Summit Dakar extended wheel studs?
Discussion in 'Wheels & Tires' started by twitchhero, Dec 11, 2021.
  1. Dec 11, 2021 at 10:53 AM
    twitchhero
    twitchhero [OP] ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    Question about the Summit Dakars wheels. I dropped off my vehicle at pep boys to have my new Summit Dakar rims mounted and balanced. They called me stating that i need extended wheel studs in order to safely mount them to the vehicle. I even purchased the lug nuts off of summit website. My question is if this is actually needed? I havent heard of needing extended wheel studs for these rims.
  2. Dec 11, 2021 at 2:50 PM
    twitchhero
    North Carolina
    Nvm, got it figured out. Lesson learned, don’t use pep boys.
  3. May 31, 2023 at 1:19 AM
    Danieldee
    Danieldee Well-Known Member
    Daniel
    2015 Tacoma TRD
    I know its a couple years old but im having the same problem with discount tire. how did you get this resolved? and were you able to mount them?
  4. May 31, 2023 at 1:45 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @Danieldee most, if not all aftermarket wheels require an E/T lug which creates more thread engagement.:thumbsup:
    Stevie17 likes this.
  5. Jan 11, 2024 at 5:10 PM
    Lopezj05
    Lopezj05 New Member
  6. Jan 11, 2024 at 8:30 PM
    Danieldee
    Daniel
    2015 Tacoma TRD
    I just had to buy their lugs.
  7. Jan 12, 2024 at 7:18 AM
    Lopezj05
    Lopezj05 New Member
    @Danieldee you didn’t have a problem with the length of your studs? I’m being told they’re short and don’t feel like the SSW lug nuts aren’t getting a lot of the stud after it pokes through the wheel.
  8. Jan 17, 2024 at 12:07 PM
    twitchhero
    North Carolina
    So a good way of going about this and making sure your getting enough thread engagement is to count the revolutions when tightening them. Their are a couple of websites you can google to make sure your good. I'm still rocking the SSW lug nuts years later with stock studs so you should be fine.
