Sway Bar Relocation Kit Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 29, 2018.
  1. Nov 29, 2018 at 6:55 AM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Hey Everyone,
    When I was lifting my truck, I decided to leave the sway bar in. Everything seems to be working OK (however when I articulate the passenger side up a bank I seem to get a minor tension creak... but that might just be new stuff breaking-in or was there from the get-go and I never realized it). Anyways, whats the deal with sway bar relocation kits on third gens? Would I benefit getting one if I'm not having any issues so far? I'm going back to have shims installed next week and wondering if I should install a relocation kit while I'm there.
    I have 6112s set at the 5/6 notch.
  2. Nov 29, 2018 at 7:29 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Lose the sway bar. You don't need it.
  3. Nov 29, 2018 at 7:35 AM
    ejewels
    CT
    I only want it because I drive a lot of road. With that said, how do you know if you need the relocation kit or not?
  4. Nov 29, 2018 at 7:36 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Do they make quick discos like they do for jeeps. Seems would make more sense
  5. Nov 29, 2018 at 7:37 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    ^^^ What he said ^^^
    PapaRee and Trident904[QUOTED] like this.
  6. Nov 29, 2018 at 7:39 AM
    Trident904
    Brian
    17 4Runner TRD OR
    I daily mine without the sway bar and it's fine. Upgraded suspension generally negates the need for the sway bar.
    ejewels[QUOTED][OP] likes this.
  7. Nov 29, 2018 at 7:40 AM
    Trident904
    Brian
    17 4Runner TRD OR
    No, because the design of our sway bars leaves no room to keep it out of the way.
    ejewels[OP] likes this.
  8. Nov 29, 2018 at 7:40 AM
    johntoyota
    Down yonder in TN
    16 truck
    On road, I have never noticed it being gone. Off road, it makes a world of difference not being there.
  9. Nov 29, 2018 at 7:42 AM
    ejewels
    CT
    Is there a way to know if the sway bar is interfering? The very slight creak I hear I'm thinking isn't related.
  10. Nov 29, 2018 at 7:43 AM
    johntoyota
    Down yonder in TN
    16 truck
    If youre wheeling and it still wont flex even with a lift, it is interfering.
  11. Nov 29, 2018 at 7:44 AM
    Trident904
    Brian
    17 4Runner TRD OR
    If you are lifted, there is likely tension on the swaybar and causing it to over-rotate in the bushings.
  12. Nov 29, 2018 at 7:46 AM
    ejewels
    CT
    which could possibly cause a tension/creak kind of sound under articulation? Its very slight.
    johntoyota likes this.
  13. Nov 29, 2018 at 7:49 AM
    Riotfunk
    Taco TRD off road
    What about longer sway bar links, or flex links. I come from solid axles and the setup was just better and easier for offroad. So just using what I know from that.
  14. Nov 29, 2018 at 7:51 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Yes. Just pull the sway bar and take it for a drive and see how you like it and if the creak is still there.
    Kolter45 and ejewels[QUOTED][OP] like this.
  15. Nov 29, 2018 at 7:52 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Totally different animal from the solid axle world.
  16. Nov 29, 2018 at 7:53 AM
    ejewels
    CT
    If the creak is still there, I'd just chalk it up to new suspension/leafs breaking in. I was going to fluid film everything too.
  17. Nov 29, 2018 at 7:57 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Could be LCA bushings, UCA bushings, leaf springs, etc. Pull the sway bar first and start from there.
  18. Nov 29, 2018 at 8:00 AM
    ejewels
    CT
    All easy fixes on a new truck I'd imagine? Like lube?
  19. Nov 29, 2018 at 8:03 AM
    Trident904
    Brian
    17 4Runner TRD OR
    I guess, my truck squeaks like a bitch but IDGAF because I beat the shit out of mine on the rocks and the underside of my truck has a protective coating of Georgia red clay that probably causes the squeaks. If you wheel your truck, there will be squeaks. Dirt and mud get into nooks and crannies and cause squeaks. There's no way around it.
  20. Nov 29, 2018 at 8:06 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    This thread got way off your original question.
    Sway bar relocation kits are meant to move the swaybar forward slightly (about 3/4"). Most commonly used when you move to a coilover because the overall diameter of the new coil is larger than stock so the swaybar makes contact with the lower coils. Check to see if you're having contact there first. The added lift is also now making the swaybar operate outside of it's original design. Swaybar relocates address this by acting as a spacer as well- dropping the mounting location by about 3/4". If there is no contact between the swaybar and the springs, then the squeak could very well be coming from the rubber bushing at the sway bar mount. You can unbolt it and add grease to the inner and outer surfaces of the bushing and that should help.
