T Slot Nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Mar 22, 2019.
  1. Mar 22, 2019 at 3:19 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    What size bolts go into T Slot nuts that are in the beds of are Trucks?
  2. Mar 22, 2019 at 3:26 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    If you’re talking about the torx bolts that bolt the bed to the frame, it’s T-55.
  3. Mar 22, 2019 at 3:27 PM
    Wolftaco0503
    Adam
    Chicago
    I'm not but thanks. I'm talking about that are in rails of our Beds.
  4. Mar 22, 2019 at 3:27 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    These are the T Slot nuts that fit into the rails: https://www.mcmaster.com/94750a595
    They accept a 3/8"-16 bolt.
    PzTank and spitdog like this.
  5. Mar 22, 2019 at 3:28 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    3/8” diameter depending on what your mounting. Basic stuff 3/8”x1” bolts are fine.
  6. Mar 22, 2019 at 3:28 PM
    Wolftaco0503
    Adam
    Chicago
    Thanks Bud
    E-Paz 732NJ likes this.
  7. Mar 22, 2019 at 4:24 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you live in a salt state, put some corrosion protection on those t slot nuts and bolts, they rust!
    TheDevilYouLove likes this.
  8. Mar 22, 2019 at 4:26 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Yes they do!!
    They use a black oxide on them, which doesn't do much.
    If you're going to paint them, degrease them first, they're pretty oily upon arrival.
  9. Mar 22, 2019 at 4:39 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I got some of these from some place called Hondo Garage. Not a plug, never heard of them, but they did fine by me. They're aluminum not steel, you can twist them in mid-rail (still a PITA to get them in, but you don't have to go all the way to the ends) and they're 5/16" thread, which is still overkill for the strength of the rail anyway. The ones with 3/8" threads are just ridiculous unless you wanna use ungraded bolts made of a hard cheese, and I found I needed to drill out mounting holes too big in too many things.
    blu92in99 likes this.
  10. Mar 24, 2019 at 12:32 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  11. Jul 17, 2019 at 6:27 PM
    monarch2k18
    monarch2k18 Active Member
    southeast va
    2019 DCSB TRD OR
    Bilstein 6112 + 5160
  12. Jul 17, 2019 at 11:35 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  13. Jul 18, 2019 at 5:51 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I wanted something a little beefier, went overboard. Got some short carriage bolts, used a grinder and modded them. They work great, can hold more weight than the rails that's for sure.
    :cookiemonster:
    AVIOTREN and Torspd like this.
  14. Jul 18, 2019 at 6:43 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    That’s a great idea!!
    llamasmurf[QUOTED] likes this.
  15. Jul 18, 2019 at 6:45 AM
    llamasmurf
    Wes
    Northern Ontario
    Anyone can do it, its super easy.
    :thumbsup:
  16. Jul 18, 2019 at 7:40 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I would not recommend these unless you are very careful. They are not threaded all the way through and you can screw up a bolt easily if it is too long and you tighten down too much.
    They do however make the t nuts that are fully threaded all the way through.
