Synthetic or Conventional Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxsoccafreak09xx, Jan 25, 2017.
  1. Jan 25, 2017 at 8:03 PM
    xxsoccafreak09xx
    xxsoccafreak09xx [OP] Well-Known Member
    Louisiana
    2009 Prerunner Lifted
    17" dick cepek rims with 33" nitto mudgrapplers tires, 3" lift, Fishing rod rack.
    I am debating on switching my oil from conventional to synthetic. I have about 97,000 miles on a 4.0 V6. What are the pros/cons? And is this a good idea to switch, or should I just stay content with the conventional?
  2. Jan 25, 2017 at 8:08 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    Synthetic is nice if you have a short commute, live in a cold region, or if you really feel like stretching your oil change intervals. Keep in mind, synthetic oil "lasting longer" doesn't mean your oil filter plugs up any slower. I made the switch to synthetic at about half as many miles as your truck has, and no regrets. I feel it fires up smoother when it's cold, but that might just be the plecibo effect.
    E-Paz 732NJ, cliffyk and 14TacoSC like this.
  3. Jan 25, 2017 at 8:12 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Either one will work to be completely honest. Synthetic is arguably "better" for your engine and helps protect against wear over time. Not to mention, you have longer oil change intervals. This is why many people use synthetic considering humans are lazy. It's a win-win with synthetic. Now, conventional is alternatively cheaper and does the job. As long as conventional oil is changed every 5-6k, it'll perform its job. Just change your filters out with every change and you'll be just fine.
    Mush Mouse likes this.
  4. Jan 25, 2017 at 8:12 PM
    xxsoccafreak09xx
    Louisiana
    Thanks for the info, I do not have a long commute and I live in Louisiana so our winters are not too intense. I mostly run 2 hrs south every weekend in the summer when it is scorching hot. I am due for an oil change and figured now might be a good time to switch to synthetic.
  5. Jan 25, 2017 at 8:35 PM
    ZachPrerunner
    Southeast TN
    Mobile 1 synthetic or Valvoline High Mileage synthetic blend. Two very good options. The Valvoline is around $18 for 5 quarts at Walmart right now.
  6. Jan 25, 2017 at 8:59 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I use Mobil 1 synthetic and have been changing it every 6 months (~5,000miles). Everytime I do a change, the oil looks brand new ( still clear ). Been this way for the past 3 years. Never fails that the oil I drain out looks identical to the oil I put in when I put them side by side. I'll probably start doing oil changes once a year moving forward.
  7. Jan 25, 2017 at 9:25 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Amsoil here. Filter changes every 5K miles, with oil changes every 10K.
    1slowvq37 and J Bumble like this.
  8. Jan 25, 2017 at 10:01 PM
    Matajramon
    Matajramon Support Taco Trucks
    Houston, TX
    2013 Toyota Tacoma dcsb prerunner
    Texas Edition
    I recommend Mobile1 or Valvoline full synthetic. Highly suggest getting genuine Toyota oil filters. I drive a lot since I change the oil every 3 months @ 5k miles. My 4.0 runs strong.
  9. Jan 25, 2017 at 10:38 PM
    Scott SD
    Scott SD Member
    I have used Amsoil 100% synthetic in every vehicle for the last 10+ years. It has a 25K mile service life and the Amsoil filters are 15K. I've had oil tested at 22K miles and it was still acceptable. I've also cut filters apart to inspect. To make life easier, I only do preventative maintenance on the family vehicles between Christmas and New Years. So, one oil change per year. Between 3 vehicles we average 15-20K miles each. No issues using Amsoil.
    1slowvq37 likes this.
  10. Jan 25, 2017 at 11:16 PM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    I use Mobil 1 synthetic on both of my trucks and my motorcycle and do oil changes at 5k miles or there about.
  11. Jan 25, 2017 at 11:34 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2010 Tacoma V-6, was recently converted to synthetic (at 88,000 miles), thank you @speedfreek. I used Castrol Edge. Jason checked it after 5,000 miles, and it looks new, but it was a half qt. low, so I added to it. No drips, either.
