Swollen (lug) nuts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tall_paul, Oct 8, 2024.
  1. Oct 8, 2024 at 5:01 AM
    tall_paul
    tall_paul [OP] Well-Known Member
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    I’ve seen some people on here recommending the gorilla lug nuts to replace what came on the truck. At 130k miles I think they need to go before they really get stuck, from swelling.
    Would these work? Figured I’d ask the experts before ordering them. It seems like the mag style is what Toyota uses, so I want to make sure I’m not ordering the wrong thing.
    https://www.amazon.com/dp/B00SF8FF86
    other product recs would be appreciated if I’m on the wrong track.
    I have the stock off road wheels on my truck.
  2. Oct 8, 2024 at 5:40 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Those won't work with OEM wheels.
    They're ET lugs designed for some aftermarket wheel applications.
    You need OEM mag style lugs. Gorilla does make them.
    GearHead899 likes this.
  3. Oct 8, 2024 at 5:53 AM
    jmneill
    SE
  4. Oct 8, 2024 at 5:55 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wouldn’t go with Gorilla, I would (and did) go with the OEM 1-piece lugs from Japan. They are exactly like the stock lugs, except they won’t swell up.
    90942-01033
    SR-71A likes this.
  5. Oct 8, 2024 at 5:59 AM
    jmneill
    SE
    I'm not impressed with my Gorilla lugs.
    Replacing OEM with Gorilla is a downgrade.
    BLtheP[QUOTED] likes this.
  6. Oct 8, 2024 at 6:08 AM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    I have the aftermarket Gorilla lug nuts with 90,000 on them and no issues. My buddies 18 TRD had the factory lug nuts swell at 85,000. I think whatever you chose it will be a wearable part and need periodic inspection, just like the lugs themselves.
    sparkystaco likes this.
  7. Oct 8, 2024 at 6:14 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
  8. Oct 8, 2024 at 6:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Don't overthink it. Discount Tire replaced mine with whatever they have in stock. Lug nuts aren't rocket science. Just avoid the factory junk with sheet metal stampings over them. I don't understand why any of the manufacturers don't just put solid nuts on all vehicles.
  9. Oct 8, 2024 at 6:47 AM
    tall_paul
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    I am coming up with this part number as fitting. 9008494002
    https://parts.lakelandtoyota.com/p/TOYOTA_2016_TACOMA-TRD-Off-Road-Extended-Cab-Pickup-Fleetside-35L-MT-4WD/Wheel-Lug-Nut/4208317/9008494002.html
    This link is saying the 90942-01033 doesn’t go with the 2016 off road. Not sure what the difference is, they both look the same, just two different sites and part numbers.
    https://parts.longotoyota.com/oem-parts/toyota-lug-nuts-alloy-wheels-9094201033
    any ideas?
  10. Oct 8, 2024 at 6:52 AM
    BLtheP
    Plano, TX
    Yeah, not surprised there. Haven’t seen them in the Tacoma sizes but on Jeeps, they are pretty junky. Lots of rust issues quickly. I’m happy with an OEM 1 piece solution.
    jmneill[QUOTED] likes this.
  11. Oct 8, 2024 at 6:54 AM
    BLtheP
    Plano, TX
    The vehicles made in Japan with our lug size (4R, FJ, some Lexuses) come with the 1 piece option I listed. What you listed is the same stock capped style you already are having trouble with.
    the ones I listed don’t “fit” because they aren’t original, but they fit. The part number I listed is what I bought.
  12. Oct 8, 2024 at 6:57 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    The only aftermarket lugs I've been impressed with are McGard. Gorilla and all the others have rusted if they were chrome or flaked if they were black ones.
    RIX TUX likes this.
  13. Oct 8, 2024 at 6:57 AM
    Taco130J
    Taco130J Member
    San Diego
    2019 SR5 DCSB
    Fox 2.5s, DK UCA, KMC Impact OL, MT Baja Boss A/T
    Echo all above. The gorillas are overpriced and mine have not held up well.
    tall_paul[OP] likes this.
  14. Oct 8, 2024 at 7:10 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    I was really hoping for some good comments in here with that thread title, but no, ya'll have let me down.
  15. Oct 8, 2024 at 7:36 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Because, they don't have, solid Nuts?
    :rofl::oops:
    To the rescue! @guaco.supreme !
    guaco.supreme likes this.
  16. Oct 8, 2024 at 8:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Can we get a Title Edit? Swollen Nuts would be pretty fun.
  17. Oct 8, 2024 at 8:13 AM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Both of the work trucks the company uses in my area (including mine) have ended up needing replacement lug nuts as the OEM ones wore out, one at 185K and the other at 230K. New ones are one-piece design that the tire shop I go to says they specifically use because they don't have the issues the two-piece lug nuts do.
  18. Oct 8, 2024 at 9:49 AM
    PNWtacoma11
    PNWtacoma11 Member
  19. Oct 8, 2024 at 3:55 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  20. Oct 8, 2024 at 4:00 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I ordered Dorman 611-167 M12 1.50, IMG_9357.jpg 21mm replacements for my 2017 from Amazon. I have FJ Cruiser rims, assuming factory replacement.
