Suggest LED turn signal bulbs that don't hyperflash
Discussion in 'Lighting' started by OhioTaco68, Oct 21, 2016.
  1. Oct 21, 2016 at 6:56 AM
    OhioTaco68
    OhioTaco68 [OP] John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Is there any LED bulbs out there that don't cause your turn signal to hyper flash ? I tried superbrightleds but my turn signals hyper flashed and they said i would need to wire in a resistor for each bulb to stop it
    ... anyone have any idea if this is true with every LED turn signal bulb?
    I have a 2016 Tacoma
    Thanks !
  2. Oct 21, 2016 at 1:33 PM
    snowbrdd
    snowbrdd Well-Known Member
    There are none.
    On older cars you can modify the flasher relay or get one specifically for LEDs. However, new ones are generally computer controlled, and I haven't heard of a way to modify the computer to use LED turn bulbs.
  3. Oct 23, 2016 at 7:12 PM
    NascarSigEp
    NascarSigEp Well-Known Member
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    What bulbs are you going to LED?
  4. Oct 23, 2016 at 7:16 PM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    You can buy a turn signal relay for led on Amazon for like $8. That's what I done on my gen 2
  5. Oct 23, 2016 at 7:20 PM
    NascarSigEp
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    I found these for my 3rd gen. It makes the front turn signals plug & play.
    https://www.ebay.com/itm/172043520065
    TEQStone Car 7440 Socket LED Decoder Warning Canceler with 50w 8ohm Resistor
  6. Oct 23, 2016 at 7:59 PM
    OhioTaco68
    Central Ohio
    Not for Gen 3 you can't
    MSU Taco[QUOTED] likes this.
  7. Oct 23, 2016 at 8:03 PM
    OhioTaco68
    Central Ohio
    I have LED'S in my reverse lights, front corner marker lights and all my interior. I had LED bulbs for my front DRL/Signal and for my rear tail lights & signal .. they worked but when you turn signal on they hyper flashed .. didn't really want to cut into wires and splice in load resistors so that's why i was wondering if there was an alternative
  8. Oct 23, 2016 at 8:09 PM
    NascarSigEp
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    That's why I got the plug & play wiring with the resistors built in. No splicing.
  9. Oct 23, 2016 at 8:13 PM
    OhioTaco68
    Central Ohio
    Ok thanks and i will check into those
  10. Oct 23, 2016 at 8:15 PM
    invidious
    invidious Well-Known Member
    San Antonio, TX
    Do you have to run resistors at each turn signal LED?
    OhioTaco68[OP] likes this.
  11. Oct 23, 2016 at 8:23 PM
    OhioTaco68
    Central Ohio
    Yes for each LED signal bulb
    NascarSigEp likes this.
  12. Dec 18, 2016 at 10:30 AM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Here is a set of really nice amber LEDs that fit the 3rd gen front signals and do *not* hyperflash. Color is perfect amber (not yellow), and they are bright but not bro-annoyingly overbright. Source: I installed a set.
    Philips X-treme Ultinon Amber LED - T20/WY21W, 180 lumens
    Here's where I bought them: http://global.rakuten.com/en/store/wattsu/item/12763x2/
    EDIT: just realized it looks like you have an SR5. Sorry, these bulbs are for the TRD models with the LED DRL. These bulbs do not double as a DRL for the SR5 trims.
  13. Aug 12, 2017 at 2:43 PM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    how's this working for you to date?
  14. Aug 12, 2017 at 2:45 PM
    daohaus
    Duan
    I have TRD Pro these should plug right in and no hyperflashing? did you do any LED upgrade to the rear turn signals?
  15. Aug 13, 2017 at 11:02 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    As far as I know, yes, they should. They plugged right in for me on my TRD OR, and did not hyperflash. I may have had to flip/reverse one of the bulbs in the turn signal socket to get it to work, but that was a simple change. They still work great and look better than stock by far. Not cheap, but I like them.
    I did not do a rear turn signal upgrade yet. I used Philips Vision 7443 LED (red) in the rear, and they *did* hyperflash when used as turn signals. I didn't want to mess with resistors yet so I use them instetad in the lower rear parkinglight/brake bulb section. I thought it was more beneficial to have the "instant on" of LED brake lights instead of the nicety of LED blinking in the rear for now.
    daohaus[QUOTED] likes this.
  16. Aug 13, 2017 at 12:39 PM
    daohaus
    Duan
    Thanks, I just looked up that part number in Amazon and they're decently priced.
  17. Aug 15, 2017 at 8:01 PM
    NascarSigEp
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    No complaints!
  18. Aug 20, 2017 at 1:09 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    is there a list of part numbers for all those LED's? Im probably not using the right terms for the search tool.
  19. Aug 22, 2017 at 7:42 PM
    daohaus
    Duan
    Got the Phillips LED in today install was pretty easy, just had to flip the polarity around so that the brake light would work in addition to the parking. Highly recommended these, I may get another pair with some resistors in the future to do the rear turn signals.
    Thanks for the tip!
  20. Aug 23, 2017 at 9:26 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Glad to hear it!
    Did you get the front Philips amber signals as well?
