T-SB-0021-19 Rust/Paint Blistering On Lower Door Sill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HelloMyNameIs, Mar 12, 2019.
  1. Mar 12, 2019 at 5:48 AM
    HelloMyNameIs
    HelloMyNameIs [OP] I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I've been seeing some guys posting about rust and paint bubbling on the lower drivers side door sill on some third gens. Checked mine and, sure enough, it's there. Make sure you go check.
    Mine is a 2018, purchased new in September of last year. Garage kept and washed often...
    This is what mine looks like:
    TSB is attached.
    crymes, MAS and doublethebass like this.
  2. Mar 12, 2019 at 5:55 AM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    I see you have had it undercoated also, visible plug? I have had this problem fixed under warranty. Was a problem with the 2nd gen also, prep problem maybe.
  3. Mar 12, 2019 at 6:35 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’ve got the same problem on my drivers side....a little dirty in the picture but you can clearly see the rust. And I've had Krown on mine since about 2 weeks after I got the truck.
    Going to give this TSB a go next time I’m at the dealer
  4. Mar 12, 2019 at 6:47 AM
    HelloMyNameIs
    Yeah had it Krowned in October.
    doublethebass likes this.
  5. Mar 12, 2019 at 7:22 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    That to me, looks like metal shaving that bit in to paint and rusted. Guessing whom ever drilled for rust protection, never took great care to prevent/clean/protect this from happening. Looks only to be on surface.
    champcaracing likes this.
  6. Mar 12, 2019 at 7:27 AM
    Silentshredr
    Chuck
    16 DclbOr4x4
    Not so much. This is a common problem. Peel up the cover over the pinch weld, this is where the rust starts.
  7. Mar 12, 2019 at 7:34 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    You all are welcome. I had to go through this last fall and ended up getting all 4 door sills repaired. good news is the finish is great and I can not see or notice any repairs. My dealer had to get approval from MaYota, but it got done. Originally my dealer tried to pin it on my Prinsu somehow lol.
    Flash1034 and doublethebass like this.
  8. Mar 12, 2019 at 7:41 AM
    Lt. Dangle
    Ohio
    Here's one of the pics I got from my Driver door sill.
  9. Mar 12, 2019 at 7:41 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    So, how can we prevent this from happening?
  10. Mar 12, 2019 at 7:42 AM
    HelloMyNameIs
    Damn man! Were all four showing signs, or they repaired as prevention?
  11. Mar 12, 2019 at 7:43 AM
    Lt. Dangle
    Ohio
    I only noticed it in 2 sills myself, but they did all 4 so i'm guessing word came down from the top to address all of them for prevention. Probably recognized an issue with production maybe.
  12. Mar 12, 2019 at 7:47 AM
    HelloMyNameIs
    How much do you know about what they did? Seems to me if it's rusting on the edge of the pinch like in your picture, it'd be hard for them to actually fix that on the back side without cutting and welding.
  13. Mar 12, 2019 at 7:51 AM
    Lt. Dangle
    Ohio
    Not much if i'm honest. I agree, but I figure I won't own it long enough to worry too much. I just pop off my sill covers occasionally and keep an eye on it. My dealer does pretty well by my so if I do have a problem soon, I expect them to do the right thing. If not, i'll deal with it.
  14. Mar 12, 2019 at 7:52 AM
    HelloMyNameIs
    Yeah, that's why I ask; I planned on keeping this thing until it fell apart. Starting to wonder if that will be as far in the future as I'd expected.
  15. Mar 12, 2019 at 7:54 AM
    Lt. Dangle
    Ohio
    Lol. I'm not too worried, I am not buying a new truck every 2 years or anything, but I figured if need be they could just drill the weld and spread it apart, but I doubt they did that. They had it about 5 days or so.
  16. Mar 12, 2019 at 7:57 AM
    Lt. Dangle
    Ohio
    CUSTOMER STATES MISCELLANEOUS CONCERN - *CUSTOMER STATES, I HAVE RUST ON MY DRIV ~|~CUSTOMER STATES MISCELLANEOUS CONCERN - *CUSTOMER STATES, I HAVE RUST ON MY DRIVERS SIDE DOOR SILL UNDER THE PLASTIC TRIM PIECE AND THE RUBBER WEATEHR STRIP. I WOULD LIKE IT LOOKED AT AND ADDRESSED. ~|~APPROVED BY TPYPTA FOR REPAIRS,WILL NEED TO SET APPT WITH BODY SHOP ~|~APPROVED BY TPYPTA FOR REPAIRS,WILL NEED TO SET APPT WITH BODY SHOP
    That's all the info from my service record.
    Also, the SA types as bad as I do lol.
    ERod27 and doublethebass like this.
  17. Mar 12, 2019 at 8:35 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    6BAE6418-5F34-4E75-801B-DD1655041FEF.jpg E590DB93-96D2-4E9C-A0A9-337DC713402E.jpg
    Probably should check the pinch welds on the bed between the cab my started to rust....Toyota fixed it under warranty the repair was almost $1800 they did an excellent job took like a week to complete.
  18. Mar 12, 2019 at 8:58 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Great. Not exactly comforting to see having just bought a new '19 TDR Sport DCLB 4WD. Toyota must be slipping a bit.
  19. Mar 12, 2019 at 10:14 AM
    HelloMyNameIs
    Wow I'll have to check for that one too. Thanks!
  20. Mar 12, 2019 at 10:16 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    good to know there's a TSB about it. thanks for posting.
