Switched from 5W-30 to 0W-30 100% Full Synthetic Oil
Discussion in 'Technical Chat' started by Rambo MARINE Recon, Jun 3, 2016.
  1. Jun 3, 2016 at 5:22 PM
    Rambo MARINE Recon
    Rambo MARINE Recon [OP] Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    I switched from the 5W-30 to 0W-30 Fully Synthetic AMSOIL Signature Series Engine Oil. I checked with AMSOIL,MOBIL1,Castrol,and a few others with all Synthetics ONLY!!! Better and quicker start ups, higher lubrication protection for the new tighter tolerances on all newer models engines for past 2-3 decades! I run 5 QTS of AMSOIL Signature Series 0W-30 Fully Synthetic Oil,I run a K&N or a MOBIL1 Oil Filters, I add 1/2 a QT. of TufOil Engine Oil Treatment, and results are quieter and smoother engine and throttle response,better fuel economy, LONGER ENGINE LIFE and much less wear and tear. Did mine at 60,000 miles this week! Runs as good as new still! Hoping to get up to 1,000,000 miles or more in life!change every 5,000-7,500 miles since new! I own a 2013 Toyota Tacoma SR5 PreRunner DCLB V6 4.0 and A/T with Tow Pkg. Changed all Oils ,Fluids and lubricants to AMSOIL at new at 500 milles and change and flush all fluids every 30,000 miles,did at 500,then 35,000,then now 60,000 miles !Tune up with new NGK Irridium Plugs,New serpentine Belt,New front Brake pads .
    pdxyota likes this.
  2. Jun 3, 2016 at 5:41 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Well....giddy-up.
    OneWheelPeel, Sig45, koditten and 2 others like this.
  3. Jun 30, 2018 at 7:49 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Amsoil = Scamsoil! Seriously that stuff is a huge waste of money and won’t protect your engine any better than Mobil 1 which can be had for half the price. I run Mobil 1 advanced fuel economy 0W-30 and it’s performance is better than Amsoil by far! Yes I used Amsoil once so I speak from experience, it’s a waste of money! Especially when Mobil 1 can be had at Walmart for $22 a 5 quart jug plus an additional quart for $6 makes for a $28 oil change rather than a $60 change with Scamsoil!
  4. Jun 30, 2018 at 7:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sorry, not impressed.
    wake100, sparkystaco and Wyoming09 like this.
  5. Jul 1, 2018 at 7:49 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Love these oil threads. A lot of uninformed opinions by uninformed people. Most of the expertise comes from blurbs on the internet or hearsay. How many here have ever had an engine fail because of the brand of oil they used? I surmise the answer is between zero and none. Modern oils are phenomenal lubricants. As long as you do regular maintenance and oil changes doubt you’ll ever have a problem due to the brand of oil. We all have our favorite oils but as far as internal engine longevity I doubt it makes any difference which brand you use. Now if we have an automotive petroleum chemist out there we might get some credible information.
    Anyway back to the original post, a new serpentine belt and brake pads at 60000 miles? Both of those should last longer than 60000 miles.
  6. Jul 8, 2018 at 10:41 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I use Shell Rotella T6 0W-40. Change every 2000 miles. I haven’t noticed any differences.
  7. Jul 8, 2018 at 10:50 PM
    Bishop84
    Bishop84 Well-Known Member
    Is this an advertisement?
  8. Jul 10, 2018 at 12:46 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    seems so. 110k on a 2013 and original belt, original rotors. im anal and im wondering what the point in 1/2 of this is
  9. Jul 10, 2018 at 1:43 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Better & quicker startups because of oil? Hmm interesting. :rofl:
    pdxyota likes this.
  10. Jul 10, 2018 at 1:44 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Next....
    Plain Jane Taco likes this.
  11. Jul 11, 2018 at 3:59 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Haven't hear TufOil mentioned in years. That stuff was the cat's pajamas back in the day... one of the few "slick" additives that didn't lose their hiney over false promises.
  12. Jul 11, 2018 at 4:13 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    There was a bunch, Slick50, Prolong, & the one that came in lab beaker shaped bottles, I think Zmax was the name. Heck some people even swore adding Marvel Mystery Oil did something. Don't know if any of that stuff actually did anything but I've always stayed away from oil & fuel additives.
    pdxyota and koditten like this.
  13. Jul 12, 2018 at 8:39 PM
    2004TacomaSR5
    Jon
    Montana
    There is a difference, but you only really notice it in extreme cold conditions. 0W will deliver the easiest startups over 5W or 10W weights in all temperatures, though. Oil will get to critical parts quicker as well which is not a bad thing! I use 0W-30 in my 3.4 because -30 degree weather isn't unheard of in Montana during winter and my truck sits outside year round and doesn't have a block heater to help it along. Mobil 1 0W-30 has a cold pour point of -58 degrees fahrenheit meaning it stays fluid and pump able down to that temperature without turing to gel. If it ever gets any colder than that, I'll just stay home and not even go outside! Lol
    Sorry to sound nerdy, but I've learned a lot of valuable information on oil from the Bob is the Oil Guy forum. A lot of knowledgable folk over there on the subject of oil and filters.
  14. Jul 12, 2018 at 8:44 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I've read about many tests and even on newer motors heavier weights always protect better. If I remember right the lighter weights give better gas mileage, start ups, ect but breaks down at lower temp so if you over heat from a cooling failure the chance of motor damage is significantly higher .
  15. Jul 12, 2018 at 8:58 PM
    2004TacomaSR5
    Jon
    Montana
    Completely untrue. There's not much any oil can do to help if your engine overheats regardless of weight. Plenty of used oil analysis's out there that say lighter weights protect just as good if not better than heavier grades. Otherwise if there was a problem, Toyota, Ford, and Honda wouldn't be using 5W and 0W-20 in all their flagship products. GM, Hyundai and Kia are headed that way as well. Toyota is even going to start using 0W-16 in hybrid vehicles and Honda is headed the same direction with their lineup. The good thing about 0W oils is they are all full synthetic, and synthetic protects better across the board better than regular oil in all temperatures. The 0W is just the cold (meaning winter) viscosity, so for instance a 0W-30 has the same high temperature operating viscosity of 30 as 5W or 10W-30. I don't know why the oil companies make this so hard to understand but it's quite inconvenient to say the least!
