Sub box seems too big and seat won't latch
Discussion in 'Audio & Video' started by 512_south, Feb 21, 2021.
  1. Feb 21, 2021 at 9:35 AM
    512_south
    512_south [OP] New Member
    Dain
    2020 TRD Off Road
    I recently purchased a 12" Subwoofer box from Taco Tunes. The box looks great but I'm having some install problems. I'm installing into a 2020 TRD Off Road (Double Cab).
    Everything seemed to go okay but I can't latch the seat and the sub seems to hit the rear of the seat when playing loud.
    Anyone else have this problem or can recommend a better fitting box?IMG_7384.jpg IMG_7383.jpg
  2. Feb 21, 2021 at 10:26 AM
    MannyTheAudioGuy
    MannyTheAudioGuy Well-Known Member
    Emmanuel
    Napa
    2017 Tacoma TRD Sport
    I have put in Racesport gen3 leds I'm the process of doing a custom audio overhaul which will include Hybrid audio unity 6x9 mid bass, unity 3 inch mid driver in the dash and fiberglassing tweets in pilar soundeading all the doors, floors, and headliner and I will be using a helix processor to retain the factory radio and as far as subs I might make custom brackets to move rear seat foward a few inches to get a full size sub in there or I might just go with a pair of jl tw5 or tw3 and it will all be powered by jl audio HD amps or I might try out the new hybrid amps
    Try removing the mat that is behind the box from the factory it will give you a tad bit more clearence
    CoastieRon likes this.
  3. Feb 21, 2021 at 10:27 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Yeah, I don’t see how that sub
    Has any room for excursion. How does that even work.
  4. Feb 21, 2021 at 10:29 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Really tight fit right there. Gonna need to find some room somewhere for that setup to work right.
  5. Feb 21, 2021 at 10:31 AM
    FastEddy59
    Eddie
    Oh, and Big Welcome to TW while I’m at it. :hattip:
    512_south[OP] likes this.
  6. Feb 21, 2021 at 10:32 AM
    512_south
    Dain
    2020 TRD Off Road
    Thanks for the suggestion. Got it to work. Needed to remove the plastic backing on the seat. Now it latches and doesn’t rattle (presumably from the sub hitting the back of the seat)
  7. Feb 21, 2021 at 10:39 AM
    FastEddy59
    Eddie
    Be good if you could get all the room you can. Those move pretty far when you start gettin’ into it.
  8. Feb 21, 2021 at 10:43 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    On the bright side, Taco Tunes didn’t rip you off like they usually do for most people.
    Brushog65 and GRNT4R like this.
  9. Feb 21, 2021 at 6:06 PM
    FatMac
    FatMac Active Member
    2020 TRD Sport Premium
    Had a similar box in my 2008. It was from SuperCrewSound. I had to remove the bin, and the plastic from the back of the seat like you did. I have a 2020 Tacoma now, will not be doing that again. I missed having the ability to fold the seats down flat.
  10. Feb 21, 2021 at 6:29 PM
    ryanvar42
    None
    Can still do it if you add a thin piece of metal or something
  11. Mar 1, 2021 at 10:48 AM
    JimResnikoff
    JimResnikoff Well-Known Member
    JIm
    Tacoma
    Rockford / Focal Audio upgrade
    You can get longer bolts for the rear seats.. and some spacers.. That's what I wound up doing. I added half inch spacers with the seat bolts.. You may have to bend the catch for the rear seat latch a little as well. Also if you move the bench seats up in the same manner with spacers the angle stays the same. It all depends on how much room you need. You may also have to remove the child seat restraints to get the box to sit farther back depending on the design.
