Suggestions on outer door handle for 03
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco03Trd, Jun 22, 2021.
  1. Jun 22, 2021 at 10:37 AM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Trying to stay on budget any recommendations on a good aftermarket driver outer door handle in black for 03? Or if u have a good one xtra let me know Can’t do the OEM right now here in SoCal at the steelership is $154 damm pandemic haha anyways any recommendations would be great .
    thanks in advance
  2. Jun 22, 2021 at 10:39 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I've had better luck with the cheap T1A brand handles off Amazon than I've had with OEM handles.
    They're so easy to change out that I don't see the point in spending OEM money on them, esp when the OEM ones seem to break just as easily.
    Dorman makes them for pretty cheap as well.
  3. Jun 22, 2021 at 11:29 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Yeah my Dorman's are still hanging in. I did buy a set of the metal ones for when they crap out though.
    Handles are one thing I don't think you need to spring for OEM.
    eon_blue[QUOTED] likes this.
  4. Jun 22, 2021 at 11:30 AM
    eon_blue
    Azusa, CA
    I compared the back of a Dorman handle to the back of an OEM one the last time I replaced my broken OEM, the Dorman had a bigger lip on it that engages the rod, so it's less likely to fail by slipping off and not engaging.
    There's a few ways these handles tend to fail, but that one was why my driver's side kept happening. With the aftermarket handles it doesn't happen anymore.
    01x4[QUOTED] likes this.
  5. Jun 22, 2021 at 11:32 AM
    01x4
    Yeah its one of those nice rare parts where cheaper actually seems to be better.
  6. Jun 22, 2021 at 11:34 AM
    eon_blue
    Azusa, CA
    The Dorman did eventually break when the plastic handle snapped haha. So, maybe OEM uses better plastic, I dunno.
    At the end of the day, a $15 handle and 30 min of my time versus a $150 handle and 30 min of my time, I'm spending $15.
  7. Jun 22, 2021 at 11:35 AM
    01x4
    Yeah the OEM aren't worth that kinda $$
  8. Jun 22, 2021 at 12:05 PM
    taco03Trd
    Carlos
    Riverside ca
    Trying to catch up on this .. thanks for the suggestions fellas . Anytime a good aftermarket part goes on my truck I usually do research on it but yea handles are way over price IMO from dealer .
    so dorman is a good quality part the?
  9. Jun 22, 2021 at 12:08 PM
    eon_blue
    Azusa, CA
    Between Dorman and T1A brands (both on Amazon), the T1A handles have lasted longer for me. Priced about the same.
    T1A also makes a metal handle for $30 or so iirc that's on Amazon.
    taco03Trd[QUOTED][OP] likes this.
  10. Jun 22, 2021 at 12:17 PM
    taco03Trd
    Carlos
    Riverside ca
    Thanks eon_blue ima check then out. prime day today hope I get one for good price .. :fingerscrossed:
    eon_blue likes this.
  11. Jun 22, 2021 at 12:39 PM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    Just did this today, struggled a bit. Had to cut off the larger clip as it would not push through after releasing it. Replaced the 17 year old OEM with the metal ones.
    I would have a couple of door panel clips on hand as they tend to break.
    Which Way Out likes this.
  12. Jun 22, 2021 at 2:23 PM
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    I bought one for the passenger door from Carparts.com for around $12. Of course I procrastinated changing until the drivers side broke about 6 months later...:annoyed:
    Luckily I have a 4 door... So I drove over to the "Stealer" and paid through the arse for OEM. :frusty:
    That gave me a chance to put the OEM and the knock off side by side. For the most part they are the same, except that the plastic seems to be a bit thicker on the OEM.
    Both work, I guess will see how well over time.
  13. Jun 22, 2021 at 2:45 PM
    taco03Trd
    Carlos
    Riverside ca
    Update
    Purchase the metal one on Amazon see how it turnouts..
    otis24 likes this.
  14. Jun 22, 2021 at 6:29 PM
    Vann
    Garth
    Weisenburg, PA
    stock
    Just a heads up. One of the retainer clips was slightly undersized on one I purchased. May not be an issue but it wasn't as secure as I would like.
