Sway bar removal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RiceBurrito, Aug 22, 2017.
  1. Aug 22, 2017 at 10:54 AM
    RiceBurrito
    RiceBurrito [OP] Member
    04 silver Tacoma 4x4 5 speed 2.7l
    I am going to be installing icons tonite or tmrw morning. Was wondering if I should remove my sway bar. Any thoughts? It's my daily driver but is also my hunting rig and I offroad pretty often.
  2. Aug 22, 2017 at 11:14 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Quite a few people have done it. Some say they don't notice a difference on road while others say it wanders at hwy speeds. Either way you get more flex i your suspension. I think it really depends on your style of driving.
  3. Aug 22, 2017 at 11:27 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    Some people will say a reason to leave it on is more control during evasive maneuvers. I'm not entirely sold on that point.
    I've heard it's easy enough to disconnect that you can before getting on the trail, or whatever, and reconnect before getting back on the road. Haven't tested that theory yet.
  4. Aug 22, 2017 at 11:39 AM
    kap1425
    kap1425 Well-Known Member
    Kevin
    Tejas
    2017 TRD OR DCLB Magnetic Grey
    Bilstein 6112/5160 Total Chaos UCA's Cali Raised Ditch Lights Katzkin Leather
    If it were me, I would leave it on for now. The sway bar will keep your cornering under control and help ease up your steering on turns. I am waiting for Currie Enterprises release an Antirock off road sway bar for the 3rd gens, then I won't have to worry about disconnecting to go wheeling.
  5. Aug 22, 2017 at 11:41 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I can still drive like a maniac with 600# springs and no swaybar and the body roll is very manageable.
    p_chinnici, SnowroxKT and Ritchie like this.
  6. Aug 22, 2017 at 3:16 PM
    2BeersPlease
    That was my thought (minus the 'drive like a maniac' part). My coils are 620# and I figured that would be enough to counter any body roll.
    Ritchie likes this.
  7. Aug 22, 2017 at 3:24 PM
    coopcooper
    alberta canada
    only times I've scared my self is bombing down washboard gravel roads at 60mph. start to get the speed wobbles haha.
  8. Aug 22, 2017 at 4:12 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    OP, rid of the sway bar. Hell, I'm on a 3 link SAS and don't have one. Wifey drives it to work everyday and no complaints.
    Good luck.
    jeff b likes this.
  9. Aug 22, 2017 at 4:13 PM
    RiceBurrito
    Thanks for your input guys. Sounds easy enough to remove it and put it back on so I'll try it with and without. I'll give an update.
    Ritchie and medic2230 like this.
  10. Aug 22, 2017 at 4:22 PM
    Madjik_Man
    Colorado Front Range
    FWIW
    I have an OME suspension all around.
    When I took the sway bar off for two weeks, read: the end links exploded and I was waiting on parts, it felt very unnerving to me driving on road, around curves, mountain passes, etc.
    After buttoning it all up it felt much safer on road.
    I've also noticed no limitations off road. While I'm not rock crawling up stuff that requires 40" tires and 5.29 gears, I have wheeled this truck on pretty tough stuff its whole life (with a sway bar).
    And if you really want to disconnect it prior to going on a trail, all you have to do is remove one end link bolt and tuck it up out of the way. Having only one end link connected is virtually the same as removing the sway bar entirely (if I understand the dynamics correctly)
    Just my $0.02
    15psd and skeezix like this.
  11. Aug 22, 2017 at 5:08 PM
    Ritchie
    Madjik,
    Cool build and rattle can techniques!
    Your truck would be awesome on 33's. Try wheelin' w/o the sway bar. Your truck would do well.
  12. Aug 23, 2017 at 7:57 AM
    Madjik_Man
    Thanks man.
    31s are good enough for me. Have never left me wanting more. If anything I'd upgrade to the stock 16" alloys and go with a 265/75r16 tire.
    Oh and I'd like the quiet stock exhaust too :)
  13. Aug 23, 2017 at 8:02 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I run disconnects. Best of both worlds. They are strong and wont break offroad. I can really feel the front end loosen up without the front bar when up in the mountains on the passes doing 50+mph. It can get downright dangerous and you must take some turns at a good amount lower speed than normal. If you have really stiff front coils then you wont even notice.
    15psd likes this.
  14. Aug 23, 2017 at 8:07 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    if you're old and scared of your shadow don't do it, if you got a big hang down... remove it.
    Ritchie likes this.
  15. Aug 23, 2017 at 8:07 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Haven't had a sway bar since idk, a few years at least, (my build probably has a date). Haven't drifted out of control and died yet but I do feel more manly knowing others claim I'm cheating death and an adrenaline junkie simply from removing a sway bar.
    Seriously though run without it for a week or so and off-road without it. Then make an informed decision. I hated hiting a pothole with one tire and having the whole truck lurch because sway bar.
    Ritchie, Madjik_Man and wheeliest like this.
  16. Aug 23, 2017 at 8:20 AM
    coopcooper
    alberta canada
    disconnects on a 2nd gen... ok
  17. Aug 23, 2017 at 8:22 AM
    JayRolla
    Colorado Springs
    Thought this was a 1st gen thread. I have them on my 4runner that shares the same front suspension geometry. You can disconnect the front bar on a 1st gen and just push it up to clear the cv's.
    jeff b[QUOTED] likes this.
  18. Aug 23, 2017 at 12:15 PM
    Madjik_Man
    There's a guy here who makes stout disconnects.
    I have it bookmarked on my computer.
    But I'm on my phone now.
    A quick search should find it for you.
  19. Aug 23, 2017 at 12:18 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Just fab up your own disconnects. I had some from an old Jeep Cherokee. Fabbed em up to work on my 98. I don't really notice a difference when they are disconnected besides the obvious gain in suspension flex. On road I don't notice it either. probably because I have some stiff azz springs in the front. I'd imagine a stock set-up might get squirrly.
  20. Aug 23, 2017 at 12:30 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I removed mine completely. It's not a daily driver anymore but I removed a while ago. Yes, you notice a difference in driving, but as long as you KNOW that, and drive accordingly, you should be fine. I mostly notice when turning right from a stop light. I get more body roll on acceleration, so I'm left some rubber behind a few times when getting on the gas.
    As with anything, it's going to be a compromise. I never saw any quick dissconnects I was happy with, so I just took it off completely
    Ritchie likes this.
