Synthetic Oil yes or no
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMC3800, Jun 15, 2017.
  1. Feb 16, 2018 at 6:39 AM
    #81
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Walmart.........$17.47 jug full syn 5w30
    TRD filter......? better than OEM or same ? more $$$$$$
    Rotella T6 full syn 5w40.......JASO/wet clutch approved...in my Rhino SxS
  2. Feb 16, 2018 at 6:59 AM
    #82
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    i use valvoline synthetic OEM filter. with how todays dino oils are they would be fine to use in reality
  3. Feb 16, 2018 at 4:02 PM
    #83
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    I use Sinclair oil as it has been aged.
  4. Feb 16, 2018 at 4:35 PM
    #84
    Noslackline
    Noslackline Well-Known Member
    New England
    '15 TRD Sport DCSB 4X4 BRM
    what he said... ;)
    bnv likes this.
  5. Feb 16, 2018 at 6:04 PM
    #85
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Another one??????
    Look, there is no such beast as "full synthetic" for IC engines it is marketing. the cleaners and additives are what make it "synthetic"
    You want a good oil, go to the store and pick one, they are ALL pretty equal these days. The myth about mixing or once you go syn you can't go back is bullshit as is the myth about synthetic causing leaks or burning. The only way that happens is if you were running a non detergent single weight oil from 1923 and you change to a multi weight detergent oil. Synthetic will not cause a leak to become worse either, if you had a leak before it will still leak, the exception is these muppets that add Lucas or some other crap to the oil that has a seal swell ingredient, then you change the oil and don't add the crap and it leaks.....not the oils fault. This happens a lot with used cars or private sellers who are trying to pull one over on people.
    personally I use Mobil 1 and either an OEM or Mobil 1 filter.
    Too Stroked likes this.
  6. Feb 16, 2018 at 8:22 PM
    #86
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS3 Pro (Yellow) Driving lights Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut
    I used synthetic, its alright. It last's longer but is also more expensive
  7. Feb 16, 2018 at 9:00 PM
    #87
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Since they are all the same why don't you get store brand dino oil it is MUCH cheaper than high price mobile 1 synthetic? C'mon man
  8. Feb 17, 2018 at 3:59 AM
    #88
    Gixerkiller
    Dennis
    Taylor, TX
    personally, the store brand is MORE expensive than my bulk purchase of Mobil. I use it in 3 vehicles for a total of 15 qts, I get a break on buying it in large quantities.
    I have used Delo and everything else, even store oil. never had a problem, I use what I can get in large quantities, las time I swapped oil it cost just over 60 bucks for BOTH cars.....DELO oil alone was 55 bucks.......Mobile was on sale and I can get it at WAL MART or Sams Club or Costco for cheap.
    0-30 Mobil 1 is 30-40 dollars a gallon, Valvoline is 50, autozone does not even have "store oil" Oriely has store oil only in qts and it is 10 bucks more than Mobile1.
    oh wait Wally world has gallons for 26.00.........
    Like I said before, OIL is OIL, it is WHAT is put IN the oil that makes the "difference" I could post links, but I doubt any of ya would read them.
  9. Feb 17, 2018 at 5:24 AM
    #89
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The funny thing about any thread comparing conventional oil to synthetic is the level of real science behind most replies. People will all chime in and say that they use xxxx brand oil and have never had any problems, therefore it's the best oil in the whole world. Really? And for how long have you used that particular oil? Many have used it for less than 20,000 miles. Now I ask you, how many oil related failures have you heard of in engines having less than 150,000 miles on them - no matter what oil was used and how often it was changed? Probably none.
    I'd propose that literally any oil (conventional or synthetic) you can buy these days is probably good enough to get you over 100,000 miles of zero oil related failures. Where the differences will show up is further down the line. And what percentage of us keep a vehicle for over 100,000 miles? I'd be willing to bet that although a number of folks will chime in and say they do, probably over 95% of us do not. So as particular as I am about changing my oil and filter every 7,000 miles (using synthetic oil & a premium filter), the benefits are all for the next owner.
    3.4PDM and Lester Lugnut like this.
  10. Feb 17, 2018 at 6:16 AM
    #90
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Pennzoil Platinum 5W-30 and OEM filter, changed every 5,000 miles, currently at ~130k miles. Used M1 for the first 70k miles, but switched to PP after observing that my '14 Outback burns notably less oil with PP than M1 or any other mainstream synthetic. I don't know why, it just does, so I figured it must be some decent stuff.
