Synthetic Oil in 99' Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thedoobster, Oct 1, 2022.
  1. Oct 1, 2022 at 4:57 PM
    Thedoobster
    Thedoobster [OP] Well-Known Member
    Brandon
    California
    1999 Tacoma SR5 3.4L 4x4
    3" Lift, 1.5" Wheel Spacers, 285/75r16 Tires
    I've had my Tacoma a little over a year now and have been slowly bringing everything up to date and replacing what needs to be replaced. It's a 99' Tacoma with a 3.4L that has 370k miles on it, I've been thing of switching from dino oil to synthetic but I've heard people warn about switching on older high mileage engines. What are some opinions on this topic? The truck already has an oil leak, would it make it worse?
  2. Oct 1, 2022 at 7:07 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I can't comment on if it would make it worse or not but let me ask you this, do you intend on changing your oil every 3k or so? If you intend on consistent oil changes and maintenance, why not just leave well enough alone?
    5W30
    Cloud99, 808BOGEYMAN and Wulf like this.
  3. Oct 1, 2022 at 7:36 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  4. Oct 1, 2022 at 7:43 PM
    5efvz
    5efvz Well-Known Member
    I use whatever's on sale.
  5. Oct 1, 2022 at 8:05 PM
    O'Silver_Taco
    MD
    depends on your leak......
    ......gasket leak could be accelerated if switch to different oil with different detergents.....
    IF its a seal leak....thats what high milage oils and tranny fluids are for....
    they have a hail marry bail out move.....stop leak additive.........plump the seal to slow leak and make it last a little longer....
    ......but at the demise of the seal.....everntually.....
    Oil doesnt mean jack.....changing it.....often, is what matters the most.....
    detergent oil means all the crap is in suspension.....going thru engine over and over.....
    Cheapest on the planet I've found......napa syn blend for $12.99 5qt....on their monthly ad slick......
    Also on their platinum filters, if you catch on that 20off sale.....you can get these as good as the K&N racing ones, for about half the price.....
    Hamer95USA likes this.
  6. Oct 1, 2022 at 8:18 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    That's cheap. I had no intentions of changing to synthetic but Mobil 1 is so cheap now (especially using a factory rebate/refund/whatever) why not? I had already done valve covers and front seals. They needed changing before.
    Jeez valve covers and the like used to be bi-annual things when I was young. Even on imports.
  7. Oct 1, 2022 at 8:27 PM
    O'Silver_Taco
    MD
    Think only big payoff to highend oil is if you have a newer much more expensive engine....
    VVT, turbos, direct injection, then for sure pony up for top tier......
    most only come that way now.....
  8. Oct 2, 2022 at 5:17 AM
    mte
    mte Well-Known Member
    1999 Tacoma v6
    I, too, have a '99 3.4...automatic. 276,000. Runs like a scalded dog. Switched to full synthetic 2 years ago. I do my own oil changes and have observed that the used oil is remarkably cleaner than what the conventional used to be. Plus, with newer synthetics, I go lots longer between changes...just sayin'
    Hamer95USA and TacomaJunkie8691 like this.
  9. Oct 2, 2022 at 11:47 AM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    I would use dino oil with that many miles. Somebody took care of it with reg oil for years. I have heard too many stories of leaks after. If your a Toyota freak you will change it all the time anyway
    TWJLee and Area51Runner like this.
  10. Oct 2, 2022 at 11:48 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    That a lot of miles so first of all congrats are in order!!!
    Synthetic will be more likely to leak, yes. I'd stick to conventional 5W30 and keep doing regular OCI.
    Area51Runner likes this.
  11. Oct 3, 2022 at 1:30 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    We have a 1999 Toyota Tacoma, and we run Castrol full synthetic 5w-30, and we don't have any leaks, but we changed to full synthetic before it went over the 100,000 mile mark.
  12. Oct 3, 2022 at 1:42 PM
    O'Silver_Taco
    MD
    Synthetic is not magic.....neither oil will fail in modern formulations.....
    its the trash that builds up....dont matter which.....you could have glow in dark oil...still the same...
    So some oil gives you a free pass.....whats really happening is your space age oil....
    is efficent at transporting trash round and round in your engine ......for a much longer period....
    thats crazy.......
    You could try that with the toilets in your house......save some water......
    and keep visitors away.....
  13. Oct 3, 2022 at 1:48 PM
    O'Silver_Taco
    MD
    I would be more concerned about cold startups......
    I add almost half a bottle of lucas for that.......makes the oil 'Tenacious'......
  14. Oct 3, 2022 at 2:07 PM
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    Only reason a synthetic oil would cause a leak is if the seals are only holding because of guck and grime.
  15. Oct 3, 2022 at 2:08 PM
    Itsgottabeyourbull
    Tulsa Oklahoma
    If oil changes have been performed regularly and according to OEM specification you’ll have no issues
  16. Oct 3, 2022 at 2:09 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    yeah the leaking will leak more but fwiw my taco has 250k and all i put is synthetic mobil1 high mileage amd oem filter and washer
  17. Oct 3, 2022 at 3:11 PM
    Potomus Pete
    Hippy
    My 99 Prerunner has had Castrol Syntec black bottle for 250K miles. The inside of the motor is like brand new. I like it because now that it's getting old I can really run a long time between changes. I still would never change over to Synthetic with high mileage
  18. Oct 3, 2022 at 3:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    No earthly idea what was run in mine for its first 180,000, but it gets synthetic now. No leaks.
    You might consider switching to a high mileage oil, the only thing they're really better at is swelling seals.
    Do you know whats leaking? It might be a simple fix.
    MalinoisDad likes this.
  19. Oct 3, 2022 at 3:31 PM
    O'Silver_Taco
    MD
    Man oil is cheap.....magnetic plug hangs on bottom of pan waiting to be reinstalled...
    Got it down couple min to drain.....couple to refill....
    Mines city stop and go....so it gets changed every 1200mi.....filter every 7.5K.....
    Helping cousins for last 60 years........I've seen some bad movies........
    Same thing for coolant.....religiously every 2 yrs.....and not the new stuff......real coolant...
  20. Oct 3, 2022 at 3:31 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    100% this. Determine what's leaking and fix it.
