Sway bar with lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 17, 2018.
  1. Nov 17, 2018 at 6:50 AM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Hey guys, installing a lift today? Leave sway bar in or no?
  2. Nov 17, 2018 at 6:59 AM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    Opinions vary. I recommend trying it with and without and see which you prefer. It really depends on how much off road vs on road etc you do.
  3. Nov 17, 2018 at 7:01 AM
    TacoRated
    Colorado
    2016 DCSB TRD OR
    Do you have a relocation bracket for it? If not, then you’ll most likely be removing the sway bar today.
  4. Nov 17, 2018 at 7:31 AM
    ejewels
    CT
    I don’t. Can I install just keeping the sway in as stock? I’m installing 6112s and JBA UCAs.
  5. Nov 17, 2018 at 7:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pavement princess or frequent off roader? (more than dirt/gravel trails)
    Pavement = on, off road = off
  6. Nov 17, 2018 at 7:37 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @ejewels I have a sway bar relocation kit if you need it in the future
  7. Nov 17, 2018 at 7:38 AM
    Breaky0self
    Breaky0self Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
    unless your offroading all the time, get the re-locator kit and leave it on
  8. Nov 17, 2018 at 7:43 AM
    TacoRated
    Colorado
    2016 DCSB TRD OR
    Only one way to find out. ;)
    This is not a show stopper for your lift. If it doesn’t work without the relocator and you want to keep using it, just remove the sway bar and get a kit and reinstall it later. It’s not a major job.
  9. Nov 17, 2018 at 7:46 AM
    ejewels
    CT
    Yeah installer is saying we’ll know once put on. Said it might rub the CV. What do most do on here? It’s a DD and only mild off road so kinda want to keep it
  10. Nov 17, 2018 at 7:49 AM
    TacoRated
    Colorado
    2016 DCSB TRD OR
    I have mine on for now... we’ll see if I keep it or not.
  11. Nov 17, 2018 at 7:50 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Who makes a relocation kit?
  12. Nov 17, 2018 at 7:50 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
  13. Nov 17, 2018 at 7:51 AM
    Rujack
    Don’t think you can do that on these trucks. It’ll tear up the cv boots iirc
  14. Nov 17, 2018 at 7:52 AM
    TacoRated
    Colorado
    2016 DCSB TRD OR
    Lots do. It’s really just a small spacer that moves the sway bar forward about 1/4 of an inch.
    Try @HeadStrong Off-Road
    Rujack[QUOTED] likes this.
  15. Nov 17, 2018 at 8:00 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    You can't leave it hanging like a Jeep but if you have an aftermarket skid plate instead of the factory splash guard masquerading as a skid plate you can slide the sway bar right out after removing the two end links and 4 bolts for the brackets. Carry a battery powered impact and it becomes a 1 minute job.
    TacoRated and seadog99 like this.
  16. Nov 17, 2018 at 8:01 AM
    medic2230
    Murph
    Bama! Roll Tide
    More important would be what springs are you running with the lift as far as if you want to remove the sway bar.
    drewhaus likes this.
  17. Nov 17, 2018 at 8:09 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I was thinking you could rotate it up and out of the way and tie it off, but I just looked and it doesn't look like it would clear everything to do that.
  18. Nov 17, 2018 at 8:09 AM
    ejewels
    CT
    6112s at the 5/6 notches
  19. Nov 17, 2018 at 8:11 AM
    medic2230
    Murph
    Bama! Roll Tide
    So using the Toyota stock springs with those shocks?
  20. Nov 17, 2018 at 8:12 AM
    ejewels
    CT
    New truck so mostly pavement and mild trails
