T35 Torx (star) Bit/Driver ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harleyg, Jan 15, 2014.
  1. Jan 15, 2014 at 1:37 PM
    harleyg
    harleyg [OP] Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
  2. Jan 15, 2014 at 1:39 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Dealership, or Fastenal. Maybe a mechanic would do you a favor?
  3. Jan 15, 2014 at 1:40 PM
    harleyg
    Harley
    I called the local dealer. Parts dept. said they don't sell tools.
  4. Jan 15, 2014 at 1:43 PM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
  5. Jan 15, 2014 at 1:46 PM
    Spoon93
    Rogue valley
    06 DCSB SR5
    You could also call a local hardware store and see what it would take to get the piece. I know ACE isn't "local" but they are right around the corner from my place and if they don't have the piece, tool, set I am looking for they usually get it expedited in to the store at no cost to me. Makes me continually go back there even though Home Depot and Lowe's can be $1-$2 cheaper. Customer service will always win in my court.
  6. Jan 15, 2014 at 1:49 PM
    harleyg
    Harley
  7. Jan 15, 2014 at 1:50 PM
    Spoon93
    Rogue valley
    06 DCSB SR5
    Good deal. Just in time for a little weekend project.
  8. Jan 15, 2014 at 1:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Your POP & Lock has torx bolts as part of the installation?
    Hell, I'd throw those things away and put regular bolts in. I hate torx bolts.
    What type of torx is it? Button head? Square head? Flat head? Do you know the threads & length?
  9. Jan 15, 2014 at 1:59 PM
    harleyg
    Harley
    The Pop & Lock instructions say the screws on the access panel of Tacoma tailgate are T35 Torx screws. The Pop and Lock does not have Torx screws.
  10. Jan 15, 2014 at 2:20 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    I'm not so sure they're T35's. I put one of these in and my $8 ratcheting screwdriver set from Harbor Freight had the correct size (at least one that fit).
    Tip: Be careful not to strip any of the plastic thread inserts pressed into the tailgate. Also, have band aids available as someone on the production line sharpens the edges of the tailgate sheet metal during assembly.
  11. Jan 15, 2014 at 2:22 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Typically you can get by using a allen/hex key on them if you are in a bind. Use metric or standard to see which one fits best. If the bolts are tight or frozen do not use this method since it can strip out .
    Must be some crap stores by you if they do not have a t-35 torx.
    No sears? Harbor Freight?
    I agree torx is not all that helpful.
  12. Jan 15, 2014 at 2:28 PM
    harleyg
    Harley
    I went to Lowes, called Sears, Harbor Freight, the dealer and a couple of auto parts stores before posting this thread. They all carried the T30 and T40, but none carried the T35.
  13. Jan 15, 2014 at 2:33 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I just used a Torx allen key set when I took that panel off my tailgate
  14. Jan 15, 2014 at 2:35 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i just went out and checked for you...its a T-30
  15. Jan 15, 2014 at 2:38 PM
    OZ-T
    Peter North
    British Columbia
    I just did the same thing , yep it's a T30
  16. Jan 15, 2014 at 2:40 PM
    harleyg
    Harley
    Thanks. I just cancelled the order with Amazon (or it says they are attempting). Much appreciated!
  17. Apr 1, 2017 at 4:37 PM
    myol56
    myol56 New Member
    2002 Tacoma
    None
    Just use the closest Allen that fits,it will turn, the inverts are only plastic, it will give, it's not frozen
  18. Apr 1, 2017 at 4:53 PM
    OZ-T
    Peter North
    British Columbia
    Old thread is old
  19. Apr 1, 2017 at 4:57 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  20. Jun 26, 2019 at 7:04 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
