Subwoofer(S) in a 2021 Access Cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Great Dane, Oct 24, 2020.
  1. Oct 24, 2020 at 12:23 PM
    Great Dane
    Great Dane [OP] Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    Has anyone on here installed a subwoofer or 2 in their Access Cab? I'm going to install one in mine once I get it, and if someone else has, I'd like to see what they did and where they put it.
  2. Oct 24, 2020 at 12:39 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Tacoma search ...
  3. Oct 24, 2020 at 12:40 PM
    Great Dane
    Dane
    Georgetown, Ky
    Did that first. Didn't find anything.
    Thank you for the suggestion though.
  4. Oct 24, 2020 at 1:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is one posted around here but it replaces the trim piece between the rear seats, is quite big, and doesn't look very nice.
    I'm not sure why someone hasn't made a thin one for under the passenger seat, but there seems to be a good amount of space there.
  5. Oct 24, 2020 at 1:59 PM
    GOTSAND?18
    stock
    Not the same truck but on my old 99 ford ranger access cab . I put the two seats down threw my subwoofer box on top of it so the 2 10” subs faced up and added a metal bracket that mounted to the back wall to keep it secured . Worked great .downside I lost the space . I didn’t care sounded great .
  6. Oct 24, 2020 at 2:35 PM
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    For any decent low end you need at least .75 - 1 cubic foot of airspace. Most "under seat" subwoofers are anemic at best. Under seat rarely works unless you are good with making a cabinet that sits below the truck, and then venting the output through a hole in the floor. Most people feel uncomfortable about a hole that big, so the normal thing to do is just to sacrifice one side of the rear area at least for a single 10" woofer to start with.
    Boghog1 and tonered[QUOTED] like this.
  7. Oct 24, 2020 at 2:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you, but anything would help over just the door speakers.
    On my side of things, I use the rear. Either loaded with stuff on many occasions, including the middle gap, or hauling the fam.
    So, I'm most likely SOL on a sub.
  8. Oct 24, 2020 at 2:48 PM
    Great Dane
    Dane
    Georgetown, Ky
    I've got an idea for one that won't be thrown together like it sounds like the one you're talking about is.
    tonered[QUOTED] likes this.
  9. Oct 24, 2020 at 2:51 PM
    Schlucki
    Rich
    North Dallas, TX
    Your best bet then would be to heavily sound dampen the doors. Use something like the Noico material on the entire outer skin (sheet metal that is the outside of the truck) and then cover the entire inner skin so it is airtight except for where the panel clips go through. An upgraded speaker set for the front with a 6x9 woofer in each door and then a small coaxial speaker up in the dash would be next. Then finish it off with a 4 channel amplifier that will have a built in crossover in it. Run the doors on a low pass setting up to say 400 hz and then high pass the dash speakers at a similar frequency. It won't play rap or electronic at high volumes, but it will be 10x better than stock!
    The other way would be to just add a small 10" enclosure that sits in the rear, and take it out when you need that last bit of space. Just protect the wires from touching each other when not in use.
    BMH and tonered[QUOTED] like this.
  10. Oct 24, 2020 at 2:58 PM
    su.b.rat
    su.b.rat broken truck
    how different is the space behind the seats AC vs. DC?
    tonered likes this.
  11. Oct 24, 2020 at 3:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am planning on the sound mat now. I'm not sure how enthusiastic I will get, but I will get enough.
    With some recent mods and my current tune, I've been enjoying the sound of the engine more. Covering the back wall and outer skins might tide me over?
    I had heard an insulated door recently and it was pretty damn nice.
    b3itz likes this.
  12. Oct 24, 2020 at 3:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is none behind the AC seat backs. It is essentially a padded wall panel.
    su.b.rat[QUOTED] likes this.
  13. Oct 24, 2020 at 3:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ?? You might be quoting the wrong person?
    Unless you are talking about my comments about the existing sub solution?
  14. Oct 24, 2020 at 3:13 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    tonered likes this.
  15. Oct 24, 2020 at 3:17 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    OEM audio+ is the only access cab sub enclosure I'm aware of. This was probably the one mentioned, though I wouldnt call it thrown together. Seems like the best solution for most while retaining both seats and most space
    tonered likes this.
  16. Oct 24, 2020 at 8:07 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Yes, not a lot of possible location{s}/room to put sub in the AC. So I have active (powered, self-amplified) sub under driver seat. Kenwood, fits and sounds perfect.
    more than enough for me, recommend to check this out.
  17. Oct 25, 2020 at 7:25 AM
    Great Dane
    Dane
    Georgetown, Ky
    I was.
    I'm gonna build something similar to the JL Audio set up.
    I'll also be replacing the head unit, using a 4 channel and a mono subwoofer amp, a component set for the front, and I haven't decided on weather or not I'm just gonna do a midbass in the rear doors or a coaxial.
  18. Oct 25, 2020 at 10:51 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Not sure about the passenger seat .. After putting seat covers on new 2020, I found there was a lot more room underneath the driver's seat. Even at that.. There's not a whole lot of room under either. I was thinking about getting a sub to go under the drivers seat, but then thought better. Even at a reputable stereo shop, the thought of some 19 year-old 'Stereo Jockey' tearing half the insides up and slicing and dicing wires ... Yeah... Well, not my brand new rig.
    I will say that I find the factory stereo completely more-than-acceptable. And since I listen to classic rock/country .. The bass is fine.
    I'm not listening to rap where I need the bass to start cracking window glass.
    I have read a few times from other posts that have replaced the 6x9's in the doors with some Kicker replacements and they seem to be more than happy with those, so I might just go that route and be happy.
  19. Oct 25, 2020 at 3:15 PM
    Great Dane
    Dane
    Georgetown, Ky
    I'm spending money on that too.
    You see, I'm not only a car guy getting into my first 4x4, I'm also an audiophile. I love music, and it has to sound good. So I'll be spending money on some good components in the front, the sub in the rear, and whatever I decide to do with the rear doors. I already have the 2 amps I'll need, and I've got the head unit picked out that I plan on using.
    I can't be happy with that.
  20. Oct 26, 2020 at 10:40 AM
    BMH
    Bruce
    I got the AC, because I wanted the 6' bed and I'm not hauling people around. I wanted the one where the back is just bare with the flat panel on the back of the cab, but it was the dealer saying 'We can order it, but can't say for sure when it'll get here ... If ever' thing, so I bought one that has the jump-seats. No adult could sit back there for more than about 10 minutes before it became torture. (Think 'fetal position') There's not a lot of room back there. On the other hand, the jump-seats do fold up out of the way pretty decently.
    If the seats were removed, or if it was just the blank panel in the back, you could easily fit, say, a 10" sub-woofer box on either/both sides and still have room to throw gym/duffel bags/etc back there. You can fit about 1/2 dozen grocery bags back there pretty easy. Other than that, there's not that much room.
    su.b.rat[QUOTED] and Boghog1 like this.
