Sun damaged window trim?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lightsped, May 2, 2016.
  1. May 2, 2016 at 6:43 PM
    Lightsped
    Lightsped [OP] Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    Besides junkyards, where is the best place to buy the door window trim that sits just below the side windows? Mine is starting to show signs of sun damage. Is this piece easy to remove/install?
  2. May 2, 2016 at 6:48 PM
    GrandeChalupa
    GrandeChalupa Well-Known Member
    Cole
    Tampa, FL
    2013 SR5 SB 4x4 Pyrite Mica
    Stock
    A guy working at a body shop said to try wiping it down with paint thinner then going back over it with a rag that has mineral spirits on it. I have not had time to try it but I'm curious.
  3. May 2, 2016 at 11:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I use liquid silicone oil on all of my rubber trim when I wash the truck and it still looks new.
  4. May 3, 2016 at 4:11 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    They make restoration products for this. Much cheaper.
    I've hard of Back to Black, Black Magic, and the other things stated above.
    txtaco87 likes this.
  5. May 3, 2016 at 7:44 AM
    Lightsped
    David
    For me, the damage is done. I have tried Armor All and Back to Back. The rubber trim isn't bad, but there is definately sun damage. Can I buy new rubber window trim?
  6. May 3, 2016 at 10:22 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  7. May 3, 2016 at 11:50 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Mine has been pretty nasty looking since i bought my truck in 2012. They have weird spots all over them and i've tried everything to restore them with no luck. Interested to see any ideas here!
  8. May 3, 2016 at 1:17 PM
    PackCon
    Connor
    I wonder is sanding them works (I'm assuming we are talking about the plastic trim on the outside of the windows, not rubber seals).
  9. May 3, 2016 at 1:35 PM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    I'm in a similar position. Mine has almost brown spots all over it. Haven't found a fix yet.
  10. May 3, 2016 at 2:46 PM
    TheTacoma
    TheTacoma Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    I have heard this works really well, where do you get the silicone oil? I was told that a hardware store would have it, I am not sure where or what I would be looking for really though.
  11. May 3, 2016 at 3:25 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    I like to use 303 Aerospace Protectant, I get great results with it and no oily residue.
    patbegley and JimboAnz like this.
  12. May 3, 2016 at 3:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  13. May 4, 2016 at 7:19 AM
    TheTacoma
    Birmingham, AL
  14. May 4, 2016 at 7:27 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    ^^^ this for me also, love this stuff
    TheTacoma likes this.
  15. May 4, 2016 at 1:57 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No rust.
  16. May 4, 2016 at 6:28 PM
    Albross66
    Albross66 Well-Known Member
    Alabama
    2007 DCSB PreRunner TRD Sport
    Sanding works or at least it did for me. I was able to get the crap off the molding on the doors and the window molding around the back window. I wet sanded mine with 1000 grit and followed with 2000 grit. Then wiped it down with Penetrol.
    Before:
    After wet sanding:
    After wiping down with Penetrol:
    TheTacoma and Chris24 like this.
  17. May 4, 2016 at 8:21 PM
    mt1961
    mt1961 Well-Known Member
    Kingsport, TN
    2015 TRD Sport
    Just replaced mine. They were nasty with spots all over them. Pretty easy job, took about an hour or so. Install instructions are in the service manual. I bought mine from Metro Toyota Scion in Kalamazoo, Michigan. My truck is a 2006 double cab and the part numbers are:
    68163-04020 Rear
    68164-04020 Rear
    68161-04050 Front
    68162-04050 Front
    Check your part numbers before you order for your specific truck. Total for all 4 weatherstrips was $101.00. Quite a bit for 4 pieces of rubber, but looks a hell of a lot better.
    Chris24 likes this.
  18. May 4, 2016 at 8:28 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ I bet. Well done.
  19. May 4, 2016 at 9:08 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    I think/hope that treating with 303 from the get go will maintain a new appearance for a decade or more.
    Info for the new guys and whosever replaced theirs.
  20. May 5, 2016 at 6:50 AM
    Chris24
    Greensboro, NC
    How did you avoid sanding the paint? Painters tape or something?
