Sumo Springs or Timbren SES for towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jsnemec, Nov 23, 2022.
  1. Nov 23, 2022 at 4:49 PM
    Jsnemec
    Jsnemec [OP] Active Member
    Josh
    18 Tacoma TRD OR
    So I’d like to add sumo springs or timbrens to support my rear leaf springs when I’m hauling my car hauler with tractor and implements occasionally. I have an 18 TRD OR with stock suspension but in the next year or two want to lift front and rear 1-2” tops.
    I don’t want the timbrens or sumos to be resting on the frame while not towing (no weight in the bed), but I’ve seen some people talk about the sumo springs always contacting and providing about 5/8” lift. This definitely isn’t what I want, whatever I end up with I want to sit about 1/2” - 1” from the frame under normal driving conditions. Is this possible with stock suspension and once I lift the rear in the future? Thanks in advance!
  2. Nov 23, 2022 at 5:17 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They ordered 2nd gen Sumo's, that's why they contacted frame, unloaded. They are two different models, one for 2nd gen and one for 3rd gen.
    AZ Pete likes this.
  3. Nov 23, 2022 at 5:21 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Air bags for the win. Deflate when no load, inflate when you got a load. I ,love mine.
    Mark77 and NuckTrutz like this.
  4. Nov 23, 2022 at 5:34 PM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    @koditten whats cost and install and maintenance look like? I’m limited to about $300 or so
  5. Nov 23, 2022 at 5:41 PM
    koditten
    Kirk
    Central Michigan
  6. Nov 24, 2022 at 5:18 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I have Sumos on my SR, and they are great. They don't touch the frame when not under load ( even with a LEER shell) , but do the job when hauling firewood off-road.
  7. Nov 24, 2022 at 12:04 PM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    @Haole Toy did you go with the blue ones and on stock suspension? That’s the direction I’m leaning towards. From what I can tell it looks like the game between the sumo and the frame increases with a lift.
  8. Nov 24, 2022 at 12:50 PM
    Timbren-Industries
    Timbren-Industries Well-Known Member
    Hello! When there is no load, Timbren Aeon Springs should not be in contact. These SES kits are designed to work when you need them to work. When you are not hauling, you should notice nothing harsh in regards to ride quality. When hauling - our product is a progressive rubber spring that provides load support to keep the truck level under load all while keeping ride quality intact!
    Lifetime Warranty and a 100 day satisfaction guarantee.
    If you have any questions - give us a shout at 1800 263 3113!
    Thanks!
  9. Nov 24, 2022 at 1:35 PM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    Will the gap between the top of the timbren and frame increase when I add a rear block or AAL? Is there a bump stop spacer I could at that time to keep the distance the same?
  10. Nov 24, 2022 at 3:29 PM
    na8rboy
    WI
    Not on a block, may on a add a leaf. Because it is putting more arch in spring.
  11. Nov 24, 2022 at 7:41 PM
    Gord0
    Gord0 Well-Known Member
    I have Sumo’s on my ‘21 after using airbags on my older Taco. Don’t tow much at all but do load up the bed and the Sumos work perfectly.
    I recently added the Icon AAL and left the overload spring in. Gap between the Sumo’s and frame increased, made up a 1/2” spacer for between the Sumo spring and mounting plate. Rides perfect for me.
    na8rboy likes this.
  12. Nov 25, 2022 at 12:51 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Sumo in blue front and rear.
  13. Nov 25, 2022 at 7:31 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I can add Timbrens don’t contact until bed is loaded. I also have a 2/1 lift level.
    Ive had them on both my 2nd and 3rd gen Tacomas without issue. When I noticed the hardware had started to disintegrate after 7 years in the rust belt, I emailed Timbren wanting to purchase new hardware. 2 weeks later a box with an entire new set of Timbrens / hardware arrived at zero cost . Outstanding warranty and customer service by them.
    patbegley and D.A.S. Taco like this.
  14. Nov 25, 2022 at 9:05 AM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    I've had the blue Sumos for four years or so on my '18 TRD OR. I tow a 3,500# trailer with about 300# tongue weight (no load leveling hitch) Couldn't be happier. I had air bags on my previous truck, and it was a PIA to constantly check and adjust the air. I have towed the trailer about 12,000 miles, so far.
    Norcal_PWRstroke likes this.
  15. Nov 25, 2022 at 9:07 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    eurowner likes this.
  16. Nov 25, 2022 at 9:49 AM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    That is insane customer service! Are the stops pretty progressive?
    Any wear or tear on them yet??
  17. Nov 25, 2022 at 4:50 PM
    AZ Pete
    Arizona
    none....we don't get much rust in the Upper Sonoran Desert.
  18. Nov 25, 2022 at 5:08 PM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    @Gord0 doesn’t sumo spring make a spacer you can add in that situation? Not sure if it can be bought separately but it looks like one of there kits has spacers in it.
  19. Dec 17, 2022 at 11:33 AM
    Gord0
    Yes they do have a spacer. It was pretty easy for me to just make what I needed though.
  20. Jul 16, 2023 at 9:59 AM
    Tacomer 602
    Tacomer 602 New Member
    Glendale, AZ
    2023 Gray Tacoma Sport
    Hi, everyone, hope all is well. I recently bought a set of the Timbren SES Bump Stops for the rear of the truck. I have a stock set up 2023 TRD DC Tacoma Sport.
    Anyone have recommendations for the torque foot pounds when installing the Bump Stops?
    I'd appreciate any feedback.
