Swing Away Tire Carriers for 2nd Gen Tacomas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoyoteRuns, Jun 19, 2017.
  1. Jun 19, 2017 at 5:13 PM
    CoyoteRuns
    CoyoteRuns [OP] Well-Known Member
    Ben
    2012 TRD Sport Supercharged 4x4 Access Cab
    Hello Gents,
    This is my running list of swing away tire carries for 2nd gen Tacomas. I've been shopping for tire carriers and high clearance wrap around rear bumpers and found a bunch of great of choices. I've been taking notes to help with my choice, and figured I'd post my notes for anyone looking. Most offer these standard features: single or dual Jerry can holders, mounts for hi-lift and shovel, and drop down camp table. A few offer special extras: lock in the open position, antenna mounts, backup camera relocation. And considering most of these come from custom fabrication shops I'm sure you can request custom fab.
    A few of my 'nice to haves':
    A shop relatively close in case I want to drive out and have them help with the install. Also, made in America! And save on shipping.
    Carrier/gear relatively easy to remove for when I'm not overlanding. I have premium AAA, so I don't need to lug all this stuff on my daily commute. Leaving the tire on is fine, but I don't need the rest of the kit.
    Ability to customize, I have ideas.
    Not too heavy, it needs to carry a tire, not stop a tank. Some people see a glass half full, others half empty, but an engineer sees the glass was built larger than was needed.
    Did I miss any great tire carriers? What do you guys think?
    PelfreyBilt
    Lemon Grove, CA 91945
    http://www.pelfreybilt.com/product/05-15-tacoma-rear-hi-clearance-bumper-with-gate/
    https://www.tacomaworld.com/threads/pelfreybilt-hi-clearance-rear-bumpers.265631/
    Highly regarded brand on TacomaWorld. Hinge looks well engineered. This is my favorite style of latch handle. Looks like it could stop a tank.
    Weight: 140 lb bumper, 50 lb carrier.
    CBI Offroad
    Idaho
    http://www.cbioffroadfab.com/produc.../bushmaster-2-0-base-swing-away-tire-carrier/
    Great looking carrier, tire is angled in a little, that is a pretty cool look. Additional options: locks open, telescoping light over camp table. The carrier is a little shorter, with the tire closer to the hinge, add-ons go on stamped steel. This looks like a much simpler and lighter option than the ones that use solid chunks of steel.
    Weight: Bumper 105 lbs, Carrier ?
    Relentless Fabrication
    Sparks, NV 89431
    https://www.relentlessfabrication.c...umper-tire-carrier-add-on?variant=18180172164
    Seems to be one of the most cost effective. Doesn't look overbuilt, ie, not a ton of extra metal. It has more stamped steel and the right amount of tubing. What's going on with that latch?
    Weigtht: 125 lbs
    Wilco Offroad
    Santa Ana, CA
    Wilco has a few interesting options.
    Veritcal mount: https://www.wilcooffroad.com/shop/tiregate-vertical-mount-toyota/
    Swing out tail gate replacement/conversion. I'd ask for solid back plate so it holds rocks/mulch. This replaces the tail gate, that's a weight savings, but you can't carry loose loads and it probably won't work with a camper shell. I like that it has 4 contact points, but don't like that I have to pull two handles to open it. Doesn't have some of the features the other guys have, such as a camp table, and there's no tail gate to act as a table.
    Horizontal mount: https://www.wilcooffroad.com/shop/tiregate-racerunner-toyota/ Doesn't meet my personal needs, but if you're racing this is probably a cool solution.
    The Hitchgate: https://www.wilcooffroad.com/shop/hitchgate-tire-carrier-toyota/ Personally I would never use this. I would think my truck would wag it right off and my gas, tire, and hi-lift would be lost on the trail. It just seems like the side to side torsion would torque it right off if you have enough weight on it. It's cute when you say, "my truck wagged his tail off" when you lose an antenna, but not great when you lose your recovery gear. However, if you want a removable and configurable system this could be a great way to go. Imagine, you can put it on your truck, your wife's car, and lend it to a friend.
    4xInnovations
    Platteville, WI
    http://www.4xinnovations.com/2005--2013-Tacoma-Rear-High-Clearance-Wraparound-Bumper_p_37.html
    These guys have the handle style I like. One of their bumpers has a dual swing out, check it. Their wrap around bumper doesn't have the hidden hitch behind a flip up license plate that some of the other guys have. They have some great add-on options, such as propane tank mount.
    All Pro Offroad
    Victor, MT The tube frame of the dual swing out is the best engineering I've seen. The total package is shorter when open. The changeable accessory holders is a good idea. Their wrap around bumper does not require cutting the body of the truck, but also isn't as high-clearance as the others. I guess that's good if you don't want to cut your truck. I think this is my favorite swing out design but maybe my least favorite bumper. They do have aluminum options.
