Suspension upgrade Bilstein 6100/5160
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Patrick44, Jan 19, 2024.
  1. Jan 19, 2024 at 11:59 AM
    Patrick44
    Patrick44 [OP] Active Member
    Patrick
    2020 Tacoma TRD long bed
    Would I still have a rake to my truck with the Bilstein 6112 set to 9/11 in the front to give me a 2” lift in the front
    Then in the rear Bilstein 5160 set to 1.5” with Deaver stage 1 2” ?
    thanks!
  2. Jan 19, 2024 at 12:44 PM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    Theoretically yes, about a 1" of rake with no extra weight in the rear if you are lifting 2" front and back.
    Note that the rear shocks don't provide any additional lift, they simply accomodate up to 1.5" of rear lift (Many people go beyond this recommendation). Your leaf springs will likely settle very slightly over time.
    Your best bet is to measure your heights as it sits today, and then decide on circlip and rears that fit the stance you want. Proof is always in the math.
  3. Jan 19, 2024 at 12:59 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    No shock provides lift; springs do that.
  4. Jan 19, 2024 at 1:02 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I “think” so. With that kit, reach out to Colton @memario1214 I’m sure he can help out. He owns/runs hotshotoffroad and always helps out.
    memario1214 likes this.
  5. Jan 19, 2024 at 1:13 PM
    pivey14
    Austin, TX
    That's what I said lol
  6. Jan 19, 2024 at 1:33 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It will look exactly like it does currently just 2” higher if you get a true 2” of lift.
    71tattooguy likes this.
  7. Jan 20, 2024 at 6:04 AM
    Patrick44
    Patrick
    Thank you!
  8. Jan 20, 2024 at 7:46 AM
    BillyE
    BillyE Well-Known Member
    What you described is exactly what I have.
    37.5 front L&R
    38.5 L rear
    39.0 R rear
    measured fender to ground with stock size wheels.
  9. Jan 20, 2024 at 7:50 AM
    Patrick44
    Patrick
    Perfect because I don’t want the rake to be huge nor am I trying to level the truck. Do you have the Deaver stage 1 too?
  10. Jan 20, 2024 at 8:03 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I can only speak for the Bilstein 5100s, but mine is set @ 2" in the front and a 1" rear block and my Taco is perfectly level, no rake. Stock coils a per Bilstein recommendation. ( I don't miss the rake, and the oem brake dive). Nor did I need to replace my UCA's.
    In this pic, it may look a tad lower in the rear, but I have 4 rims and 4 tires in the box.
    Patrick44[OP] likes this.
  11. Jan 20, 2024 at 8:12 AM
    Patrick44
    Patrick
    Thank you!
  12. Jan 20, 2024 at 8:16 AM
    BillyE
    Yes
