Subaru Hood Scoop On 1st Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by apotter, Aug 30, 2019.
Honest Feedback
  1. Give’r Hell Bud!
    46 vote(s)
    71.9%
  2. Nope.
    7 vote(s)
    10.9%
  3. Too Much Free Time Bro...
    13 vote(s)
    20.3%
Multiple votes are allowed.
  1. Aug 30, 2019 at 8:59 PM
    apotter
    apotter [OP] Well-Known Member
    Southern Maine
    2023 Tacoma
    Have seen a few threads where the 4runner hood scoops were grafted into the tacoma’s hood...couldn’t find a 4runner or Tacoma hood with a scoop for the right money so adding a ‘98 subaru Outback hood scoop to the ‘98 tacoma.
  2. Aug 30, 2019 at 9:02 PM
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    IF YOU BUILD IT THEY WILL COME .. LOL
  3. Aug 30, 2019 at 9:03 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Too small, get the big sti one...
  4. Aug 30, 2019 at 9:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Now you're gonna get the sun reflection like all the skewp owners complain about!
    1997tacomav6 likes this.
  5. Aug 30, 2019 at 9:07 PM
    apotter
    Southern Maine
    2023 Tacoma
    May have to if the supercharger is ever put on order
  6. Aug 30, 2019 at 9:10 PM
    apotter
    Southern Maine
    2023 Tacoma
    Nah..had a 2013 TRD sport and never had any issues. Just need a good set of sunglasses
  7. Aug 30, 2019 at 9:15 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Screw the scoop, cut a hole and pop a super bee hemi scoop in there.
    misterquad and c0climber like this.
  8. Aug 30, 2019 at 9:16 PM
    Sassafras
    Sassafras Active Member
    Stephen
    Chesapeake Bay
    1997 Single cab 2.7
    Oil drain valve Front hitch
    Can't wait to see this finished, looks good so far:thumbsup:
  9. Aug 31, 2019 at 4:07 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    From the picture, it looks like it's going to be clean. Nice.
    Kolunatic likes this.
  10. Aug 31, 2019 at 4:44 AM
    1997tacomav6
    Denver
    Are you making it functional with a hole in the hood or just for the look.
    If just for the look you probably will have to block off the scoop inlet or else
    the scoop will act like a kite pulling on the hood at speed so it better
    be well attached.
    I found my 4runner scoop on carparts.com for around 150.00 and they
    cut the main section out of the hood and shipped it.
    The 4 runner scoop originally has a block off for air flow as it’s originally not functional
    so you would not have any kite effect or drag or u can cut a hole 4 air to flow in the hood and the scoop. I chose to make mine functional.
    A hood scoop gives the truck a completely different look.
    Definitely do it and take your time doing it correctly.
    Not to many scooped Tacoma trucks out there.
  11. Aug 31, 2019 at 6:01 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    A friend of mine just got a hood for his 4runner on carparts.com... there
    was a problem with it and his experience is that they have great customer
    service and took care of him right away...
    -Mike "credit where it's due..."
  12. Sep 2, 2019 at 1:34 PM
    apotter
    Southern Maine
    2023 Tacoma
    That’s the beauty of this scoop - The ‘98 outback came stock with a block off plate. No supercharger...yet..
    1997tacomav6[QUOTED] likes this.
  13. Sep 2, 2019 at 1:35 PM
    apotter
    Southern Maine
    2023 Tacoma
    $150 is real money..So far two hoods and still under $150
  14. Sep 2, 2019 at 3:29 PM
    SStavin
    SStavin Active Member
    Dan
    01 Prerunner
    Legacy GT owner here. Love it!
  15. Sep 2, 2019 at 5:43 PM
    TrePar1080
    TrePar1080 New Member
    Trey
    Gold 97 Tacoma 4x4
    Cluster swap, tilt column swap, head light swap, remote oil filter install, lift, wheels and tires on the way
    Will a 2000 4runner hood fit on a 97 tacoma?
  16. Sep 2, 2019 at 6:27 PM
    1997tacomav6
    Denver
    No, not unless you change the grill bumper and fenders to 4runner parts
    Taco critter likes this.
  17. Sep 3, 2019 at 7:07 PM
    apotter
    Southern Maine
    2023 Tacoma
    exactly..no big deal, just a quick swap to the entire front end to add a scoop!
  18. Sep 3, 2019 at 10:24 PM
    1997tacomav6
    Denver
    :worthless:
    jonesbt likes this.
  19. Sep 4, 2019 at 3:07 AM
    apotter
    Southern Maine
    2023 Tacoma
    Easy there Kemosabi! Definitely taking your advice and on the ‘take your time and do it correctly’ - plus working two jobs as an engineer and real estate agent, and had to replace an exhaust gasket on the 83 toyota camper last week, lots of time spent there so we could go camping.
  20. Sep 4, 2019 at 3:09 AM
    apotter
    Southern Maine
    2023 Tacoma
