Supercharger AEM 50-1220 340 Fuel pump replacement by removing the bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Sep 16, 2021.
  1. Sep 16, 2021 at 7:17 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    It’s actually a very easy process to remove the bed to get to the fuel pump.
    I installed the AEM 50-1220 340 pump (supercharger) its almost identical in size to the Denso pump
    Rented this Pittsburgh engine hoist for 25.00 a day. Can do this in one day easily.
    Remove the taillights
    Remove the taillights harness
    Remove the gas cap and remove the gas filler section
    Remove one tire for the hoist to slide under,
    Remove the six bolts holding the bed to the frame.
    Nows a good time to clean your frame from rust and spray a coat of paint
  2. Sep 17, 2021 at 6:30 AM
    chainslap
    chainslap Well-Known Member
    Prescott, AZ
    95.5 SR5 V6 5spd 4x4, 2020 Tundra TRD DC
    You can also just slide the bed back a couple feet if you don’t want to mess with a hoist. Still easier with two people.
    1997tacomav6[OP] likes this.
  3. Sep 17, 2021 at 6:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    After removing the 6 bolts that hold the bed to the frame, what do you have to do for an hour before you can get to the fuel pump?
    1997tacomav6[OP] and tacojim02 like this.
  4. Sep 17, 2021 at 7:51 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Did mine the same way...there was no dropping the tank with a rusted strap. Pretty easy to lift the bed off with two people as well
  5. Sep 17, 2021 at 11:57 AM
    tacojim02
    tacojim02 Well-Known Member
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    :rofl::boink:
  6. Sep 17, 2021 at 12:19 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Just cut the bed and make a service door like a 4Runner :sawzall:
  7. Sep 17, 2021 at 4:38 PM
    1997tacomav6
    Denver
    You paint the frame of course
    chrslefty likes this.
  8. Sep 17, 2021 at 4:43 PM
    1997tacomav6
    Denver
    Yup, winter is. Coming so I figured this would be a go time to paint the frame.
    AND of course that gas line nut was to the fuel pump needed a 4 foot breaker bar to bust it loose
  9. Sep 24, 2021 at 5:54 PM
    1997tacomav6
    Denver
    I think you can remove the front and middle bolts, loosen the very rear bolts as far as you can but leave them in there to hold the rear of the bed in place and then lift the very front
    Of the bed up just enough to get the pump out as long as the fuel lines break free.
    You probably need to remove the gas filler plate
  10. Sep 24, 2021 at 6:48 PM
    Partsman@dtla
    Partsman@dtla Humachine
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    What's the difference or advantage between the AEM and Walbro 190lph that most route for after supercharging?
  11. Sep 24, 2021 at 7:00 PM
    1997tacomav6
    Denver
    The Walbro out put flow rate is 190lph and very loud.
    AEM 50-1220 out flow rate is 340 LPH not loud = 95.00 from advanced auto with discounts.
    Zero ping issues with this AEM pump
  12. Sep 24, 2021 at 7:13 PM
    Partsman@dtla
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    Not to discredit you but I run the walbro and honestly don't hear the "loud" part of it..? I guess my magnaflow is interfering. There is a slight hissing when idle is warmed up and the environment is quiet but I can live with it. In fuel demand with the average pulley size used 2.2 to 2.1 do you see an issue or is it just preference?
  13. Sep 24, 2021 at 7:19 PM
    1997tacomav6
    Denver
    I don’t have any experience with the walbro, I’ve heard plenty of people say it’s loud.
    I run a 1.9 custom pulley with stock injectors, again no ping or fuel issues with the AEM pump, it’s output is much higher
  14. Sep 24, 2021 at 7:32 PM
    Partsman@dtla
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    1.9 pulley with stock injectors really?? Wow.. Did you have to create a map or have it tuned, 7th injector?
  15. Sep 24, 2021 at 7:37 PM
    1997tacomav6
    Denver
    I am running a stand alone haltech 2000,
    The haltech has a timing map, fuel map, no open loop or closed loop to deal with and no MAF to deal with.
    The AEM pump has more than enough extra fuel pressure to cover
  16. Sep 24, 2021 at 7:44 PM
    Partsman@dtla
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    Crazy AWESOME! I know Haltech is the tuners choice for complex turbo setups but never knew of anyone doing it on the Toyota 3.4 supercharger configuration. You're at an ABOVE level my friend..
  17. Sep 24, 2021 at 7:52 PM
    1997tacomav6
    Denver
    Thanks
    The haltech has solved all the supercharger ECU problems and the power comes on IMMEDIATELY.
    No closed loop anymore.
    A new band of power in the lower rpms.
    It has a completely new power band now.
    You can swap it back to stock in less than 10 minutes too if needed
  18. Sep 24, 2021 at 7:59 PM
    Partsman@dtla
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    COOL.. I'm not unhappy with my current combination but you must have a smirk from cheek to cheek :D, nice to know. Not sure when but I'm gonna have to follow in your footsteps. Hahaha.. :thumbsup:
  19. Sep 24, 2021 at 8:02 PM
    1997tacomav6
    Denver
    Well if you do there will be a big improvement over your setup now,
    When you get to that place let me know and I will give you my advice and some inputs on what steps you need.:)
    Toyotadilly likes this.
  20. Sep 24, 2021 at 8:04 PM
    Partsman@dtla
    Hector
    LALAA LAND
    1996 Tacoma 4x4 V6
    Supercharged
    THANK YOU, will do!
