Tablet Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishWolf, Mar 4, 2022.
  1. Mar 4, 2022 at 10:48 AM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Got a tablet for Gaia Gps usage..anyone have any thoughts on a good cost effective mounting solution? Thanks in advance
  2. Mar 4, 2022 at 1:59 PM
    10YSON
    10YSON Well-Known Member
    GREG
    2ND GEN 4X4 LT
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    I have Ram mounts in my truck for an iPad mini and my iPhone, I have been very happy with them. Ive tried some the cheaper mounts and you definitely get what you pay for with the ram stuff.
  3. Mar 5, 2022 at 6:06 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    I have 2 ram mounts that I use for a Samsung tablet as well as my phone that are both mounted to a Tech Deck. Not the bet pic but the only one I can find.
  4. Mar 5, 2022 at 10:46 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Another Ram mount user but expect movement on bumpy or washboard roads. Keep it as short/close to the base as possible and use as few parts/connections as possible.
  5. Mar 20, 2022 at 7:18 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I have a 3rd Gen but have the same question. Anyone mount a tablet from the passenger side seat bolts? I was wondering if a console side Molle panel would be strong enough to mount a Ram Mount.
  6. Mar 20, 2022 at 9:02 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    BlkDakDave and ODSC1 like this.
  7. Mar 20, 2022 at 9:09 PM
    TacoTuesday1
    FL
    Check out expedition essentials 2TPAM
    Seen a guy selling one used Facebook marketplace
  8. Mar 20, 2022 at 11:26 PM
    Bajatacoma
    SC
    I've got two of those seat bolt setups as well; I had one in my VW Westy and one in my Tacoma, both for use with a netbook (kinda gives you an idea how long ago that was). The version with the thicker aluminum pole was more stable but both needed another point of contact to help limit movement so I had made something to work. I removed them and never tried them with my tablet so can't comment on how well it would work for them. I've still got the pieces in storage along with other unused RAM stuff (motorcycle mounts, old GPS mounts, etc). At one of the places I worked we tried them in some of our ambulances with Toughbooks, again, not really impressed.
    ODSC1[QUOTED] likes this.
  9. Mar 21, 2022 at 7:23 PM
    xplorn
    xplorn Well-Known Member
    Ken
    Oregon, USA
    '10 DCSB OR
    This is overkill for most. I use a somewhat large Surface Pro for serious mapping. It stays secure over rough terrain in the large RAM X-grip for tablets. Two arms go to the mounts that were made for either side of the heater controls.
    For a standard size tablet I'd think one arm off a deck style mount to a smaller x-grip would work fine.
  10. Mar 22, 2022 at 9:27 AM
    Bajatacoma
    SC
    I like the two arm idea, I'm sure that works much better than a single mounting point. I've got an X Grip in the "box-o-parts" but switched to a Tab-Tite after my rubber strap thing finally broke. Current tablet is just a Galaxy Tab A 8" after my original Tab S finally died.
    Your radio sun shield looks like the one I made from Kydex for my radio- another one of those Tacoma quirks where Toyota's engineers didn't do a very good job. Before that I had a strip of Velcro above the radio and a L shaped piece of Kydex.
  11. Mar 23, 2022 at 2:17 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Any preferences over the dash mounts or cup holder etc?
  12. Mar 23, 2022 at 2:31 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    I did the "Build a Mount" option on Ram Mounts and it suggested this arm for a dash mount option, is this a non drill in to dash option? it did not specify, Thanks in advance!
    https://www.rammount.com/part/RAM-B-101U-225B
  13. Mar 23, 2022 at 4:01 PM
    10YSON
    GREG
    2ND GEN 4X4 LT
    This is how mine is mounted, no cutting and completely reversible. It's an iPad mini
    RichardC.ranium likes this.
  14. Mar 23, 2022 at 4:08 PM
    10YSON
    GREG
    2ND GEN 4X4 LT
    The Ram product you need to attach it to your oh-shit-handle is actually a motorcycle part. I found the part number for you: RAM-B-367U
  15. Mar 23, 2022 at 4:36 PM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Thanks.. I did not know about that option..the part link i posted is for a dash mount but i wasnt clear if it used existing holes in dash or you were expected to drill new ones
  16. Mar 23, 2022 at 4:56 PM
    10YSON
    GREG
    2ND GEN 4X4 LT
    I believe you drill holes and put that stainless backing plate behind your dash and then sandwich your dash between the plate and the ram mount. I thought about going this route but the interior of our truck has very few spots that are actually flat and not occupied by something other part already.
  17. Mar 25, 2025 at 6:01 PM
    RichardC.ranium
    RichardC.ranium Member
    Ben
    Thanks for this idea, I went with a tab a7 lite, runs perfect and $50, got the parts off ebay for another $50 free shipping so full nav only cost me $100, the money saved will be spent on Avenza maps.IMG_6868.jpg IMG_6865.jpg
    10YSON[QUOTED] likes this.
  18. Apr 16, 2025 at 9:24 AM
    FishWolf
    R Something
    2011 Toyota Tacoma
    Which mounting setup is this? I have that same tablet
  19. Apr 17, 2025 at 4:50 PM
    RichardC.ranium
    Ben
