Sun visor sagging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoreyF, Jun 25, 2018.
  1. Jun 25, 2018 at 4:24 AM
    CoreyF
    CoreyF [OP] Corey
    Suffolk, VA
    2013 Tacoma 4WD SR5 Access Cab V6 Automatic
    My drivers side sun visor has begun to be real stiff when trying to lower it and it sags now too. It's gradually sagging lower and lower and won't snap up and stay in the up position. Any tricks to fix this or is replacing it the only option. Maybe it needs a lubricant or something?
  2. Jun 25, 2018 at 5:31 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  3. Jun 27, 2018 at 10:39 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    FYI
    visor hanger is covered by warranty (platinum at least, don't know about any other)
    my 2013 visor made a pop noise recently, and then I knew, it broke inside. and yes it drooped about an inch all floppy like
    A platinum warranty does cover this. Dealers will tell you 'trim is never covered by warranty' (which is true), and sunvisor is not even listed
    as things covered. But I had my visor start to droop on my 2013, and I called Toyota Financial and specifically asked three times
    is the visor hinge covered if it droops. they say hold on we gotta check...they cover the 'visor hanger'. I asked again does this mean the
    part that bolts on, or the hinge mechanism if it is drooping ? they say well, it says 'visor hanger'....so it's covered
    so...I went to dealer, told them what Toyota Financial said...and they replaced it no cost.
    NEW I was quoted 300 bucks !
    sparks Toyota said 195 !!!
    junkyard, for an immaculate visor missing just the lens cover.. 40 bucks !
    but it was free for me under warranty
    BlakeyD likes this.
  4. Jun 27, 2018 at 1:02 PM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Velcro
  5. Jun 27, 2018 at 2:39 PM
    MoVal04
    MoVal04 Member
    07 Sport
    I had the same problem on my 07. found a link in the forum for olathetoyota. called, spoke to Mark in parts, ordered on phone, mailed within an hour. My local dealer in Metairie, LA wanted 121.00 drivers side, 117.00 passenger. i paid 83.00/78.00 respectively. He stated it appears they have now revised the visor for the problem.
    Mo
  6. Jul 3, 2018 at 5:37 AM
    Spruced UP
    Spruced UP Well-Known Member
    Eric
    Jacksonville, FL
    2013 DCLB PreRunner TRD Sport, Spruce Mica
    Their website has them listed for ~$200. Yikes!
  7. Sep 29, 2021 at 7:54 AM
    Voodoochild 2k9
    Voodoochild 2k9 Well-Known Member
    Randy
    Florida
    TBD
    Undercover SE; DD Pioneer Radio
    Do the gen 3 visors have the same issue? If not, can you mount them in a second gen?
  8. Sep 29, 2021 at 12:38 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I haven't seen any cases with the 3rd Gen visors sagging like ours tend to. Doesn't mean there aren't though.
    From the looks of it, it seems like you could mount the 3rd Gen visors to the 2nd Gen, but the electrical connection is different. So if you're looking to maintain the vanity light, you may need to connect and wire that yourself.
