Super White Spray Paint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diesel Joe, Nov 8, 2012.
  1. Nov 8, 2012 at 12:09 PM
    Diesel Joe
    Diesel Joe [OP] Diesel guy living in a gasser world.
    Joe
    Corvallis
    2007 Toyota Tacoma Access Cab TRD Off Road
    Fog light anytime, Relocated rear diff breather, Painted badges/grille, Kenwood head unit, Midland CB, Bilstein 5100 up front set at .85",
    I'm want to color match my grille and seeing as how I have a super white truck I figure it should be pretty easy to color match. I was just wondering if someone has found a brand that is pretty damn close to super white. I hear Krylon Fusion is pretty close and I don't want to pay $25 a can with paintscratch.com. I'm looking for a $5 dollar can of paint at Home Depot. Does it exist??
  2. Nov 8, 2012 at 12:15 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Ever see a paint chip book at a body shop? There are like 55 different shades of white. Spend the money now or you'll spend it later
  3. Nov 8, 2012 at 12:15 PM
    J4RR
    J4RR Well-Known Member
    The OC
    07 DC LB TRD SPORT 4X4
    The only paint that found that was an exact match were the $25 per can paint. Those $5 can are close but to me it was obvious that it wasn't a match...don't go cheap, in the long run it will be better with legit color matched paint...unless you don't mind that it is off a bit.
  4. Nov 8, 2012 at 12:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good luck... Superwhite is hard to match, especially if you're picky. Krylon Fusion is close but you will definitely be able to tell the difference. I tried those $25/can brands (Paintscratch actually) and it still didn't match well enough for my liking. They even sent me a second batch because the first batch was off. The second batch was a lot better but still yellowed when I applied the clear coat.
    Basically, if you go the route of a cheap paint job, that's what you get, something that looks cheap.
  5. Nov 8, 2012 at 2:45 PM
    Diesel Joe
    Joe
    Corvallis
  6. Nov 8, 2012 at 3:06 PM
    StormTrooperTaco
    StormTrooperTaco Well-Known Member
    Washington
    2013 Taco TRD Sport DCSB
    Plasti Dip Wheels GY Duratracs 20% Tint all around
    Just pick up some white Plasti Dip, see how you like it, if you don't like it you can remove it.
  7. Nov 9, 2012 at 1:29 AM
    Alex88
    Alex88 Well-Known Member
    Alex
    Oakland, CA
    2010 DCLB Sport
    Manfred likes this.
  8. Nov 9, 2012 at 1:59 AM
    CanTac
    CanTac Well-Known Member
    Peterborough On./Ocala Fl.
    23 TRD Sport 4X4 D/Cab Long Box
    I had mine done at a local bodyshop for around $200. Has been great. Did it about 3 years ago now, still looks perfect other than a few dang rock chips.
  9. Nov 9, 2012 at 5:01 AM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    i am going to vinyll wrap mine. cheaper than paint and will be removable if needed and wont look like a derp'd front grill
