Sway Bar Bracket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cl251, Oct 26, 2021.
  1. Oct 26, 2021 at 11:02 AM
    cl251
    cl251 [OP] Well-Known Member
    New jersey
    2010 Silver Tacoma TRD Sport
    3in Bilstein lift w ucas 17x9 Falcon Wheels and 35s Viper cut Stereo upgrade Lighting
    I was replacing sway bar bushings today and when I was bolting the brackets back up one of the bolts broke and won’t come out or tighten. The rest tightened up perfectly. Is it okay to drive? Or any recommendations on getting it out? Thanks!
  2. Oct 26, 2021 at 11:14 AM
    10YSON
    10YSON Well-Known Member
    GREG
    2ND GEN 4X4 LT
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    I'd just pull the sway bar out of the truck until you get that bolt extracted.
  3. Oct 26, 2021 at 11:23 AM
    cl251
    New jersey
    I don’t even think there is a way to extract it it just spins freely.
  4. Oct 26, 2021 at 11:31 AM
    guyfromky
    guyfromky Well-Known Member
    You'll have to cut the bolt head off with an angle grinder, cut-off wheel, etc, remove the sway bar and then drill and tap.
    Or just do like some and drive without a sway bar. I don't recommend it, but some on here swear by it.
    10YSON likes this.
  5. Oct 26, 2021 at 5:43 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Sounds like the welded nut inside the frame is dorked up. Here's a few past threads on it (and I'm sure you'll find plenty more using the search):
    https://www.tacomaworld.com/threads...-in-the-frame-want-to-discuss-options.373114/
    https://www.tacomaworld.com/threads/broke-the-sway-bar-nut-inside-the-frame.211911/
    https://www.tacomaworld.com/threads/sway-bar-bolt-at-frame-just-turns-and-turns.112440/
