Supercharger Vacuum diagram sticker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by darth_bronchioles, Aug 24, 2023.
  1. Aug 24, 2023 at 2:35 PM
    darth_bronchioles
    darth_bronchioles [OP] Well-Known Member
    California Central Coast
    1999 Supercharged Tacoma 4x4 Limited
    TRD Supercharger URD 7th injector kit K&N intake 4Runner Mirrors Dog Light Mod
    So I just failed smog (California) because my truck has the sticker for the stock vacuum diagram which doesn't correspond to the vacuum lines for the supercharger install. Does anyone know where I can find the sticker for the supercharger Vacuum diagram, or if there even is one? I showed the inspector the diagram in the installation PDF, but he said they have to go off of the sticker under the hood.
  2. Aug 24, 2023 at 2:39 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    weird, but not surprising I guess. Magnuson might be able to send you one. If not, I'd just print a photo of one off the web and stick to the underside of the hood with packing tape when you get to the smog shop :notsure:
    Area51Runner likes this.
  3. Aug 24, 2023 at 2:39 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Remove the stock vacuum diagram, and tell him there wasn't a diagram for the supercharger provided to adhere to the hood.
  4. Aug 24, 2023 at 2:41 PM
    eon_blue
    Azusa, CA
    I know the CARB sticker is required but I wasn't aware the diagram sticker was, kinda wonder if they are just being super nitpicky to avoid any liability. Some smog shops are like that out here. Might try a different place, if you're anywhere near Pasadena.... there's a good place in Duarte I always go to with my supercharged 04 I can give you the name of.
    I have the TRD headers which for some reason aren't technically CARB legal for the 2004 Tacomas (only up to 2003)...but he still passes me.
    BartMaster1234 likes this.
  5. Aug 24, 2023 at 2:51 PM
    darth_bronchioles
    I'd probably fail for not having one at all, lol worth a shot though.
    Yeah, I'll probably try a different place. I live in the Monterey area, otherwise I'd be willing to try out your place.
    eon_blue[QUOTED] likes this.
  6. Aug 24, 2023 at 9:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    When I got my supercharger from Magnuson, there was a vacuum routing sticker included in the box.
  7. Aug 24, 2023 at 10:18 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    According to Magnuson, there are only 2 stickers included with the M62 kit. Fuel and Belt Routing. I'd call Magnuson or perhaps @BartMaster1234 might have something. I recall he came up with some stickers once for something similar.
  8. Aug 24, 2023 at 10:24 PM
    darth_bronchioles
    Do you have a picture? If anything, I might be able to mock something up.
  9. Aug 24, 2023 at 10:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'll try to remember to take one next time I'm near the truck.
  10. Aug 24, 2023 at 10:32 PM
    darth_bronchioles
    Thanks, I appreciate it!
  11. Aug 25, 2023 at 9:51 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I pass California smog just fine with the stock vacuum line stickers. It depends on who does your smog I guess.
    I pass with just the CARB sticker, and that’s all they should need. I had a K&N intake that changed the vacuum line routing and I still passed with the K&N carb sticker.
  12. Aug 25, 2023 at 9:52 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    @Kwikvette might have a smog shop for you. He used to be out there.
  13. Aug 25, 2023 at 9:56 AM
    eon_blue
    Azusa, CA
    Yeah I have the sticker under the hood too from whenever the PO had the TRD version installed. When I first saw my smog guy he definitely went to check the CARB sticker but I never once saw him reference the vacuum line one, I think the OPs smog guy is being overly cautious or deliberately trying to get him to go somewhere else. Some of these smog shops out here do not like taking in modified vehicles, even if they're modified with carb certified parts, for whatever reason. Probably got dinged in the past for something and are on thin ice with the state.
  14. Aug 25, 2023 at 10:38 AM
    darth_bronchioles
    I guess the place I took it to was just overly cautious. Magnuson replied to me saying basically the same thing; that vacuum routing shouldn't matter. I might mock-up something just to be on the safe side, but first I'll take it to a different shop. Thanks for the input everyone.
  15. Aug 25, 2023 at 10:40 AM
    eon_blue
    Azusa, CA
    If you have a local community thread on FB or something, try finding out where other guys go to get their boosted/modified vehicles smogged. Will stand a much better chance not having a stick-in-the-mud smog guy giving you grief over stuff that shouldn't matter like the last guy.
    Tyler already tagged @Kwikvette but maybe he knows of a place because he had several modified cars out there before he moved
  16. Aug 25, 2023 at 11:36 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    The guy who smogs my car is definitely a car enthusiast, he parks his NSX and his Ferrari inside the lobby. I kind of have a feeling he turns a blind eye, or purposely doesn't look super hard at modified vehicles.
  17. Aug 25, 2023 at 2:06 PM
    darth_bronchioles
    I'm gonna take my truck into a different shop in a bit. In the mean time, I mocked up a new sticker and ordered a batch of them just to cover my bases in the future. I'll have 9 available once they arrive if anyone else is interested.
    The size is 4.3x5.5 in
  18. Aug 25, 2023 at 3:43 PM
    darth_bronchioles
    I made a few more for 2WD Tacomas. Anyone is free to use them for their own vehicles, I won't be printing these.
    Area51Runner and Digiratus like this.
