SUP / Paddleboard transporting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jim727386, Jul 1, 2024.
  1. Jul 1, 2024 at 5:45 PM
    Jim727386
    Jim727386 [OP] Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    Has anyone used roof rack on a 3rd gen double cab to haul SUPs? Not sure there is enough room on the roof. I would like to use the soft racks, similar to the picture BTW...my boards lengths are 10'6"
    Anyone?
  2. Jul 1, 2024 at 6:49 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    In Hawaii there are a lot of Tacomas and boards of all kinds. Most that I've seen use a metal rack mounted in the bed and a little higher than the top of the cab.
    Kolohe07 likes this.
  3. Jul 1, 2024 at 8:03 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I think your board may hit the sharks fin antenna if you aren’t using a rack with crossbars to elevate it.
    I strap down my SUP in a padded SUP bag in the bed, tailgate down, with flag waggling off the back — if it’s a short trip; or up top on my OEM rack crossbars strapped down to those velcro surfboard pads (Vesl, Dakine, etc.) — if it’s a long trip and I need the bed for gear.
    Jim727386[QUOTED][OP] and JK like this.
  4. Jul 1, 2024 at 8:26 PM
    JK
    JK Well-Known Member
    Northern California
    2018 Super White Tacoma TRD Off Road
    I’d imagine that if a roof rack provided enough clearance above the shark fin antenna, you’d be good to go. Here’s a photo of what I use.
    Jim727386[OP] likes this.
  5. Jul 2, 2024 at 12:07 AM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    With a 10'6" and 3' of contact with the racks you will be ok driving 25 mph.
    Otherwise the nose of yer boards will be wanting to lift off.
    Send it:bananadance:
    Chew and Jim727386[OP] like this.
  6. Jul 2, 2024 at 5:52 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Thanks for the replies. I think I will look for a used bed rack and go from there.
    BTW...fins forward when carrying sups or surfboards. That way if the boards try to get airborn, the fin will help stop them or slow them down til you can pull over.
    Malvolio likes this.
  7. Jul 2, 2024 at 5:53 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Nice! Who makes that rack?
  8. Jul 2, 2024 at 6:38 AM
    JK
    Northern California
    It’s the Yakima OverHaul Hd rack. With Yakima’s SUPDawg paddle board rack mounted to it.
    Jim727386[QUOTED][OP] likes this.
  9. Jul 2, 2024 at 7:51 AM
    canuck guy
    Alberta
    23TRDOR
    Use a tie down rope and secure to something it the front. That what used to do with windsurfer and looks like JK did similar in post #4.
  10. Jul 2, 2024 at 10:37 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    We always strapped boards down like this pic. Fins up and at the front of the vehicle; nose pointing back. That eliminates the lifting forces and also lets the fins provide backup in case your straps come loose.
  11. Jul 2, 2024 at 9:14 PM
    Kolohe07
    David
    Haiku , Maui, Hi
    You are correct.:thumbsup:
    That is how we always used to do it.
    I used to race downwind SUP with 14' and 17 ' boards stacked.
    When I posted, I didn't stop to think about the orientation of the boards on the rack.
    Downwind Sup here on Maui has evolved, and now everyone is riding foilboards .
    Malvolio[QUOTED] likes this.
  12. Jul 3, 2024 at 3:08 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    I lived on the west side for a couple years next to "S turns" park. I had a couple Naish nalu boards for fun. Always wanted to do a downwinder on one of those 17' SICs.
    I moved to North Shore Oahu after that, between Waimea and Pipe. I loved my time in Hawaii and miss it every day.
    Kolohe07[QUOTED] likes this.
  13. Jul 3, 2024 at 9:08 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I added two single slot e-tracks to the rear of the truck shell so a Yakima EasyTop can be temporarily attached.
