Sudden, massive oil leak. Cracked filter housing!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skierd, Feb 2, 2022.
  1. Feb 2, 2022 at 9:05 PM
    skierd
    skierd [OP] Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Coming home a couple weeks ago, my Tacoma started making a bad grumbly noise from the engine. I was almost home, and as soon as I pulled in to my parking spot the oil light came on. Crap!
    stopped the engine immediately, and checked the oil level. No oil on the dipstick and a mess on the front of the engine. The offending part appeared to be the oil pressure switch as oil was coming out from around it. This photo is from the shop, after cleaning.
    From above
    Unfortunately, the sensor was not the culprit:
    The actual housing was cracked. :eek:
    It took two weeks to come in, but now everything seems ok.
    BF46E1F5-3200-4346-B777-D73F64E9B0FD.jpg B0FE4786-6865-4C9E-9797-78EB561FC2C6.jpg
  2. Feb 2, 2022 at 9:09 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    It cracked where the pressure gauge is located? Bizarre but glad you got it all sorted out.
  3. Feb 2, 2022 at 9:11 PM
    skierd
    David
    Fairbanks, AK
    Yep, cracked at the pressure switch. Bizarre for sure, and damn lucky I was close to home. I had to add 4 quarts to get oil on the dipstick again…
  4. Feb 2, 2022 at 9:29 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    good thing you parked it soon David. Can’t figure out how a crack like that would suddenly appear, doesn’t look like it goes all the way to the threads in the photo but you saw it so you would know.
  5. Feb 2, 2022 at 9:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Did it crack because you got the metal filter housing? Not trolling, genuinely curious if that has some affect?
  6. Feb 2, 2022 at 9:35 PM
    skierd
    David
    Fairbanks, AK
    Doubtful. It’s been -20 to -40 out after an ice storm. Our roads are ROUGH right now, like 4” deep cracks in the ice down to the pavement every hundred to couple hundred yards.
  7. Feb 2, 2022 at 9:44 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I run metal housings on my FJ and Tundra, but I dont let anyone but me change the oil. I have seen the guys at the dealership spin them on with impacts, and in that scenario I would want a plastic housing. I would rather the plastic housing break.
    CPS-65 and Stocklocker[QUOTED] like this.
  8. Feb 2, 2022 at 10:20 PM
    Montana_Actual
    Montana_Actual ;)
    Roads are terrible in MT, I can only imagine in AK. Definitely take their toll on our vehicles.