  11. Feb 17, 2018 at 6:32 AM
    #91
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    According to the folks over at BITOG, the Pennzoil has a lower NOACK rating, so that’s why there’s less burnoff.
  12. Feb 17, 2018 at 6:33 AM
    #92
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    +1
  13. Feb 17, 2018 at 6:35 AM
    #93
    80schild
    Chad
    Flori-Bama
    Not trying to nitpick here, but the only oil that comes in gallons is Delo and Rotella. The rest of the bottles are 1.25 gallons (5 quarts).
  14. Feb 17, 2018 at 6:43 AM
    #94
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    True. I believe in Synthetic because of the Cold as Hell starts, and the Hotter than Hell starts, we have here in Canada. That's when it benefits the most, hence Synthetic is better for me.
  15. Feb 17, 2018 at 6:50 AM
    #95
    ecoterragaia
    Central Virginia
    Had to look up what meant, pretty cool, thanks :thumbsup:
    Bowhuntercoop likes this.
  16. Feb 17, 2018 at 9:50 AM
    #96
    Gixerkiller
    Dennis
    Taylor, TX
    Not pick who cares it is cheaper in 1.25 jugs that in qts. Matters not if it is a US gallon metric gallon or imperial gallon.
  17. Feb 17, 2018 at 9:52 AM
    #97
    Gixerkiller
    Dennis
    Taylor, TX
    No truer words have ever been posted.
    Choose an oil and run with it.
    Tell everyone else to go suck ass.
  18. Feb 17, 2018 at 10:15 AM
    #98
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    https://www.tacomaworld.com/threads/400-000-miles.404359/
    This guy, 400k. I've been following his recipe, lol. I got lucky and my Walmart clearanced out some Bosch ep filters and I bought like 25 of the bigger ones at $3 each. I get the Mobil 1 ep when it's 5 off through Ibotta at Walmart. It is right now if y'all want to save $5, so is standard M1 and their yearly stuff. So you get M1 for price of dino.
    If you want an extra $5, total of $10, use my referral link below or type in the code, if you don't already use the app that it's. Think we both get $5 or something :thumbsup:.
    https://ibotta.com/r/xandtrx
    Code xandtrx
  19. Feb 17, 2018 at 8:34 PM
    #99
    taco2010trd
    Tampa, Florida
    Quit wasting your money and buy walmart dino oil.
    Blockhead and BillsSR5 like this.
  20. Feb 18, 2018 at 5:22 AM
    #100
    Gixerkiller
    Dennis
    Taylor, TX
    sorry dude,
    the Mobil 1 is still cheaper.
    and I have vehicle in the stable BUILT on the use of only "synthetic" oil, the logical thing is to buy in bulk and use the same oil in 3 vehicles as opposed to certain oil for each.
    Yall can do as you wish, synthetics lasting longer and being better than standard oil is the never ending argument.
    the answer is neither is bad, neither is good, neither is best. As of 2018 ALL OIL is good oil, this is not 30-40 years ago when "Synthetics" had an advantage.
    EVERY oil and company has a formulation of additives that "make" the oil, some have low ash, others low sulfur, others have extended polymer compounds, and still others formulate with natural gas or charged particulates.
    wal mart dino oil is probably made by United Oil, which gets its products from Chevron...probably.....
    before this goes any further and people start getting butthurt and the bans start let me make the final statement which is NOT conjecture...
    525
    6-1. Specifications
    6
    Vehicle specifications
    Engine oil selection
    “Toyota Genuine Motor Oil” is used in your Toyota vehicle. Use
    Toyota approved “Toyota Genuine Motor Oil” or equivalent to satisfy
    the following grade and viscosity.
    Oil grade: ILSAC GF-5 multigrade engine oil
    And Toyota has a "Warranty and Maintenance" guide that says BOTH 2.7 and 4.0 in both schedule A (non synthetic) AND schedule B (synthetic)
    the oil is changed at 5,000 miles and a rotation of the tyres is also performed. MAJORITY of manufacturers are at this point for oil.
    EITHER synthetics or standard are FINE in BOTH of the engines. NEITHER is recommended over another.
    USE WHAT YOU LIKE AND WHAT YOU CAN AFFORD> CHANGE IT OFTEN AND ALWAYS USE QUALITY FILTERS.
    END OF ALL OF THIS.
    Moderators, can we lock out these bloody oil threads?
    outlawtacoma likes this.
