Switch Blank for AUX/SUB hole
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unchained 5150, Aug 2, 2021.
  1. Aug 2, 2021 at 2:36 PM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Anyone know who make a switch blank for the pictured spot? I moved the AUX/USB behind the Climate Control section and ran a usb to the glove box for carplay. So I would like to fill the hole in.
  2. Aug 3, 2021 at 2:45 AM
    Unchained 5150
    Rick
    Auburn Ma
    Wow nobody??? @MESO do you know where or what switch blank I would need for the open spot?
  3. Aug 3, 2021 at 2:54 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
  4. Aug 3, 2021 at 2:58 AM
    Unchained 5150
    Rick
    Auburn Ma
    Nope it's an odd size.
  5. Aug 3, 2021 at 4:09 AM
    littlefish
    Hudson Valley NY
    Oh dang ok I see it now.
  6. Aug 3, 2021 at 4:21 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Rick.....likely not what you want to hear, but what about your local Toyota dealer???
  7. Aug 3, 2021 at 4:29 AM
    Unchained 5150
    Rick
    Auburn Ma
    Might be what I have to do Pops, hope all is well.
  8. Aug 3, 2021 at 4:30 AM
    Unchained 5150
    Rick
    Auburn Ma
    I might just buy a new oem switch that doesn't connect to anything but fills the hole at least.
  9. Aug 3, 2021 at 4:34 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    I've thought about doing the same thing because I use a mini USB flash drive plugged into that port and the it's door won't close all the way. It's too hot out to do it right now but my plan is to leave that port operational in the dash and piggy-back another to the armrest box for my flash drive. That should work as long as I only use one port at the time.
    I have not explored what wire connector that port uses yet (too hot & I'm lazy) and build a "Y" cable to run to the console box.
    Unchained 5150[OP] likes this.
  10. Aug 3, 2021 at 4:41 AM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Would it be cheaper to put the OEM usb port/switch back, and just get a new radio-> usb cable off alibaba for $10 bucks to route wherever you want? Thats what I did and just left the OEM switch in the dash (not functional) and routed the new usb cable into my center console. I bet that USB Port costs more than it should since its probably specific to Toyota and not a frequently purchased part.
  11. Aug 3, 2021 at 4:43 AM
    Unchained 5150
    Rick
    Auburn Ma
    That's what I said I will probably just buy a new OEM switch to put in the blank, but not have it function
  12. Aug 3, 2021 at 4:46 AM
    chstaco
    SC
    2020 Tacoma
    Yea I meant put the one you took out back, and just buy a new cable, vs having to buy the new switch. Just a thought, no worries!
  13. Aug 3, 2021 at 6:24 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I’ve never seen a blank that fits in that smaller usb slot.
  14. Aug 3, 2021 at 6:25 AM
    Unchained 5150
    Rick
    Auburn Ma
    Thank you sir
  15. Aug 3, 2021 at 6:30 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Yours do. I did it.
  16. Aug 3, 2021 at 6:31 AM
    MESO
    State of Jefferson
    The original “small” usb slots, yes. The new airplay usb(as in OP’s) is smaller and more square.
  17. Aug 3, 2021 at 6:31 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    My bad
  18. Aug 3, 2021 at 6:32 AM
    Unchained 5150
    Rick
    Auburn Ma
  19. Aug 3, 2021 at 7:10 AM
    shiftd
    shiftd Well-Known Member
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    If you are up for buying a few cables you could retain the USB in that slot and make it charge only using this cable by running it to a power source.
    https://www.tacomaworld.com/threads/2020-tacoma-media-port-relocation.648547/page-3#post-25897126
    Then from the back of the head unit run this cable to the cable you've got routed to the glove box.
    https://m.aliexpress.com/item/40009...tedetail&spm=a2g0s.9042311.0.0.5c114c4dAYqGYO
    I'm a few steps behind you in a similar project. I've got the cables but haven't installed just yet. Plan on doing this, relocating the data to the center console or glove box and leave the port on the dash to just charge. Might even wire up a switch so I can flip between two USB sources if I can get that working which seems possible.
    These are for 2020 and up, I can't say that they'll be good for 2019 or older. But you mentioned carplay so I assumed
  20. Aug 3, 2021 at 7:12 AM
    Unchained 5150
    Rick
    Auburn Ma
    That's a lot of work it seems.
