Sway bar end link bushings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TenderWarrior, Mar 16, 2021.
  1. Mar 16, 2021 at 10:05 AM
    TenderWarrior
    TenderWarrior [OP] Well-Known Member
    Hey guys, am I able to just swap out the sway bar end link bushings or do I have to replace the entire end link? The bushings are shot right now. I have a 2001 4WD V6 Tacoma.
    Thanks
  2. Mar 16, 2021 at 10:08 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    It's easier to swap the whole thing, I wouldn't mess with it. Save an hour of your time for 10$?
  3. Mar 16, 2021 at 10:23 AM
    TenderWarrior
    Do you recommend a specific brand for end links? Everywhere I see that are around $30 for each.
  4. Mar 16, 2021 at 10:24 AM
    LoveableWerewolf
    Nashville
    @RockAuto
    I've most of the time found they have the best prices.
    Tacomaworld has a discount if you look up thier page here.
    I like Moog, but some don't.
    TenderWarrior[OP] likes this.
  5. Mar 16, 2021 at 10:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  6. Mar 16, 2021 at 10:57 AM
    LoveableWerewolf
    Nashville
    Exactly, storefront parts stores really run more expensive unless you know exactly how to deal with them. If you can order online I would say go for it.
  7. Mar 16, 2021 at 11:13 AM
    TenderWarrior
    Thanks. Yea I’ll just get the moog ones to replace. These end links are not the kind where the two bushings sandwich the link so I wasn’t sure if they could be replaced.
  8. Mar 16, 2021 at 11:32 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    You can definitely do just the bushings, I did way back when I didn't really know what they were (but I could tell that they needed to be replaced). Ended up taking the sway bar off a couple months later!
    Replacing the Stabilizer Link Bushings
    If I were to do it again, I'd get the $12 set of 4 polyurethane aftermarket bushings, since that seems like a great deal and probably better than the rubber.
  9. Mar 16, 2021 at 11:45 AM
    TenderWarrior
    yea looks like you have the end link where the bushings sandwich the link. I don’t have that one. I’ll have to get a picture because it’s hard to explain how mine looks different.
    turbodb[QUOTED] likes this.
  10. Mar 16, 2021 at 12:40 PM
    jbrandt
    Justin
    Yours look like this I'm betting:
  11. Mar 16, 2021 at 12:44 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I mean you "could" replace the sway bar and LCAs with one from a 98-00 but yeah, not worth it.
    Just get the double ended ones we have to deal with, maybe $40 total?
    also, maybe it's me at the end of the day but when someone mentions what they have and then someone else posts the "solution" for something the person doesn't have :annoyed:
  12. Mar 16, 2021 at 12:52 PM
    TenderWarrior
    yeah they are just like that. I ended up ordering the Moog ones and yes spent $40 total. Which is totally fine I just was trying to go the cheaper route but if I’m gonna replace I’d rather have the whole thing brand new.
    jbrandt[QUOTED] likes this.
  13. Mar 16, 2021 at 12:52 PM
    jbrandt
    Justin
    Hey, at least it was still for a 1st gen. It's hard to know what is the same vs what is different between the various sub categories of 1st gens.
    My favorites are the "you need a body mount chop" to fit 33's" in the 1st gen section.
    turbodb and Abeyancer like this.
  14. Mar 16, 2021 at 2:35 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I just did the whole thing on each end; easy-peazy! Got em from Rockauto.com.
