Supercharger maintenance: rebuild?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jedirye, Sep 6, 2020.
  1. Sep 6, 2020 at 8:33 PM
    jedirye
    jedirye [OP] Wannabe
    Florida
    2013 Baja Supercharged
    Inquiring about supercharger maintenance, coming up on 100k miles. I've done a search, found this:
    https://www.tacomaworld.com/threads/trd-s-c-maintenance-how-to.331263/
    Super helpful, however also found another thread where they mentioned requiring a "rebuild" at 100k miles and the rebuild kit is $750. Since the truck's at the shop already for an undetermined amount of time (sigh....), was thinking of having them do the maintenance if the price is fair. Now I DID do the SC belt already and changed the plugs already (Iridiuns) so good to go there... Not sure where to buy rebuild kit, had already done Google search and couldn't find. Honestly not even sure if that's required, hence my inquiry.
    Any input is greatly appreciated!
  2. Sep 6, 2020 at 9:10 PM
    jedirye
    Florida
  3. Sep 7, 2020 at 4:37 AM
    boredazhell
    boredazhell Well-Known Member
  4. Sep 28, 2020 at 10:05 AM
    jedirye
    Florida
    Thank you!!
    I'm going to go ahead and do the oil and whatnot, and leave the rest be... It's just way too complicated. I'll revisit this in another 10k miles lol
  5. Sep 28, 2020 at 12:21 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Truckstop13 likes this.
  6. Sep 28, 2020 at 12:22 PM
    JasonLee
    15 TRD OffRoad
  7. Sep 28, 2020 at 1:21 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I had the dealer do my supercharger rebuild a couple years ago, they charged me $735.00
  8. Oct 26, 2020 at 5:16 PM
    jedirye
    Florida
    The dealership I go to knows nothing about SCer maintenance. They said they couldn't find anythimg from Toyota about even needing the maintenance at 100k miles.
    Does anyone have something from Toyota about it? I Googled and didn't find much. There was a broken link for SCer at TRDUSA... This one: https://www.trdusa.com/superchargers.html
    Many thanks for any help.
  9. Oct 27, 2020 at 7:23 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Yes this is everything for a basic rebuild from what I understand.
    At the minimum I would change the oil, which isnt bad at all. There is a kit on Amazon with a syringe for $35. This is what I went with: https://smile.amazon.com/gp/product/B07N1VV79F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Im in the same boat as you looking to do the rebuild also, but only have about 50k on mine. Its on my FJ. I will swap it over to the Taco prolly this spring, and do the rebuild then. I have a little oil weeping out around the cone. Hardly anything, but I want to go ahead and do it all since I will have it out.
  10. Oct 27, 2020 at 7:37 AM
    jedirye
    Florida
    I was quoted $550 for supercharger oil and scer coolant change. Seems high. Infact ill figure that out myself if it's accurate lol
    Do they have coolant?
  11. Oct 27, 2020 at 7:50 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Yes this is the coolant in the intercooler. So you have a small intercooler pump that circulates the coolant from the supercharger down through the intercooler in front of the radiator. Should be the same pink coolant as the radiator.
    550? lol They dont call it a stealership for nothing...
    Athlaos likes this.
  12. Oct 27, 2020 at 7:53 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  13. Oct 27, 2020 at 8:52 AM
    theturbodog
    theturbodog Well-Known Member
    Fort Worth, TX
    This was on an older 3.4l almost 10 years ago now, but at the time Magnussen was doing the rebuilds for very nearly the same cost as the parts. I just pulled just the 'guts' off and sent it to them and got it back a week or so later rebuilt and tested. I'm not sure if they still do that, but possibly worth looking into.
  14. Oct 27, 2020 at 10:04 AM
    jedirye
    Florida
  15. Oct 27, 2020 at 10:15 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I’m a little lost but I honestly just skimmed over everything. So first.....Toyota states maintenance at 100k. At the bare minimum a s/c oil should be changed. This is easy. It involves taking a bolt off, using the syringe to extract the oil (it stinks badly so be careful), replacing the oil, put the bolt back on. At the 100k maintenance you really should do the s/c oil, swap the impeller bearings, swap the coupler, belt, and inspect the rotors for wear. I’d also swap your spark plugs regardless of how many miles you have on them at that time since you have everything exposed. 2 of the drivers side plugs are almost impossible to change unless everything is off. However, a few guys from that thread I sent you have swapped the plugs with a sneaky setup of swivels, extensions, and a ratchet. Superchargeronline.com are very reputable and can do the rebuild for you if you send them your stuff. Keep in mind if you have modded the motor.....tune, exhaust, pulley, etc. you should do the maintenance sooner. What exactly did you need to know about the s/c coolant?
  16. Jun 28, 2023 at 12:22 PM
    Suckafartout
    Suckafartout Well-Known Member
    2008 Tacoma trd sc
    Supercharged
    Yes, do not take the supercharger off to change the plugs. There’s like a couple bolts you have to undo for the fuel assembly or whatever it holds to get that out-of-the-way just so your hand can fit in there. Need 2 short, sockets, a small ratchet with hinge and a wobble.
  17. Jul 5, 2023 at 5:38 AM
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    I have a questions about this:
    1) I bought truck at 25K miles with supercharger in 2014, now have 95K. I have changed the oil on it (around 70k miles) but that's the only maintenance I've done. It's not making noise, but I can't seem to get more than about 4psi of boost. Should I be looking into a rebuild?
    2) Does anyone have a link for an explanation of how to remove the supercharger? Mainly I'm not sure I would know how to get the belt off...
    3) Reviewing links here it seems the options are to send off for a rebuild or order a rebuild kit and do it yourself. I don't have a press and not sure a rebuild kit is doable without it. Any insights?
    Thanks in advance.
  18. Jul 5, 2023 at 7:06 AM
    Suckafartout
    2008 Tacoma trd sc
    Supercharged
    Probably needs tuning, How far advanced is your timing? Pulley size? The belt comes off with the tensioner underneath. You have to take the skid plate off and then two bolts and the whole tensioner Hass to come off to remove the sc belt or other belt behind. SC supposed to be good for at least 100,000 miles and you changed the oil in it then it should be good for a little more. The advice here I got is wait until it starts making weird noises.
  19. Jul 7, 2023 at 4:41 AM
    Bwthomas77
    North Carolina
    Thanks, I think I'll hold off. I do have a tune on my truck and actually in lower gear it does look I'm hitting higher boost numbers. Sounds like unless it's making noise best to leave it alone.