    I think I am happy with it. I had done changes at the dealership at 4,000 miles approx. for all the truck's life before the synthetic change over. No engine problems ever.
  12. Jan 25, 2017 at 11:38 PM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Amsoil user here as well. I've been using amsoil since 2000 on my rides and never had an issue changing at longer intervals. if you switch to synthetic just try to get an oil test after your first oil change and see what your results are.
    Norton[QUOTED] likes this.
  13. Jan 26, 2017 at 1:50 AM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    Still do your oil changes every six months, one problem is moisture build up in the oil, and also when you do your oil change, it will show if a problem is developing.
  14. Jan 26, 2017 at 1:50 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use a OEM filter and a high quality synthetic, usually either M1 High Mileage or Pennzoil High Mileage. I still change the oil and filter at about the 5k Mark, oil and filter together cost about $32 so it's not a massive expense. I suggest that you send a sample to Blackstone of your next oil change and that may help you make your decision.
  15. Jan 26, 2017 at 1:53 AM
    Doug2000
    2017 Tundra 5.7L
    You only change your oil once a year, your asking for problems.
    Bubbles and bluezzy like this.
  16. Jan 26, 2017 at 12:47 PM
    Scott SD
    Scott SD Member
    Depends on the conditions. If you live in Ontario, that may be true. Not so much in San Diego with relatively low humidity. It all goes back to the data. And like I said, I've had oil analyzed at 22k miles and it was still considered acceptable. Why would Amsoil market their product for 25K miles?
    Norton likes this.
  17. Jan 26, 2017 at 12:55 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
  18. Jan 26, 2017 at 4:07 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Oh boy, this again. LOL :)
    To answer your question, I guess it depends if you are able to leave the oil in the engine long enough to reap the benefits of synthetic oil. Many people just can't leave it in that long. Can you?
    The thing about synthetics is... you can extend your oil change intervals because synthetics resist thermal breakdown, resist shear, and typically clean better than conventional oils. In other words, synthetics do not lubricate better, they lubricate longer. Tons of tests have been done to measure the wear protection of motor oils, and... many conventional oils provided a far stronger oil film than some of the popular synthetic oils. So the conventional vs synthetic discussion does not involve "better lubrication." It's about the longevity of the oil. Running longer drain intervals places added demand on the oil filter, something to keep in mind.
    Synthetics also flow better at very low temperatures, so people living in very cold climates will get quicker startup lubrication vs conventional oils.
    For me, synthetics are worth the added cost because I can run longer OCIs, saving back the extra money and spending less time under the truck.
    About once per year, Mobil offers $10 rebates on 5 quarts of Mobil 1 (usually 2 deals per household). I bought from Wal-Mart and got two 5-quart jugs for **$13 each** after rebate. That's crazy. Way less than conventional oil from a parts store. Kind of a no-brainer.
    My Corvette owner's manual says to do a synthetic oil change at 7,500 miles or once per year, whichever comes first. I drive that car about 5,000 per year. What is the problem?
  19. Jan 26, 2017 at 4:58 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've been using Mobil 1 since the 1st oil change. I change the filter every 5K and the oil every 10K. I'm at 176,000 trouble free miles. I'm not convinced synthetic is better, but it does last longer. I wouldn't go 10K between oil changes with conventional oil.
    And up until May I was logging 20,000 miles a year on the truck. It is now driven less and I may start changing every 6 months regardless of miles. I probably won't put 10K a year on it at this point.
    Synthetic does cost more, but if you double the miles driven before changing it actually comes out cheaper to use synthetic in the long run.
    LowFourJoe, asuchemist and Norton like this.
  20. Jan 26, 2017 at 5:26 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Mobile 1 Full Synthetic here. Using it since 10k mark on new truck. I'm at 25k now. Changing at 5k intervals and it always comes out dark.
    Cold climate. Highway driving.
    Notoneiota likes this.
