Suggestion for online parts suppliers
Discussion in '1st Gen. Tacomas (1995-2004)' started by retnev, Sep 9, 2022.
  1. Sep 9, 2022 at 7:49 PM
    retnev
    retnev [OP] Well-Known Member
    Which online parts suppliers do you guys suggest.
    I have to replace O2 sensors etc.
    Prefer not to buy from the D(S)tealer or Ebay, and rather ask if someone know of a great Toyota online parrts distributor that does not rip you off like the Stealer or sell you fake stuff as on Ebay.
    Thanks
  2. Sep 9, 2022 at 8:05 PM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 780k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 780,001 plus miles, Original Owner
    You can buy directly from Denso website
  3. Sep 9, 2022 at 8:08 PM
    eon_blue
    eon_blue Okayest Member
    I got a good deal on Denso sensors using coupons I had through Pep Boys, just gave them the Denso part number I needed and used a coupon that gave me a good percentage off.
    Just don't buy sensors of sites like eBay and Amazon, lot of counterfeit ones there
    Nessal likes this.
  4. Sep 9, 2022 at 8:09 PM
    eon_blue
    Also McGeorge Toyota's parts department usually has the best online prices for OEM parts dealer-wise, worth checking out
    Bivouac likes this.
  5. Sep 9, 2022 at 9:06 PM
    retnev
    McGeorge Toyota's parts, looks really great. Thanks. Denso seems for dealers and bulk purchases only. there is no way I can search for the part and buy IO could find, but it is the best place to make sure you get what you buy as authentic. Two nice options thanks.
  6. Sep 9, 2022 at 9:18 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    If your looking for actual Toyota parts there’s plenty of online dealers like the one mentioned above. If you don’t need Toyota parts I like rockauto. They have options from cheap Chinese crap to all the big name companies like denso.
    Aircates likes this.
  7. Sep 9, 2022 at 9:33 PM
    retnev
    I dont mind using brand X, but in that case I need evidence from users that it actually holds up.
    If you know of particular BrandX that holds up for cheap, I would be interested in that too.
    So if you know of BrandX oxygen sensors that undercuts the OEM version but actually works for years, I will give them a try.
  8. Sep 9, 2022 at 9:41 PM
    vern650
    brandon
    hyrum, ut
    O2 sensor I’d stick with denso, but you can get them at rockauto. I use rockauto a lot, but I try to stick with name brand parts just to be safe. I was just pointing out they have a wide range to choose from.
  9. Sep 9, 2022 at 9:59 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I usually go to RockAuto to look up prices and the part numbers for whatever component I need, then compare prices and availability across the internet.
    for example, This is the actual OEM Denso Upstream O2 sensor found at RockAuto for $118 bucks
    https://www.rockauto.com/en/moreinfo.php?pk=1607172&cc=1441488&pt=5132&jsn=875
    Listed at Amazon for $112 bucks
    https://www.amazon.com/dp/B003YNF9DI?ref=ppx_yo2ov_dt_b_product_details
    I ordered and installed that O2 sensor a few months ago on the Bank 2 side, no issues yet.
    Ponch1776 and vern650 like this.
  10. Sep 9, 2022 at 10:02 PM
    MonkeyProof
    SoCal- SGV
    there has been a lot of reported check engine lights coming on with other brand O2 sensors. Stay with the OEM Denso brand as suggested
    TWJLee likes this.
  11. Sep 10, 2022 at 6:19 AM
    retnev
    Thanks all for the responses and advice.
    I found some good recommendations you.
  12. Sep 10, 2022 at 10:07 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It seems Denso has really changed the marketing of products since last I bought was direct from Denso Aftermarket!
    I would now buy from my local Napa Dealer.
  13. Sep 10, 2022 at 10:30 AM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    As stated Rockauto is the place. Our OEM suppliers are Denso, Advics(brakes) and Aisin (among others)
  14. Sep 10, 2022 at 10:44 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I bought my last one from Amazon, Denso original (from Denso Amazon store), 2 years no issues and paid $68 to my door
    you have to pay close attention when shopping on the site, always make sure (not true always) that it's "shipped or sold by" so that way you can always get the refund if any issues
    bought my Walker exhaust there too, from the Amazon Walker store
    I've bought stuff from ebay as well, again making sure reputable entity
    Bivouac likes this.
  15. Sep 10, 2022 at 10:56 AM
    eon_blue
    Yeah if I do buy off those sites I make the seller is based in the US, if they show as being based in China then it's too risky imo.
    frizzman[QUOTED] likes this.
  16. Sep 25, 2022 at 4:26 PM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    Don’t use rock auto. If it’s cheap it’s cheap for a reason.
  17. Sep 25, 2022 at 6:17 PM
    vern650
    brandon
    hyrum, ut
    you know they sell oem parts on rockauto right? Not everything on there is cheap Chinese parts.
    Nessal likes this.
  18. Sep 25, 2022 at 6:49 PM
    Duke_962
    Nwnj
    I do but in my experience I have got so many oem and after markets parts incorrectly boxed or mis picked it just isn’t worth it anymore.
  19. Sep 26, 2022 at 12:26 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
  20. Sep 27, 2022 at 8:24 AM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
