Surging at idle & on throttle 04
Discussion in '1st Gen. Tacomas (1995-2004)' started by SalemCBR, Mar 27, 2018.
  1. Mar 27, 2018 at 9:17 PM
    SalemCBR
    SalemCBR [OP] Oregon's #2 TW rep
    Oregon
    04 DC Elock PreR
    Deck plate, all time auxillary, black billet, xeon bulbs, sockmonkey decals, and lots of back to black.
    Hey there TW,
    I am seeking your help. I am experiencing surging idle-whatever speed only been 45 mph so far with it. Recently replaced 02 sensor.
    Seems like if the truck is cold I can start it up and a couple blocks later it starts to surge again. At one point in traffic it would die as I slowed below 1200 or so rpms. At that point tge idle was 400 at best. Seems to be back to 800 or so.
    Thoughts? Where to look first? Search the bowels of earth for a tps? This is no cbr (sport bike) I am not winning.
  2. Mar 28, 2018 at 1:56 AM
    04Burk
    04Burk Well-Known Member
    Glen
    Hinesville, GA
    04 4x4 V6 Xcab 217k miles
    I had something similar. Cleaned the throttle body and cleared it right up.
    SalemCBR[OP] likes this.
  3. Apr 2, 2018 at 2:28 PM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Cleaned TPS, cleaned TB, replaced front 02 sensor.
    Thoughts are: new o2 sensor bad? Timing belt stretched and throwing timing, iac needs replaced?
    Toyo tech said my iac is part of the throttle body and to get a new/used throttle body. He said he ordered in a iac but it didnt fit and I must have an 05 TB??
  4. Apr 7, 2018 at 12:13 PM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Will be in search of junk yard throttle body. Pretty sure that 30 year toyo machanic is crazy and it is an 04 TB. The TPS sensor would be diffefent.
  5. Apr 17, 2018 at 5:31 PM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Replaced throttle body. The new one looked much cleaner than my old one inside. But I am getting the same symptoms. Idle goes up and down at around 1.5 seconds time. Than faster as I accelerate. Cant drive it smoothly.
  6. Apr 19, 2018 at 9:13 AM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Bumpidy bumpidy. Ideas??
  7. Apr 19, 2018 at 10:15 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    did you clean the little holes just past the throttle body? You have to remove a small metal square with screws to access. Would be easier to remove the whole throttle body to fully clean, and prevent other junk from falling into the engine.
    Try cleaning the MAF as well (with MAF cleaner)... spray inside the holes, and the temp air bulb. Do what the guy in this image is doing, however I would not recommend jamming the straw up the holes, you could ruin the MAF sensor.
    Maf sensor can be removed by removing two screws, unplugging, and popping it out. No need to remove air box.
    3_TACOS_NEVER_ENOUGH likes this.
  8. Apr 19, 2018 at 2:43 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    How do you clean a tps? I would suspect that thing.
  9. Apr 19, 2018 at 3:08 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Also check for vacuum leaks. Cracked hoses, hissing noises, surge in idle when spraying around areas of engine bay with carb clean will help narrow down areas.
  10. Apr 19, 2018 at 3:11 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Any check engine light codes?
  11. Apr 25, 2018 at 11:20 AM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Cleaned the holes under the screwed in cover on top the TB, Replaced the TB with a used one, cleaned TB, cleaned MAF, cleaned TPS, replaced plugs and wires, replaced O2 sensor again to make sure it was not a bad part.
    I guess I gotta pay a shop again.
  12. Apr 25, 2018 at 11:22 AM
    SalemCBR
    Oregon
    04 DC Elock PreR
    Did this too.
  13. Apr 25, 2018 at 11:25 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    link in my sig is the 03-04 ETCS TB. It was Toyota's first attempt for Tacoma for the electronic throttle versus the cable driven
    I've had random idles for awhile but mostly OK. no surging tho.
    remember the 00-02 4Runner has the same TB. IAC was removed for the 03-04 due to ETCS
  14. Apr 25, 2018 at 11:27 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    TPS is electrical, based off resistance and position. @SalemCBR did you mean something else other than TPS? If not why/how did you clean TPS?
  15. Apr 25, 2018 at 3:31 PM
    SalemCBR
    Oregon
    04 DC Elock PreR
    The shop said they cleaned it. I have since put in another throttle body so. No change.
    When I disconnect the TPS and run it, it idles 1800 and still is rising and falling 200 or so rpms once it runs just a little. Thats a surge just short of 1 second and faster as I drive it.
    I did a seafoam treatment in the PCV hose and that didnt change anything. But after that I could hear a leaking air sound in or after the high part of the surge in idle. Sounds like it is near the pcv valve. Cleaned with rag and inspected those rubber components. The valve does rattle. If I pinch that hose the leaking sound goes away until pressure builds up (i think).
  16. Apr 25, 2018 at 3:54 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    going back to your original post. did this surging happen before the O2 sensor replace? is that the reason you changed it?
  17. Apr 25, 2018 at 4:24 PM
    SalemCBR
    Oregon
    04 DC Elock PreR
    No, i had a code for o2 sensor. Didnt surge before.
  18. Apr 25, 2018 at 7:43 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    what was the code, and what kind of O2 sensor did you buy?
  19. Aug 30, 2018 at 8:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    spray carb cleaner around the area to try to narrow down the area of the leak. If the idle changes then you've gotten close to the area. Also, the rattle test for PCV valves is not always the best indicator. If it's very old then you should probably spend the $8 or so to replace it and the grommet that it sits in. Replace the grommet because it can get hard and brittle and no longer seal properly.
  20. Sep 13, 2018 at 4:16 PM
    Mtnbkeguy
    Mtnbkeguy New Member
    2004 Tacoma 3.4
    Following. I’m experiencing the same thing. Could it be the cataletyc converter?
