Suggested drop for hitch mount??
Discussion in 'Towing' started by Kindghost, Sep 15, 2011.
  1. Sep 15, 2011 at 9:38 AM
    Kindghost
    Kindghost [OP] Member
    Greenville, NC
    11 PreRunner SR5
    hey guys i just bought my first tacoma and i must say i am lovin it!! i got the tow package on my 2011 prerunner and i was wondering what would be the usual ball mount drop thats recommended? i found one online that says its made especially for the tacomas and it has a 2 3/4" drop. would this be acceptable? it was kind of pricy tho. i'm new to towing too but i won't be towing anything real heavy or anything. maybe you guys with more experience can help me out a little b/c this is also my first truck:D
  2. Sep 15, 2011 at 9:43 AM
    Kindghost
    Greenville, NC
    11 PreRunner SR5
    yeah i def want a locking pin. people these days would steal it. how much would you say a good ball mount should cost?
  3. Sep 15, 2011 at 9:56 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    walmart..... Jim
  4. Sep 15, 2011 at 10:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I got a Reese kit at Wally World for like $30. It incluced the ball mount, 2" ball and a locking pin in a plastic carrying case. The case is the best part, I grease my balls so having a case to put it in afterwards is nice. And yes, I realize how that sounded and didn't see any way around it... :eek:
  5. Sep 15, 2011 at 10:05 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    I waxed mine once but never,, hit em with grease:anonymous:
    JonnyQuicksand and Kevinpd325 like this.
  6. Sep 15, 2011 at 10:08 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i have a 2” drop that we had laying around. just have to put a ball on it. and on the the locking pin. MAKE sure that the SHAFT if 3” long. since are hitches are a little different and they require one with longer shaft. the 2 1/4” will not work.
  7. Sep 15, 2011 at 10:11 AM
    ILLINOISTACOMAGUY
    ILLINOISTACOMAGUY Well-Known Member
    Darryl
    ILLINOIS
    2005 SR5 SPORT
    WeatherTech Digital floor mats front and rear. Ventvisors, Hood protector, Towing package, Bed tiedowns, Wheel to Wheel steps,
    I use a 2" and when its all said and done on my stock tacoma it sits about right....axle grease to lube it. I bought mine from Wal-Mart.
  8. Sep 15, 2011 at 10:13 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Looks like this is pretty well covered, but I will add that I have always been impressed by CURT Manufacturing's products for towing.
    Definitely overkill for our little Tacoma's, but they make quality products nonetheless. AutoAnything.com is generally the best place to purchase them, unless you can find a local retailer.
    Fink
  9. Sep 15, 2011 at 10:21 AM
    Kindghost
    Greenville, NC
    11 PreRunner SR5
    so whats the the rise have to do with anything? i just don't seem to understand it.
    thx for all the input. it looks like i would be good with a 2 in drop, but what rise?
  10. Sep 15, 2011 at 10:24 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i just had to order a 14" drop for mine! :eek: i guess that's what happens when you have a 3" lift + having the receiver built up into an aftermarket rear bumper haha.
    but seriously, in your situation, a 3" drop should be sufficient for most towing.
  11. Sep 15, 2011 at 10:32 AM
    Fink
    Orlando, FL
    99% of ball mounts can be flipped - making the ball higher, versus lower. The rise tells you how much higher the ball mount will be should the ball mount be flipped. The drop, which is what most people care about, is how much lower the ball will sit when used conventionally.
    Here is a good link that describes just about all aspects of towing & hitch/ball mount measurements - http://www.etrailer.com/faq-ballmount.aspx
    Generally, the rise measurement will be 2" less than the drop measurement because of where you measure it from, accounting for the 2" receiver size (on Class III & IV hitches).
    :thumbsup:
    Fink
  12. Sep 15, 2011 at 10:38 AM
    Kindghost
    Greenville, NC
    11 PreRunner SR5
    oohhhh.... sounds simple enuf. i will prob never flip it over. thanx.
  13. Sep 15, 2011 at 11:00 AM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    It will depend on the trailer.
    I used a straight one (no drop) on my popup, no weight distribution hitch. The tongue weight dropped the rear of the truck so far down that the trailer was still nose down, LOL, I almost needed a rise, not drop.
    My current TT requires a 2" drop I think.
    But my truck is sits about 2" higher than stock. (1" blocks plus spring TSB)
