Suspension Setup For Camper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChuckWagonPNW, Oct 23, 2020.
  1. Oct 23, 2020 at 8:44 AM
    ChuckWagonPNW
    ChuckWagonPNW [OP] Member
    I recently got a Four Wheel Camper for the 2019 TRD OR and am going to spend the next year living out of it. The camper weighs in at over 1200 pounds so going to do some suspension work and think I have settled on the following but still have some question I need some help with. Primary use will be overlanding, a lot of wash boarded roads, maybe trails like White Rim in UT, nothing too extreme.
    Tries:
    265/75/r16 E rated Wildpeaks or BFG KO's
    Front:
    Bilstein 6112 with new coils (600lbs or 650lbs, not sure)
    Not sure on the amount of lift, I think they max out at 1.8 inches on the Access Cab?
    Rear
    Bilstein 5160's
    New Leaf pack, something heavy duty for a constant weight, not sure what brand. Will all the added leafs this will likely result in a 2.5 inch lift in the back (unweighted) right?
    I have Firestone Airbags installed right now, might keep those and get cradles for them.
    Thoughts on the suspension?
    Thanks in advance!
  2. Oct 23, 2020 at 8:48 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sounds like you got it covered. I run just with the ride rites and I’m good
  3. Oct 23, 2020 at 9:39 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    If it was me I would look at moving to a full sized pickup, the extra size will be well worth the extra cost to upgrade.
  4. Oct 23, 2020 at 9:43 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Is this a folding camper? A teardrop? Hardside? Bed mount?
    Is 1200 lbs the Tare (empty) weight or GVWR of the camper?
  5. Oct 23, 2020 at 9:43 AM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    I too suggest this for someone with an fwc but the tacoma is nice that its a smaller package. It technically shouldn't have the FWC on it but plenty of people do this. But seems already purchased the FWC so its a mute point.
    Campers are also a whole lot cheaper for full sizes than mid-size in the used market. Maybe not FWC type but plenty of other brands and more suitable to living out of.
    I can't get rid of my tacoma and have just decided to build my own wedge/camper to my liking since lead times are so long.
  6. Oct 23, 2020 at 10:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    For a camper in/on the bed? I'd definitely look at a full size, better yet a 3/4 or 1 ton
    @hiPSI said it best, ,,,,"those guys who carry their house with them are all over max payload."
    hiPSI and Interbeing like this.
  7. Oct 23, 2020 at 11:00 AM
    ChuckWagonPNW
    Hindsight is for sure 20/20 and knowing a year ago what I do now, I would have gone full size. But its too late to get the toothpaste back into the tube, so sticking with the Tacoma.
    1200lbs is the dry weight.
    wahoobie likes this.
  8. Oct 23, 2020 at 11:05 AM
    2ski4life7
    Seattle WA
    I think a lot of people have good luck with the HD dakars. They can also be switched to MD dakars by removing the third leaf I am told, if the HD is too stiff.
  9. Oct 23, 2020 at 11:22 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  10. Oct 23, 2020 at 11:29 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Id recommend calling Deaver Suspension, tell them what setup you’re running on your truck and how you plan to off road it, and they can build you a set of leaf springs tailored to your truck.
    Deaver phone number:
    714-542-3703
  11. Oct 23, 2020 at 11:39 AM
    Interbeing
    Austin, TX
    I empathize with your dilema, but you also don’t want to compound the problem. 1200 lbs dry weight translates into probably closer to 1700-1800 lbs loaded minimum. It isn’t just the spring rate, you also need to consider your axle, gearing, transmission, brakes (drum rears), wheel bearings, etc. The Tacoma was never designed for that type of load. Sometimes we just have to take a step back and reconsider our situation and readjust. Living in a camper full time makes it even more important to have the right equipment for the job, not just for comfort, but more importantly, for your safety as well. Having worked in the trucking industry as a winch tractor operator I saw first hand the results of pushing gear past it’s intended purpose, unfortunately too often resulting in tragic results. Anything other than running at very moderate speeds on flat open roads will be a very miserable experience at the least, and at the worst, endanger your life, and the lives of others.
    Chew and Dalandser like this.
  12. Oct 23, 2020 at 11:52 AM
    ChuckWagonPNW
  13. Oct 23, 2020 at 11:53 AM
    ChuckWagonPNW
    Its nice to have someone with experience chime in, thanks. Seriously considering your thoughts.
  14. Oct 23, 2020 at 12:04 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
  15. Oct 23, 2020 at 12:11 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  16. Oct 23, 2020 at 12:55 PM
    RyanDCLB
    4/19 DCLBOR
