Synthetic Oil yes or no
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMC3800, Jun 15, 2017.
  1. Jun 16, 2017 at 8:41 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Jun 16, 2017 at 10:14 AM
    #42
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    I use Mobil1 5w-30 and a Purolator Pure1 filter. The oil can be bought in a 5 qt jug at Walmart for $23-27 depending on if its on sale, and the filter is about $5. So roughly $30 for a full synthetic oil change. It's so easy to do on these trucks (no ramps needed, filter on top, etc) that I am more than happy to do it myself.
    I've torn into engines of mine at over 100k and they look clean enough to eat off of. To be fair, that probably has more to do with consistent oil changes and not the brand of oil though.
  3. Jun 16, 2017 at 8:21 PM
    #43
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    I buy M1 5w-30 at costco and oem filters.
    JeffreyB and buzzkill911 like this.
  4. Jun 16, 2017 at 9:01 PM
    #44
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    Ditto.
  5. Jun 20, 2017 at 3:15 PM
    #45
    CroTaco
    CroTaco Well-Known Member
    Tulsa OK
    2007 White Tacoma PreRunner TRD package
    3 inch lift.
    Funny you say it'll cause leaks wheN in turn one of the reasons it's designed for is to stop small leaks.
  6. Jun 21, 2017 at 7:19 AM
    #46
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I added a bolt once...
  7. Jun 21, 2017 at 7:33 AM
    #47
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Those of you using 5W-30, what does your engine call for? The 2.7L 2TRFE has called for 5w-30, 5W-20, and 0W-20 all in the same generation. I run 0W-20 since thats what the cap says but should I be running something else?
  8. Jun 21, 2017 at 7:36 AM
    #48
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Also interested in some info about this question. Is it the VVTI? Or is it some crap for CAFE standards? If it is the latter I would be inclined to switch grades once my warranty is up.
  9. Jun 21, 2017 at 7:51 AM
    #49
    TacomaZL
    Illinois
    Personally I run 0W-20, but as my engine gets older I may run 5w-20...it still has the same operating temperature as what I run but still a bit thicker. That being said in Chicago where I live we have had -25F days during the winter....those are the days I'm glad I'm running a 0W-20.
    KyYote58 likes this.
  10. Jun 21, 2017 at 7:51 AM
    #50
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    I run Mobil 1 5w30 and Wix filters. I have used that combo for years on all my vehicles with no issues, so I will stick with what works for me.
    As for leaking after switching at a high mileage, I bought a Ram 5.7 with 187,000 miles on it. The previous owner had run Quaker State dino oil since new. I switched to M1 high mileage at 189,000 with no leaks and no issues. It had 207,000 when I traded it in on my Tacoma.
  11. Jun 21, 2017 at 7:59 AM
    #51
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    RedLantern likes this.
  12. Jun 21, 2017 at 8:02 AM
    #52
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
  13. Jun 21, 2017 at 8:04 AM
    #53
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  14. Jun 21, 2017 at 8:09 AM
    #54
    Indy
    Indy Master of all I survey.
    I think its funny that people treat amsoil like its some protected class. How do you start a joke about amsoil? (Glances over both shoulders...) :laugh:
  15. Jun 21, 2017 at 8:10 AM
    #55
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Amsoil + OEM Filter.
  16. Jun 21, 2017 at 8:25 AM
    #56
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Have been running Amsoil signature series and their EA oil filters for a decade in my truck. I use regular analysis to monitor wear and oil life. Have settled into an 18 month change interval ~ 4-8k miles. (Not my daily driver)
    Use the same stuff in my wife's car and hers goes 18k miles ~12 months per change.
    Wear elements have always been well below universal averages in both motors despite the long time/distance runs. Amsoil was the first company to bring API synthetic automotive oils to market and I will never use anything else.
    TacomaMike37 likes this.
  17. Jun 21, 2017 at 8:29 AM
    #57
    outlawtacoma
    W. TN
    2018 T4RTRDOR
  18. Jun 21, 2017 at 8:36 AM
    #58
    dustin19d
    Dustin
    Washington
    That sounds like a kick-ass job!
  19. Jun 21, 2017 at 8:52 AM
    #59
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    In the study, AAA found that "synthetic engine oils performed an average of 47 percent better than conventional oils in a variety of industry-standard tests,” the organization's managing director of Automotive Engineering and Repair, John Nielsen, said in a statement.
    “With its superior resistance to deterioration, AAA’s findings indicate that synthetic oil is particularly beneficial to newer vehicles with turbo-charged engines and for vehicles that frequently drive in stop-and-go traffic, tow heavy loads or operate in extreme hot or cold conditions.”
    But you aren't going to put yourself in the poorhouse if you flip for the synthetic, either: these oils add an average of only $64 per year to vehicle operation costs, a bit less than twice as much as conventional oil.
  20. Jun 21, 2017 at 10:20 AM
    #60
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Don't get me wrong Amsoil is good. Used to use it myself in my 3.4L. I have to laugh when people say it's the holy grail of oils.
    14TACO4X4 and Hoff like this.
