Subwoofer with stock stereo + speakers
Discussion in '1st Gen. Tacomas (1995-2004)' started by kmac1701, Feb 1, 2018.
  1. Feb 1, 2018 at 6:53 AM
    kmac1701
    kmac1701 [OP] Well-Known Member
    Kevin
    Boston
    1998 Tan Tacoma PreRunner Ext Cab v6 3.4L
  2. Feb 1, 2018 at 7:24 AM
    tony2018
    tony2018 Well-Known Member
    There were talks about that in the audio section. Not so great if I recall. There was another powered sub that someone recommended though.
  3. Feb 1, 2018 at 7:31 AM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I had one of those. it was ok. then I upgraded my radio, speakers and put one more sub in. Now I love it.
  4. Feb 1, 2018 at 7:58 AM
    kmac1701
    Kevin
    Boston
    Would you say it was worth $100?
  5. Feb 1, 2018 at 8:04 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    for me it was. it fits under the seats which is a big thing for me. I need to keep the back open for gear. It's honestly not a terrible sub. Doesn't have the big bass of other subs, but hey, it's a shallow powered sub so what do you expect? Fills the truck up just fine.
    I ordered the wiring kit with mine. it was an extra $10, which is worth it
    kmac1701[QUOTED][OP] likes this.
  6. Feb 1, 2018 at 8:16 AM
    kmac1701
    Kevin
    Boston
    Right now I'm just looking for a cheap upgrade of sorts for the stock system, and I'm not too picky so it might work for me. Thanks for the input.
    Tacofire98[QUOTED] likes this.
  7. Feb 1, 2018 at 8:21 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    if that's what your looking for this one will do you just fine.
  8. Feb 1, 2018 at 9:06 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Then you can add a grom kit (i think that's the name) and add an aux input to your stock stereo.
  9. Feb 1, 2018 at 10:22 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm using one in my truck. I like the amount of bass it puts out. It's doesn't rattle my mirror or anything but it gives the music a nice low end you don't get from full range speakers. I'm running it with JBL compenent speakers up front and JBL 3-way Coaxials in back off of a 4 channel amp. This all connects to a Pioneer HU.
    For $100, I think it's pretty decent and doesn't take up much space at all.
  10. Feb 1, 2018 at 6:57 PM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    you guys got the 10" model to fit under the seats?? mine sits behind the driver seat. i like the sounds but really wish it was out of the way
  11. Feb 1, 2018 at 7:04 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    kmac1701[OP] likes this.
  12. Feb 1, 2018 at 8:21 PM
    boostedka
    James
    NM
    I mounted mine to the back of the cab in place of one of the fold down rear seats. Sounds cleaner this way not being muffled by the seat.
  13. Feb 2, 2018 at 5:28 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    This is what I am running in my regular cab bench:
    https://www.bestbuy.com/site/kenwoo...ffcode=pg257794&ksdevice=c&lsft=ref:212,loc:2
    With Dynomat it works well on the back wall. I'm not exactly looking for licence plate frame rattling sub. I just need a little depth to the sound.
    I'm running this for my radio as I wanted bluetooth.
    https://www.crutchfield.com/S-W5olQsA9NBx/p_158N5100BT/Sony-MEX-N5100BT.html
    And speakers which I am running off a small amp.
    https://www.amazon.com/GTO638-6-5-Inch-3-Way-Speakers-Pair/dp/B003KN2TF8
    Honestly not that expensive and yet amazing sound for the system.
  14. Feb 2, 2018 at 6:10 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    I put one under each seat. I swap out the seats to wrx seat, so maybe I have more clearence?
  15. Feb 2, 2018 at 6:12 AM
    tony2018
    What!?!?! Pics of seats please.
  16. Feb 2, 2018 at 8:32 AM
    boostedka
    James
    NM
  17. Feb 2, 2018 at 8:35 AM
    tony2018
    Hmm...not a bad place to put it.
  18. Feb 2, 2018 at 8:37 AM
    boostedka
    James
    NM
    Thanks. I rarely use those seats, especially the one behind the driver's seat so it was not a loss removing it. And it doesn't take up any more space than the seat did.
  19. Feb 2, 2018 at 9:13 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    kmac1701[OP] and boostedka like this.
  20. Feb 2, 2018 at 10:40 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I would honestly look at upgrading the deck, first. Aftermarket decks have MUCH more power than stock, so even if you keep the stock door speakers, the additional power will drive them better and they'll sound better. I've been running the stock speakers with a Kenwood deck for like 10 years in my doublecab. I'm no audiophile, but it definitely sounds much better than the stock deck.
    For $100, you can get a pretty decent deck that will do all sorts of stuff the stock deck NEVER will do, including a sub pre-out, mp3's, bluetooth, etc...
    boostedka likes this.
