Supercharger-how far before fuel pump upgrade.
Discussion in 'Performance and Tuning' started by Amo-cat3, Aug 3, 2011.
  1. Aug 3, 2011 at 7:17 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Just supercharged my VISA and ordered a "TRD SUPERCHARGER" Yay - how far can you go before you absolutely need a bigger fuel pump. I already have an X-1, k/n intake, dtlt headers, 2.5" mbrp exhaust. If i throw on the trd supachagah will the stock fuel pump and the supplied trd bigger (425) injectors be sufficient. Considering i have the correct map uploaded in the x-1.
    I don't race and no long boosted sprints for me, just exta towing oomph and testosterone boost once in a while. By the way I got it out the door shipped to Hawaii for $3883 fit kit n all from ShopTRD.com. Best prices i could find from a reputable site.
    I am going to attempt this install myself and have done countless searching and research. I installed everything else myself including the notorious X-1 cam shaft sprocket install so i'm diving into this one with me and my laptop and tacoma worlds knowledge. I'm jizzing every 10 seconds knowing that it is on it's way here. oooh, oooh .....
    At what point do i need an oil cooler, fuel pump, valve body trans upgrade, re-financed mortgage etc.................
  2. Aug 4, 2011 at 12:37 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Super charger guru's?
  3. Aug 4, 2011 at 12:55 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I would get one asap, even more so with the X1. There are two plus sides for getting the fuel pump, its keeps your pressure stable (very important under boost) and you can change out the filter. Oil cooler would be a good investment too, as for the VB you can wait until your pushing more ponies.
  4. Aug 4, 2011 at 7:47 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    It wont hurt to get it now if you have the funds... I have heard of VB upgrades pending increased HP levels. With stock pulley your boost levels are in line with what the APR is set to run pending you have the right MAP. If you start to run lean which could be viewed via an A/F monitor gauge such as AEM or similar, then you definately need larger injectors, 7th inj, and or a fuel pump.
    Enjoy Boost...
    :cool:
  5. Aug 4, 2011 at 10:37 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Going to smaller pulleys is what will change boost on the supercharger and with smaller pulleys bigger injectors and fuel pump is a must. Looks like an upgraded fuel pump is a good idea but not an absolute must with my set up.
    Can i modify APR base calibration maps by simply renaming it for eg:
    Tta40.03A.F_425.zip(supercharger map) renamed to Tta40.03A.F3_425.AprCal1 - this would be the supercharger map with the "F3" no catalytic converter hot calibration. Is this correct?
    For just standard boost with the TRD how important is an oil cooler on a scale from 1 to 5, 5 being most. I'll definitely switch to synthetic oil now.​
    Lastly, is there a plug and play A/F guage for the X1, or any plug and play guages for the supercharger. ​
    Thanks all.​
    DistortedAxis likes this.
  6. Aug 4, 2011 at 1:32 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This is how it works on the X1 for F files
    F1 is base tune (cats on) with speedlimiter
    F2 is base tune (cats on) without speedlimiter
    F3 is hot tune (no cats) without speedlimiter
    This is why you REALLY should get the upgraded fuel pump, if the X1 cannot keep the desired a/f ratio and/or fuel pressure it will go into limp mode.
    As for the oil cooler, I would consider it a 4, but it depends on you driving style, for sustained hard driving, I would get it, if not then no. There is no plug and play gauges for the X1, many have tried but it's easier to run them separately.
  7. Aug 4, 2011 at 2:17 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Thanx L Runner, I'm going to order the fuel pump now from urd - at this point better safe than sorry.
    For the fuel pump how close does the external filter need to be to the pump? And for guages would you say AFR guage would be first choice.
  8. Aug 4, 2011 at 5:20 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    For the filter you'll know as you'll have it at the end of the supplied hose. But for mine I hung it with zip ties so it doesn't bounce around. As for gauges I would run them in this order, oil pressure, AFR, fuel pressure.
  9. Aug 5, 2011 at 11:14 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    So trd supercharger, walbro fuel pump, tuned x1, intake, dtlt headers, and 2.5" exhaust with standard pulleys. How much boost should i expect with this setup with these mods 5-7 psi?
  10. Apr 11, 2015 at 2:11 AM
    CBHoldin
    CBHoldin ispin26
    Dank
    S.W. Colorado
    99 xtra Cab 3.4 Taco/Supercharged
    Post some updates!!
    By the way, whats a strong fuel pump for a Supercharged 2nd gen (black super charger) on a '99 Tacoma? I am about to get the smaller pulley and want to get everything in line
    URD seems to only make a 'URD specific' fuel pump for an 05+ tacoma
    Post up those brawny fuel pumps for a 3.4l 6cyl Tacoma
    peace
  11. Apr 11, 2015 at 2:47 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Holy thread revival!
    I have the Walbro 255. If I were to do it again I would get the DeatschWerks 320 for better capacity and E85 compatibility.
