Symptoms of rear end going bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by E30325, Dec 14, 2018.
  1. Dec 14, 2018 at 4:25 PM
    E30325
    E30325 [OP] Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    So I've had a squeaking sound coming from the rear end for a couple days now, changes frequency with wheel speed, it just sounds like something in a brake or a sticking brake to me so I wasn't concerned about it. I rotated my tires today and while I had it in the air I spun it over by hand trying to replicate the noise
    I couldn't get it to make the noise but heard another worse noise.
    Basically as I'm spinning it over by hand I'm hearing wayyyy more noise from the rear end then I should be, like you can hear all the teeth as they mesh but in a clunking sort of way. I took a video of it but don't have a way to upload it.
    Seems strange to me for a rear end to go bad at 180k, I don't baby it but I wouldn't say I abuse it either, its a 4.10 e locker diff, changed the fluid about a year ago
  2. Dec 14, 2018 at 4:28 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Squeaking? are you sure it's not a wheel bearing? u joint?
    FWIW there is some audible play in my rear diff with 230K miles on it but it's running fine
    Running Board Man and E30325[OP] like this.
  3. Dec 14, 2018 at 4:29 PM
    E30325
    Nick
    There is no play in either wheel to suggest a bearing, and it doesn't change in corners. Could be a U joint but they felt good. The squeaking isn't my main concern though, it's just clunking of the rear end as I hand spin it
  4. Dec 14, 2018 at 4:30 PM
    E30325
    Nick
    I have a vid but don't know how to upload it haha... technology wise I'm roughly 115 years old
    Boatbldr likes this.
  5. Dec 14, 2018 at 4:30 PM
    Wulf
    rock raisin
    Upload it to youtube, then click the movie/film icon in the post editor and paste the youtube url there
    E30325[QUOTED][OP] likes this.
  6. Dec 14, 2018 at 4:31 PM
    E30325
    Nick
    I'll have to make a YouTube acct, I'll upload it when I get a chance. At firestone right now seeing what they have to say haha
    Running Board Man likes this.
  7. Dec 14, 2018 at 4:32 PM
    E30325
    Nick
    I don't but I'll make one
  8. Dec 14, 2018 at 4:33 PM
    E30325
    Nick
    Hahahah I know how you feel about firestone, my local one isn't bad tho and it's free
  9. Dec 14, 2018 at 4:34 PM
    E30325
    Nick
    Wanna PM me your email? It won't let me upload the link into a PM
  10. Dec 14, 2018 at 4:35 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    My driveline, with ~130k miles has some play in it too. I'm now worried about that.
    For the squeak, you could remove your rear driveshaft, then drive around in "front wheel drive". If the noise goes away, then it's a U-joint. If it's still there, could be an axle bearing.
  11. Dec 14, 2018 at 4:36 PM
    E30325
    Nick
    I had it in the air, you don't hear anything driving which seems really weird to me. The vid I got is just spinning it by hand when it's in the air
  12. Dec 14, 2018 at 4:37 PM
    E30325
    Nick
    Good point, I greased the zerk while I was under there but it didn't make a difference. My next plan was change the fluid and look for metal, then I could pull the driveline if that doesn't tell me anything
  13. Dec 14, 2018 at 4:43 PM
    E30325
    Nick
    Of course, it won't let me attach the vid because it's over the 5mb limit.
    No the carrier bearing looks good and the sound is for sure from the axle/rear end
  14. Dec 14, 2018 at 5:08 PM
    E30325
    Nick
    I thought all the u joints looked good and they agreed with me, said wheel bearings are fine too and brakes look good. He recommended a local drive train shop to me
  15. Dec 14, 2018 at 5:44 PM
    E30325
    Nick
    Update, drove home from firestone, squeak is gone, so it must have just been something in my drum that came out when they looked at them
    mynewtoy and Running Board Man like this.
  16. Dec 14, 2018 at 5:44 PM
    Wulf
    rock raisin
    :bananadance::bananadance::bananadance::bananadance::bananadance:
  17. Dec 14, 2018 at 5:57 PM
    E30325
    Nick
    Yeah but that still means my rear end is probably cheesed. Draining it tomorrow
  18. Dec 15, 2018 at 10:24 AM
    E30325
    Nick
    So just jacked it up again with it cold, had my buddy (who is way smarter then me) listen to it, each of us spun a tire the same direction and noise goes away, so he said it's gonna be bad spider gears, makes noise when you spin one, or when you spin opposite directions, but tires going the same direction and it's quiet
    Running Board Man and Wulf like this.
  19. Dec 15, 2018 at 5:45 PM
    E30325
    Nick
    Drained it today, metal chunks on the magnet on the drain plug, so spider gears are fucked. But it makes no noise or vibration driving, so they can't be that bad yet. I have no idea what I did, I'm not even that hard on it at all. I wheel it IMO lightly, dont to burnouts, never even spin a tire unless it's wet out. So who knows.
    I guess I'm just badass enough to blow a Tacoma rear end on 33's :anonymous:
  20. Dec 15, 2018 at 5:46 PM
    E30325
    Nick
    @Sperrunner you still have that 4.10 e locker 3rd?
