Swapping in factory LSD third member to non factory LSD diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by overado, Feb 12, 2017.
  1. Feb 12, 2017 at 11:42 AM
    overado
    overado [OP] Well-Known Member
    2010 RegCab Tacoma
    Lifted, 285/70/17s, Referbished FJ rims, custom front bumper, snorkel
    I have a 2010 Tacoma reg cab 5spd with 4.10s I also have the 3rd member out of an 07 Tacoma with the factory LSD which allegedly also has 4.10s has anyone swapped these two 3rd members.
    I have done a lot of research and cannot confirm that the LSD is in fact 4.10s. Before I tear into my axel I would like to know if anyone else has done this.
    Thanks in advance!
  2. Feb 12, 2017 at 11:47 AM
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    I believe they are different suzes too, the non lsd is bigger then the lsd
  3. Feb 12, 2017 at 12:53 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    As long as both rears are 8.4 and both 4.10 it is an easy swap. I did the same swap on my 2012 4.0 l. I ordered a new center section(3rd member) right from Toyota with LSD but mine had 3.73 gears for the v-6.
  4. Feb 12, 2017 at 12:55 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is for locker vs no locker, which are different sizes.
    While you have the part, using something like a gear driven Detroit Trutrac torsion LSD will be significantly better than the factory's clutch pack LSD.
  5. Feb 12, 2017 at 6:01 PM
    overado
    2010 RegCab Tacoma
    That is what makes me nervous is that they are two different ratios. I was told by the donor that it was 4.10 but I don't know how to confirm the ratio...that being said it is a very easy swap provided the ratio is the same
    I Am not 100%sure but I'm pretty positive they are both the Toyota 8.4, I can measure the one in my garage but not the one on the truck until it is out of the truck. I know the donor came out of a 2007 4.0L v6 and I was told it was a 4.10 which I believe to be true as I scored the 3rd member out of a an axel that had been swapped. The only reason I am doing it is that I have LSD 3rd sitting in my garage and it would be nice to have the LSD. I know there are better options but I have the potential to do this swap for almost nothing out of pocket!
  6. Feb 12, 2017 at 6:06 PM
    Pigpen
    Northwest Montana
    They're all 8.0"
    The moniker 8.4 is false and confusing. If both trucks are non e locker, the swap will work.
    If the donor truck is a 4 cyl, it's a 4.10. If the donor is a 6 cyl, it's 3.73.
  7. Feb 12, 2017 at 6:13 PM
    overado
    2010 RegCab Tacoma
    The more I've read the more confused I am about the 8.0 vs 8.4. that being said the donor was a 4.0 so I guess I'm SOL? I was hoping for some reason that I have not been able to find the LSD diffs would be 4.10s like I was told it was
  8. Feb 12, 2017 at 6:21 PM
    Pigpen
    Northwest Montana
    All 4.0 trucks come with 3.73
    The 8.4 designation is given simply because it's stronger than the e locker 3rd member. It's still an 8 inch ring gear.
  9. Feb 12, 2017 at 6:23 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Count the number of teeth on the ring and the number of teeth on the pinion. Divide the larger number by the smaller number. That will tell you what the gear ratio is. But like was mentioned...if it came out of a v6 and hasn't been re-geared, it is 3.73.
  10. Feb 21, 2017 at 10:09 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Is it possible to swap the E-locker carrier into a LSD axle housing?
  11. Feb 21, 2017 at 10:18 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Maybe so, but it seems the two aren't compatible. Everyone list the gears for each axle separately and with different part numbers. ECGS also shows the 8.4" gears as weighing significantly more.