    BAMF - Bay Area Metal Fabricators
    http://www.bayareametalfab.com/2005-2017-Tacoma-Skid-Trilogy-_p_71.html
    They promise 2nd gen bumpers in the future. They have an inexpensive Bed Rail CB Mount.
    Brute Force Fab
    http://www.bruteforcefab.com/high-clearance-rear-bumpers.html
    I saw someone here had their carrier, but their images don't currently load on their website, so I'll check back later.
    Mobtown Offroad
    https://mobtownoffroad.com/product/bumper-1/
    The bumpers look super solid. There's an option for wrap around and regular bumpers.
    Aluminess
    http://www.aluminess.com/toyota/toyota-tacoma-2005-2011/rear-bumper/
    Aluminess gets and honorable mention for having lockable boxes as an option, but they don't have a wrap around bumper, so it's not exactly what I was looking for. But the dual swing is pretty awesome!
    Badland Bumpers
    http://******************/racksystem.html
    Ravensdale, Washington
    They have a bunch of tube-based options.
    George3231, Kasbien, Tonka08 and 3 others like this.
  2. Jun 19, 2017 at 5:21 PM
    solarservant
    solarservant Beersquatch
    Zach
    Tucson, AZ
    ADS/ICON/Dobinson's equipped 2Gen prepped for international overland travel
    ADS front coilovers, ICON rears, Deaver Expedition Pack, CBI Bumpers, RCI skids, Avid sliders, Warn EVO 10S, on 33" Falken Wildpeak MTs, Vagabond Drifter camper & Goose Gear interior.
    Thanks for this. I'm shopping
  3. Jun 19, 2017 at 5:45 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
  4. Jun 20, 2017 at 5:50 PM
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    I made my own from buying the latch and hinge from FWInovations. I think Relentless has parts also.
  5. Jun 20, 2017 at 6:03 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have the Wilco Hitchgate Solo High Clearance and love it.
    BassAckwards likes this.
  6. Jun 20, 2017 at 6:05 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Aluminess
  7. Jul 9, 2017 at 9:50 AM
    wahoogully
    wahoogully Member
    Sacramento
    2015 tacoma DCSB
    Suspension, tires
    Thanks for sharing your research! After first big off-road trip I want some more mods and these are high on list.
  8. Jul 9, 2017 at 11:00 AM
    CoyoteRuns
    Ben
  9. Jul 10, 2017 at 3:29 PM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
  10. Jul 10, 2017 at 8:48 PM
    CoyoteRuns
    Ben
    Thanks Irish, I added them.
    irish_11 likes this.
  11. Jul 10, 2017 at 8:56 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Our latch has been updated, I'll be posting info on the update soon. All current orders are receiving the update.
    Also to note, our pivots are custom made for us to our spec and are double shear for extra strength and rigidity compared to most competitors shank-style single shear.
  12. Jul 11, 2017 at 8:31 AM
    CoyoteRuns
    Ben
    Awesome, looking forward to seeing it. Let me know when you have a new pic and I'll update the one at the top of the thread.
  13. Jul 11, 2017 at 9:22 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    mine was custom from a local fab, i would look at swingouts with double shear if you plan on having lots of weight on it.
    edit- also considered you cap (if you have one), if you have something angled you will want your tire to angle instead of sitting straight
    JesseB likes this.
  14. Jul 26, 2017 at 5:51 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
  15. Jul 27, 2017 at 5:01 PM
    CoyoteRuns
    Ben
    Pic added at top. Thanks!
    Drainbung and Blackout14 like this.
  16. Nov 26, 2018 at 9:53 PM
    George3231
    George3231 Member
    George
    2008 silver tacoma
    None
  17. Nov 26, 2018 at 9:54 PM
    George3231
    George3231 Member
    George
    2008 silver tacoma
    None
    The only swing away that I like is the body armor
  18. Nov 27, 2018 at 5:01 AM
    PSmith1970
    PSmith1970 Active Member
    2015 Tacoma DC 4x4
    gn2vxLnhQDzztBYT5X-d8WZzNmqV8_GSFMHdBX6g_5effec516746336da87f9f19fa321ced20f315b3.jpg
    I'll put in my plug for Slee Offroad from Golden, Colorado
    http://www.sleeoffroad.com/products/bumpers/rear_bumpers_05-15_tacoma.htm
    Great product and pretty standard installation. My biggest concern about the bumper-mounted spare was potential rattling, flexing, and vibration resulting from "spirited" off road driving. After a weekend in Baja, I can safely say that this is a solid, movement-free bumper. Their bumper allowed me to keep my rated hitch and came with a bracket to relocate the backup camera, the Rotopax mount and a Hi-Lift mount. As a bonus, the anodized spindle cover is a work of art!
    NmapFE likes this.
  19. Nov 27, 2018 at 5:04 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
  20. Nov 29, 2018 at 3:45 AM
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    Like this
