Super White Taco Pin Stripe Removal Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sploinker, Sep 9, 2018.
  1. Sep 9, 2018 at 7:05 AM
    Sploinker
    Sploinker [OP] Well-Known Member
    NC
    2018 White TRD Pro
    Southern Style Offroad Slimline Bumper SmittyBilt X20 Winch Heise Light Bar Addictive Desert Designs Rear "Stealth" Bumper Tailgate Lock Thinkware F800 Pro 2 Channel Camera Hondo phone mount with gun magnet Center Console and Glovebox kits TRD front side light covers TRD third brake light cover Hood, Grill, Tailgate, and Bedside Vinyl Decals Interior red vinyl highlights Interior compartments inserts Extang Solid Fold Bed Cover Redline Tuning Hood Struts
    I have read what feels like a million posts on Pin Stripe removal. Paint thinner, acetone, oven cleaner, buffing, etc. However, if I am reading right and the posts are true, the super white taco does not have a true clear coat and so the question becomes, "What is the best option to remove painted on pinstripes from a super white (0040) 2018 TRD Pro?" I'm under the impression the clear coat is what protects the finish from using these products. Any professional advice or comments from those with super white and have performed pinstripe removal would be greatly appreciated.
    Thanks!
  2. Sep 9, 2018 at 7:13 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’m no paint expert but a decent rubbing compound should work regardless of whether you have single stage paint (no clear) or clear coat. You might try a good sealer and wax first. This dramatically reduces the appearance of my pinstripes, which I don’t want to buff, to save my paint from further wear.
    I would definitely not be putting acetone or oven cleaner on it!
    Single stage paint, which I’ve heard is what the super white is, is better in that it has no clear to start peeling.
  3. Sep 9, 2018 at 7:16 AM
    Rujack
    Just pick up a bottle of buffing compound and a couple micro fiber cloths and try it on a spot under the hood if you’re worried it will mess up the paint.
  4. Sep 9, 2018 at 7:27 AM
    dkap79
    dkap79 Member
    Dan
    2018 TRD Pro
    If your pinstripes are vinyl like mine were I used my wife’s blow drier and peeled them off and took the residue off with wd-40 and microfiber clothes there are a bunch of you tube videos on it
    Whitetail Assassin likes this.
  5. Sep 9, 2018 at 7:38 AM
    Rujack
    Are we talking pin stripes from branches or are we talking graphic decals?
    If decals, I used a decal adhesive remover on my decals on my 91 4Runner, which was also white and I believe single stage. It worked great with a plastic scraper and elbow grease.
  6. Sep 9, 2018 at 7:55 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Be careful with a OTC rubbing compound you could end up marring the paint and then have to fix the damage from the aggressive compound with a light polish.
    Pin stripes are easy to remove, as suggested heat it up with a hair dryer and carefully peal off. I use Goo Gone with a microfiber to remove the left over adhesive.
    Then follow up with an AIO to clean the paint after. AIO=ALL in ONE polish which will clean and protect and not overly aggressive to damage the paint if you don't know what your doing.
  7. Sep 9, 2018 at 8:03 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Removing painted on pinstripes from a new $40,000+ truck is something I would have a Pro do. I'm not it.
  8. Sep 9, 2018 at 8:08 AM
    Sploinker
    NC
    2018 White TRD Pro
    Yes, I'm also thinking down that line. Waiting to hear back from my dealer to see who painted them so I can contact them about the pinstripes, type of paint used, can they remove them, etc.
    Spackler likes this.
  9. Sep 9, 2018 at 9:50 AM
    Sploinker
    NC
    2018 White TRD Pro
    Pretty sure they are definitely painted on, cant get finger under them at all and on the inside of the back driver side door you can see 2 small dots of the pin strip colors where the painter just slightly touched the weather stripping at the end of his run that came right off with my thumbnail. Obviously not so easy with the truck.
  10. Sep 9, 2018 at 9:56 AM
    Spackler
    Spackler Well-Known Member
    Is the stripe black? Can you post a pic of your Pro? The avatar pic is too blurry.
  11. Sep 9, 2018 at 10:31 AM
    Sploinker
    NC
    2018 White TRD Pro
    Its actually 2. On e red and one black that end in a point at the front.
    the front part of the back door in this second pic looks square cut but I peeled a tiny bit off with a thumb nail. All I could get though because it was on the curve I guess I was able to get into it.
  12. Sep 9, 2018 at 11:53 AM
    Sploinker
    NC
    2018 White TRD Pro
    Good golly! Confirmed its after market paint on because I cleared about a 2 inch stretch on the rear pillar with about 40 minutes of elbow grease and a clay bar. Has to be an easier way :(
  13. Sep 9, 2018 at 3:48 PM
    JeffKill
    JeffKill Member
    Jeff
    Concord, NC
    2018 TRD Sport
    Mine were painted on also. The dealer left the info for the company that did the pinstripes in my glovebox. I contacted them and they removed them free of charge.
  14. Sep 9, 2018 at 4:39 PM
    Sploinker
    NC
    2018 White TRD Pro
    Nice, no such luck here, I'm still waiting to hear back from the dealer who did it.
