    08 TRD Off Road 4x4 DCSB
    I'm a little annoyed that Poly Performance gave me the middle finger when I asked them about why my alignment still floated after putting in their Taco Tabs. They stated it was how the TC gussets were welded in and "spread" which is a joke.
    If you have installed the TC gussets you know there pretty hard to mess up, but yet I am at fault and have heard a couple folks that had the same issue.
    The tabs don't fit, they are too small for the TC tab gussets and my alignment moves backing out of my driveway. Save your money and weld the stock cams. Figured I'd share my luck with these jokers before someone else made the move to these stupid things.C01F35C8-05C5-4CB3-920E-DCB60A3A3BB1.jpgC437D5AC-8AA1-40F2-A258-CCCD5C1F792B.jpg
    GilbertOz, Dye22 and Stonekoldb1 like this.
  2. Oct 8, 2021 at 5:04 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Welding the stock tabs is really a pretty good option. I have yet to hear of anyone that's welded theirs, who's had a problem with them.
    For the money you'd spend on the Taco Tabs, you could buy an inexpensive welder at HF.
    Scrat and Dye22 like this.
  3. Oct 8, 2021 at 5:23 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Hmmm.... this is next on my to do list.... but im not quite ready to weld the cams in place.
  4. Oct 8, 2021 at 6:35 PM
    TacoTuesday1
    FL
    doesn't JD Fab solve this by beefing it up
    Naveronski, bhigbee and Torspd like this.
  5. Oct 8, 2021 at 9:18 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    for that price you can just buy a new truck with a beefier frame.
  6. Oct 9, 2021 at 6:54 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    $1000 isn't even a downpayment with the current market :D
    Superdave1.0 and lferrara like this.
  7. Oct 9, 2021 at 2:38 PM
    winkel
    Corydon, IN
    You don't weld the cams. You weld a nice bead behind your stock tabs, attaching them more securely to the frame.
  8. Sep 30, 2023 at 10:46 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    yes you do, you put a tack weld on the eccentric washer to keep it from moving. running a bead behind the tabs is a solution for the the tabs being flattened by a moron
    Scrat and Torspd like this.
  9. Sep 30, 2023 at 5:05 PM
    winkel
    Corydon, IN
    Well damn, I hadn't considered that.
    Torspd and Ricardo13x like this.
  10. Oct 1, 2023 at 3:08 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Taco Tabs do not use round eccentric washers that could rotate. Taco Tabs uses almost square shaped alignment plates, nestled between the frame tangs.
    While this is a topic from years ago, Taco Tab kit supplies new bolts. Those bolts must be tight to prevent minor alignment movement. Once correctly tightened, the bolt tightly secures the pivot bushing from moving out of place.
    If not correctly tightened, the suspension bushing will wear away the frame causing other concerns.
    The bolts supplied with Taco Tabs, per the instructions, the large bolts torque to 125 ftlb, while the small bolts are 100 ftlb.
